Complete VCDS - Vagcom mod list
2 reading
854K views 723 replies 199 participants last post by  Gongy
#1 · (Edited by Moderator)
I've been adding mods today and realised that we have no comprehensive list of codes on this forum.
So here is the full list (as of right now), they have been checked however I hold no responsibility if you mess up!
I'll keep adding them as new ones are found
Please post any others I've missed or any mistakes and I'll add them to the list.
These have been tested completely on pre-facelift. Most should work on a facelift car however there are a couple that won't or need to be completed a different way.
The only mods that work on the Chorus, Concert or Symphony stereo are the ones that don't use hidden menu options. The hidden menu is not accessible from chorus or symphony stereos.
No idea how to use VCDS? Here is a PDF to get you started -
Guide Here
VCDS for dummies more appropriate?!!
VCDS For Dummies Here!!
More questions about VCDS? Here is a page to answer those questions -
FAQ Here
Most importantly... Enjoy turning on the features Audi didn't want you to have!
____
The A5OC List
Enable Hidden menu in MMI
  • Adjust bluetooth microphone sensitivity
  • Adjust Back-up Camera Picture
  • Change MMI 3G splashscreen
  • Disable After-wipe of windscreen wipers
  • Disable amber corner lights
  • Disable amber side markers
  • Disable Key warning (keyless models)
  • Disable LED 'wink' on turn signal - pre-facelift
  • Disable LED 'wink' on turn signal - facelift
  • Dim LED 'wink' on turn signal
  • Disable bulb error message with LED reverse lights installed
  • Disable "Lights are on" warning
  • Disable NAV & Phone warning messages while entering data at speed
  • Disable Seatbelt Chime
  • Disable soundaktuator (speaker on face lifts)
  • Enable Adaptive brake lights
  • Enable Ambient Interior Lighting Control
  • Enable Optic rear parking for cars without front parking sensors
  • Enable Automatic Gear selection shown in DIS
  • Enable Automatic Hill Hold Assist 'lite'
  • Enable Auxiliary ventilation
  • Enable Battery meter does not appear to work on facelift cars with MMI 3G+ HDD Navigation
  • Enable DIS with Efficiency Program
  • Enable Double Disarm Beep
  • Enable Drivers Memory Seat
  • Enable DRL Selectable via MMI
  • Enable DRL
  • Enable Audi Drive Select without the buttons
  • Enable Euro parking lights that turn on signal at night
  • Enable interior lighting option
  • Enable fog lamp to come on for the same side as that turn signal
  • Enable Front Turn Signals as Parking lights
  • Enable Gauge Test/Needle Sweep
  • Enable Horn confirmation on locking
  • Enable Import CDs to MMI's HD
  • Enable Independent Fogs control with high beams
  • Enable Lap Timer
  • Enable LEDs remain bright for parking lights
  • Enable Rear Tail Lights on with DRLs
  • Enable Release Parking Brake without putting foot on Brake
  • Enable Release Parking Brake without putting seatbelt
  • Enable Remote Operation windows&sunroof
  • Enable Reverse mirror tilt
  • Enable Speed on chorus, concert or symphony display
  • Enable ‘Tourist’ Mode – Headlight Convertor (MMI 2G)
  • Enable TPMS (Tyre Pressure Monitoring System)
  • Enable Video in Motion on MMI
  • Set Audi parking system - Switch OFF Speed
  • Set Custom ADS settings
  • Set Headlight washer - cycles
  • Set Headlight washer - duration
  • Adjust Consumption in DIS
  • Adjust LED Brightness
  • Change Language
  • Activate SDS for cabriolet
  • Change fuel tank characteristics
  • To increase radio play time after car is turned off
Audi A4/S4/A5/S5 B8
VCDS (VAG-COM) codes
Enable Hidden menu in MMI 3G
[5F - Information Electr.]
[Adaptation - 10] -> Channel 6
change 0 to 1
To access the hidden menu, hold down car and setup together for 5 seconds
Use this hidden menu at your own risk.
Enable Hidden menu in MMI 2G
[07 - Control Head]
[Adaptation - 10] -> Channel 8 -> Change 0 to 1
Use this hidden menu at your own risk. Caution: Keep away from the "Bootloader"
____
  • Hidden menu
  • Diagnose
  • Settings
  • Mic sensiblity - choose -6db/0db/+6db
____
[6C-Back-up Cam.] [Security Access - 16] (enter security code 22351)
[Adaptation - 10]
Channel 10 (Brightness)
Default: 50 (Set between 1-100)
Channel 11 (Contrast)
Channel 12 (Saturation)
Channel 13 (Temperature)
____
Change MMI 3G splashscreen...
Enable through the "hidden menu":
  • - navigate to 'car/carcodingvehicle'
  • - choose the model of choice in 'configuration line'
  • - select 'Update Splashscreen'
  • - restart MMI
____
[09 – Cent. Elect.] [Coding - 07] -> [Dropdown] -> "x ** 8K1 955 119 ** WWS xxxx" -> Long Coding Helper -> Byte 1
Bit 3 - Remove check mark (1 = active)
____
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 10
Submodule 0
Bit 3 - Set to 0 to disable amber side markers (U.S. vehicles)
____
[46 – Central Conv.] [Coding - 07] -> Long Coding Helper -> Byte 9
Bit 7 set to 0 (Uncheck)
____
Disable LED 'wink' on turn signal - pre facelift
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 3
Bit 2 - LEDs remain at full brightness with parking lights (1 = active)
Bit 7 - Turn off LED-strip DRLs with indicators (1 = active)
____
09 – Cent. Elect.] [Security Access - 16] (enter security code. One of the default codes is- 20113)
[Adaptation - 10] -> Channel 3 (Heading Wink Brightness)
Default Value is 26, Setting value to 88 (Makes it identical to normal brightness)
____
Dim LED wink on turn signal for US cars
Instead of complete wink off, there is another mod that comes as stock in Europe. There is an LED dim instead of wink.
Starting with factory setting:
Central Electronics 09
Coding 07
Long Code helper
Byte 02 - Check bit 6 (Side Marker as DRL)
If you have already eliminated the winking, the you will need to go to Byte 03 and undo the modification. In other words, the winking DRL options (Bit 7) will need to remain checked/on as it was in the factory setting.
____
____
Disable "Lights are on" Warning
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 5
Bit 3 - Set to 0 to disable "lights are on" warning when you open the door.
____
[5F - Information Electr.] -> Adaptation -> Set channel 2 & 3 to 250
____
[17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 0
Bit 2-4 – Seat Belt Warning
____
To mute the Soundaktuator
A9 Structure Borne Sound
Adaptation 10
At Channel drop down choose "Volume of structure borne noise actuator" (only choice)
Enter a value in the proper box (0% = mute )
____
[46 - Comfort System] [Coding - 07] -> Long Coding Helper -> Byte 8
Bit 0 – Emergency Brake Flashing via Turn Lights active (1 = active)
Bit 1 – Emergency Brake Flashing via Brake Lights active (1 = active)
____
Enable Optical rear parking for cars without front parking sensors
[10 - Park/Steer Assist] [16 - Security Access - 71679] do it [07 - Coding] Byte 0 - Bit 4 change 0 to 1
____
[02 – Auto Trans] [Adaptation – 10]
Select “Single Gear Display” from top channel drop down menu
Select “D on/S on” from New value drop down menu
____
Enable Automatic Hill Hold Assist ‘lite’only works on certain abs modules - see below link
[03 - ABS brakes][Security Access - 16] (Enter code presented by program)
[Coding – 07] -> Long Coding Helper -> Byte 1
Bit 6 set to 1 to enable hill hold assist.
VagComABS
____
[5F - Information Electr.] [Coding - 07] -> Long Coding Helper -> Byte 6
Bit 1 – Set to 1
[Hidden menu] [car] [cardevicelist] [Auxiliary heating] Enable
[08 - Auto HVAC] [Coding - 07] -> Long Coding Helper -> Byte 1
Bit 3 – Set to 1
Bit 4 – Set to 1
____
For MMI equipped cars
[Hidden menu] [car] [cardevextdevicelist] [Battery] Enable
[Hidden menu] [car] [carmenuoperation] [Battery] Set to 5
Reset MMI
or
[56 - Radio] -> Adaption -> Channel 39, add 16 to your value
For symphony, Chorus and Concert
Select module 56 - Radio
Select “Adaptation – 10
Select channel 39
Add 16 to the present value
"test"
"save"
“Done, Go Back” and "Close Controller
____
Enable DIS with Efficiency Program for MY2010+ (Not a complete Program without the Start/Stop System)
[17 - Instruments] [Adaptation - 10] -> Channel 77
change 0 to 255
____
[46 - Central Conv.] [Adaptation - 10] -> Channel 63
Add 4
ensure Module 46, Byte 1, Bit 2 is ticked. This activates the alarm audible notification option
____
36: Seat Mem - 07 Coding - Long Coding Helper - change Byte 2, bit 0, to 1
Seat memory will be there however greyed out in MMI
Press and hold down unlock button on key fob for 5 seconds for the windows to come down
Press and hold down lock button on key fob for 5 seconds for the windows to go back up
In MMI, Seat Adjustment you are now able to find Driver's seat, you can set Key memory on/off. Set it "on" for both keys separately.
____
[09 – Cent. Elect.] -> [Coding – 07] -> Long Coding Helper -> Byte 3
Bit 5 set to 1
____
Enable DRL
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 2
Bit 1 = DRL via Front Side markers
Bit 2 = DRL via High Beams
Bit 3 = DRL via Fogs
Bit 4 = DRL via LEDs
Bit 5 = DRL via Parking Lights
Bit 6 = DRL via Side markers
Bit 7 = DRL via Tail lights
____
Audi Drive Select (ADS)
____
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 9
Bit 0 - Set to 1
____
Enable interior lighting option for pre-facelift
MMI Basic (Symphony/Concert radio) - (NON-MMI - 2G/3G):
Code:
[56 - Radio]
[Coding - 07] -> Long Coding Helper -> Byte 8 Bit 7 - Interior Light Settings active - (1 = active)
MMI high (2G):
Code: Enable the Interior lighting (extended) MMI item:
[07 - Control Head]
[Adaptation - 10] -> Channel 1 add 2 to the existing value
MMI high (2G hidden menu as alternative)
If you choose to use the 2G hidden menu you will find the setting using the following:
DIAG SETTINGS -> APK 0x01, 0x0B, 0x0C -> Interior lighting (extended)
MMI 3G and MMI3G+
This can only be activated through hidden menu
Enter hidden menu - choose car - choose carmenuoperation - select interior light - set to 5 to allow adjustment whist moving - press return - select cardevicelist - choose interior light and press to fill box in - press return
*at this point 3G owners do step below, 3G+ go to (3G+ only) below
(3G only) Reset MMI (press setup, scroll wheel and top right button next to scroll wheel at the same time)
(3G only) Option will show in MMI
(3G only) [09 – Cent. Elect.]
[Coding - 07] - Long Coding Helper -Byte 16 Bit 6 - Set this bit manually to 1
(3G+ only)
Facelift needs an extra setting to activate the option.
Hidden Menu > car > carbusassignment > Interior Light > change from 9 to 1.
Reset MMI
Enable interior lighting for facelift cars
[09 – Cent. Elect.]
[Coding - 07] -> [Long Coding Helper] -> Byte 16
Bit 6 - Interior/Ambience Lighting Adaptation active
____
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 4
Bit 0 - Check the box or change :Bit 0 set to 1
____
Bit 0- Check the box or change :Bit 0 to 1
Once the change has been made you can enable the front turn signals as DRL's by making the following change:
Bit 6 - Check the box or change :Bit 0 set to 1
____
[17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 1
Bit 0 - Check the box for "Gauge Test/Needle Sweep active"
____
Enable Headlights on all the time
Bit 5 - Check the box or change (Bit 5 Set to 1)
____
[46 – Cent. Convenience.] [Coding - 07] -> Long Coding Helper -> Byte 1
Bit 2 - Check the box or change (Bit 2 Set to 1)
____
[Hidden menu]
Main/Diagnose/Settings
Import Media
Set to 4 of 4 "Copy/Ripping"
____
Bit 1 – (Front) Uncheck the box or change :Bit 1 to 0
Bit 2 – (Rear) Uncheck the box or change :Bit 2 to 0
____
Enable Lap Timer
Bit 3 - Check the box for "Lap Timer active"
__
Enable Remote Operation Windows and Sunroof
[46 - Cent. Conv.] [Coding - 07] -> [Long Coding Helper] Byte 2
Bit 2 - Set to 1
__
Bit 7 - DRL's via Tail Lets Active (1 = Active)
____
[53 - Parking Brake][Security Access - 16] (Enter code presented by program)
[Adaptation - 10] -> Channel 4 Set to 0
____
[Adaptation - 10] -> Channel 7 Set to 0
____
[52 Door Elect, Pass.] -> [Coding - 07] -> [Long Coding Helper] -> Byte 4
Bit 3 and Bit 2 set to 1
____
Module 56 - Radio
Adaptation - 10
Channel 2 --> change 0 into 1 (driving school mode active).
New menu item: Under Radio Setup "ON/OFF" driving school mode.
____
[09-Central Elect]
[Coding – 07]
[Long Coding Helper] - Byte 4, Bit 6 = 1
Enables the 'connection' between Cent. Elect and the Headlight Convertor MMI menu item
[55-Xenon Range]
[Adaptation – 10]
[Channel 10] - 0 = Disable 1 = Enable
Press ‘Test’ and then ‘Save’
Enables the Headlight Convertor MMI item under the CAR button.
Restart MMI to see changes.
____
Enable TPMS
* only works with certain ABS modules - see below link *
VagComABS
____
Enable Video in motion on MMI
[5F - Information Electr.] [Advanced ID - 1A] Note 1st Serial number
[Security Access] Enter Digits 6, 13, 10, 14, 11 of the 1st Serial number
[Adaptation - 10] -> Channel 48
Set to 255
Reset MMI
____
[10 - Park/Steer Assist] [Adaptation - 10] -> Channel 23
Set to 20 (max value in km/h)
____
Set ADS to specific preset Comfort, Auto, Dynamic or Individual
[09 – Cent. Elect.][Security Access - 16]
Set to 01 - Comfort, 02 - Auto, 03 - Dynamic or 04 - Individual
[Adaptation - 10] -> Channel 64
[Adaptation - 10] -> Channel 65
[Adaptation - 10] -> Channel 66
*Note all four channels needs to be set to the same value.
____
Set Headlight washer - Duration
[09 – Cent. Elect.]
[Security Access - 16] [Adaptation - 10] -> Channel 6
change to e.g. 500
____
Set Headlight washer - Cycles
[09 – Cent. Elect.]
[Security Access - 16] [Adaptation - 10] -> Channel 26
change to e.g. 10
____
[17 - Instruments]
change 100 to xxx (see samples below)
Sample 1 - Calculation based on volume per distance (e.g. l/100km):
DIS: 9,3 l/100 km.
Real: 9,8 l/100 km. (100 * 9,8 / 9,3 = 105,38)
Channel 3 will be changed from 100 to 105
Sample 2 - Calculation based on distance per volume (e.g. MPG):
DIS: 23 MPG.
Real: 24 MPG. (100 * 23 / 24 = 95,83)
Channel 3 will be changed from 100 to 96
____
Adjust LED brightness
[09 – Cent. Elect.] [Security Access - 16] (enter security code. One of the default codes is- 20113)
[Adaptation - 10] -> Channel 03
Set between 5 and 100 (5 being lowest and 100 brightest)
____
Select language in DIS:
17 - Instruments
Byte 8 -> Bit 0-4 - ->
Select the language.
____
Activate SDS for cabriolet:
5F–Information Electr.
Change Byte 15 – Bit 0 to 1
Change Byte 16 – Bit 0 to 0
____
Change fuel-tank charisterics:
17 - Instruments
Adaption - change channels 30 and 33
____
To increase radio play time after car is turned off:
In the Hidden Menu:
MMI 2G:
"MMI->SETTINGS->Standby Timer" - will allow you to hear e.g. Radio or CD longer before MMI shutdown (if ignition is OFF) - default 10 min. and the max. is 60 min.
MMI 3G:
From the main screen select 'onofftimer', set 'Standby delay'. The maximum value is 30 minutes
#409 ·
Thanks for that C99. for 300 EUR though i think i will pass.
#410 · (Edited)
Much thanks to the creator of this thread!
But now I am trying to figure out the coding to disable the tail light side marker...
Anyone?
09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 10 Submodule 0
This only seems to disable the front...
EDIT:
Here is the coding to disable the rear side markers and confirmed on PRE-FACELIFT ONLY I believe the coding is different for facelift vehicles.
Central Convenience
Security - Enter 16017
Adaptations
Enter Channel 209 and Write Down The Number
Enter Channel 210 and Write Down The Number
Channels 209 and 210 - Change to "0" (That's the number zero)
#411 ·
Cool, got a VAGCOM lead and program to have a play this weekend :)
Prob gonna mess it all up hahaha.
Will take screenshots etc before hand ;)
#412 ·
Whatever settings/coding you change - make absolutely sure you make a note of the existing coding/settings for a module and what precisely you change. It's the only way you'll be able to go back and undo anything that you might not notice immediately as causing a problem
If you want to learn how all the steps work, do the TPMS activation if you have the correct ABS controller. You need to download the read the coding guide as the long coding element is far from obvious!
#414 ·
Thanks, I took screenshots of all the codes before I made any changes and so far all seems ok.
How do I do the TPMS as the link in the op is dead?
#413 · (Edited)
What Are the best/Necessary VCDS mods
Hi Guys,
I was just wondering what the best VCDS mods were in your opinion.
My brother is a master tech at Audi and has got VAGCOM and the lead he is coming over this weekend and is going to do dome mods for me but I wondered what you guys had done and what you found enhanced the car the most.
I have 2010 A5 Sline Special edition 2.0tdi.
It has MMI 2G High with HDD NAV.
Any help or suggestions will be much appreciated.
#415 ·
Found it
Click "56-Radio"
Click "Coding 07"
Click "Long Coding Helper"
TAB to "Byte 8" or click it
Check "Bit 6: TPMS Settings Active
Close "Long Coding Helper" Window
Click "Do It!"
#416 ·
I think it's about time I updated the OP! Seems to have been neglected for a while with all these extra posts.
#418 · (Edited)
What is ADS?
I just done the mirror dipping on the passenger side. Can this be done on the drivers too and can you set how far it dips as at the moment its not a lot?
Also activated the TPMS and the option is up but greyed out, does this mean I cant use it?? Or do you have to activate it in someway??
#420 ·
What is ADS?
Audi Drive Select - you chance the characteristics of the car. Ie put it into comfort, dynamic mode etc.
No, the dipping mirror is only available on the passenger side. Your right, it doesn't did far enough for me. I don't use it for that reason.
#421 ·
One of the coding options it says on your list as you select 2 for this is something to do with memory position or something? I thought this might have something to do with it as it work with this 2nd option not ticked also
#422 ·
Not sure what you mean without looking at it. I'm 99.9% sure you can't do move any more due to limitations of the non folding mirrors. However..... I'm happy to be proved wrong!
#423 ·
Hmm, it actually says to tick Bit 3 and change Bit 2 to 1 but both mine are only tick options, I don't have the ability to select 1 but one of them, Bit 2 or 3 says something about memory position.
I'll be playing again later so will have a gander and a fiddle :)
Any idea on the TPMS at all?
Massive thanks for all this btw :)
#424 ·
Does anybody know Audi's stance on doing things like enabling ADS while the car is still under an approved used style warranty?
I presume they will try to push for invalidating the warranty if they could see it was done?
#426 ·
they didnt care about mine and i even warned them over the error before it went in. its an Audi feature that is on the car they shouldnt have a leg to stand on unlike having a remap done. i kept quiet about that one
#427 ·
No my question.. the Average MPG
is there a way to change how this increments?? eg my car will go 46.4 mpg to 47.0 then 47.7
its annoys the hell out of me. any one know if i can force it to increments of 0.1 like real time data?
#428 ·
Figured the TPMS, it won't work on my module as I have the 1AS.
Now another question, I have the sensors on my door handle for the keyless entry but I don't think I have ever tried if I have keyless entry? I don't think I do as Im sure I have seen the option disabled in the VCDS.
Can I simply turn these on and see if it works?
#429 ·
You only have keyless entry of you car has advanced key. You'll know if you have advanced key if you have a start/stop button
#431 ·
Ah, I do not have start/stop button.
So then I think Im done with the Vagcom mods?
Not sure what some are tbh like the Aux heating. Is that have the ac on while car still locked or something like that?
#430 ·
You will have the rectangular groove in your handle regardless
#432 ·
Yes, you can turn the blowers on at set times. So in summer of you know you leave work at 5pm you can have the car blow the hot air out from 4.50pm. It doesn't use the AC as the engine isn't on.
#434 · (Edited)
I don't think it is on the chorus/symphony. It wasn't something I activated on my B8 A4 with that stereo and I'm sure I would have if I could have.
#435 ·
ODIS To carry out the coding mods
Hi Guys, Does anybody know if you can carry out these mods on ODIS software and not VAGCOM and if so how? Thanks
#436 ·
If you have access to ODIS then changing the parameters will be a similar process. The steps however will not be the same.
#437 ·
Does anyone know if there is a code that enables the car to do the windows up automatically if the rain sensor senses rain?
A friend mentioned it to me but didn't know if it worked or where he heard it from.
#441 ·
S5 2010 have no 07 control head, it's for MMI2G till 09/2008. If You have MMI 3G it's in address 5F, or for Symphony it's in 56.
#440 ·
Radio preset list
Everytime you start a car again, the scroll-button on the steering wheel lets you scroll through ALL available radio stations (listed by frequency). You have to look at the dashboard, scroll all the way up, to "Memory list", click on that, and only then you will be scrolling through your favorites, i.e. preset channels. Well, this is really annoying as it distracts you attention for quite some time (if you stop scrolling up, the selector is back to current line in 1 sec.) - to the extent that this scroll-button became unusable for me. I only use it for phone options.
Is there a way to tell MMI that I want to always start in the preset radio channels list???
I.e. Default list = Memory list.
2014 Audi Q7
#442 ·
2014 Audi Q7
No, there isn't.
#443 ·
Does anyone know if it's possible to get the volume of radio/CD to lower when you put car in reverse? Is this available to unlock on a 58 plate coupe?
#444 ·
I'm sure that you do this through the cars menu.
