1 - 20 of 706 Posts
I've been adding mods today and realised that we have no comprehensive list of codes on this forum.
So here is the full list (as of right now), they have been checked however I hold no responsibility if you mess up!
I'll keep adding them as new ones are found
Please post any others I've missed or any mistakes and I'll add them to the list.
These have been tested completely on pre-facelift. Most should work on a facelift car however there are a couple that won't or need to be completed a different way.
The only mods that work on the Chorus, Concert or Symphony stereo are the ones that don't use hidden menu options. The hidden menu is not accessible from chorus or symphony stereos.
No idea how to use VCDS? Here is a PDF to get you started -
Guide Here
VCDS for dummies more appropriate?!!
VCDS For Dummies Here!!
More questions about VCDS? Here is a page to answer those questions -
FAQ Here
Most importantly... Enjoy turning on the features Audi didn't want you to have!
________________________________________
The A5OC List
Enable Hidden menu in MMI
Adjust bluetooth microphone sensitivity
Adjust Back-up Camera Picture
Change MMI 3G splashscreen
Disable After-wipe of windscreen wipers
Disable amber corner lights
Disable amber side markers
Disable Key warning (keyless models)
Disable LED 'wink' on turn signal - pre-facelift
Disable LED 'wink' on turn signal - facelift
Dim LED 'wink' on turn signal
Disable bulb error message with LED reverse lights installed
Disable "Lights are on" warning
Disable NAV & Phone warning messages while entering data at speed
Disable Seatbelt Chime
Disable soundaktuator (speaker on face lifts)
Enable Adaptive brake lights
Enable Ambient Interior Lighting Control
Enable Optic rear parking for cars without front parking sensors
Enable Automatic Gear selection shown in DIS
Enable Automatic Hill Hold Assist 'lite'
Enable Auxiliary ventilation
Enable Battery meter *does not appear to work on facelift cars with MMI 3G+ HDD Navigation*
Enable DIS with Efficiency Program
Enable Double Disarm Beep
Enable Drivers Memory Seat
Enable DRL Selectable via MMI
Enable DRL
Enable Audi Drive Select without the buttons
Enable Euro parking lights that turn on signal at night
Enable interior lighting option
Enable fog lamp to come on for the same side as that turn signal
Enable Front Turn Signals as Parking lights
Enable Gauge Test/Needle Sweep
Enable Horn confirmation on locking
Enable Import CDs to MMI's HD
Enable Independent Fogs control with high beams
Enable Lap Timer
Enable LEDs remain bright for parking lights
Enable Rear Tail Lights on with DRLs
Enable Release Parking Brake without putting foot on Brake
Enable Release Parking Brake without putting seatbelt
Enable Remote Operation windows&sunroof
Enable Reverse mirror tilt
Enable Speed on chorus, concert or symphony display
Enable ‘Tourist’ Mode – Headlight Convertor (MMI 2G)
Enable TPMS (Tyre Pressure Monitoring System)
Enable Video in Motion on MMI
Set Audi parking system - Switch OFF Speed
Set Custom ADS settings
Set Headlight washer - cycles
Set Headlight washer - duration
Adjust Consumption in DIS
Adjust LED Brightness
Change Language
Activate SDS for cabriolet
Change fuel tank characteristics
To increase radio play time after car is turned off
Audi A4/S4/A5/S5 B8
VCDS (VAG-COM) codes
Enable Hidden menu in MMI 3G
[5F - Information Electr.]
[Adaptation - 10] -> Channel 6
change 0 to 1
To access the hidden menu, hold down car and setup together for 5 seconds
Use this hidden menu at your own risk.
Enable Hidden menu in MMI 2G
[07 - Control Head]
[Adaptation - 10] -> Channel 8 -> Change 0 to 1
Use this hidden menu at your own risk. Caution: Keep away from the "Bootloader"
Hidden menu
Diagnose
Settings
Mic sensiblity - choose -6db/0db/+6db
[6C-Back-up Cam.] [Security Access - 16] (enter security code 22351)
[Adaptation - 10]
Channel 10 (Brightness)
Default: 50 (Set between 1-100)
Channel 11 (Contrast)
Channel 12 (Saturation)
Channel 13 (Temperature)
Change MMI 3G splashscreen...
Enable through the "hidden menu":
- navigate to 'car/carcodingvehicle'
- choose the model of choice in 'configuration line'
- select 'Update Splashscreen'
- restart MMI
[09 – Cent. Elect.] [Coding - 07] -> [Dropdown] -> "x ** 8K1 955 119 ** WWS xxxx" -> Long Coding Helper -> Byte 1
Bit 3 - Remove check mark (1 = active)
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 10
Submodule 0
Bit 3 - Set to 0 to disable amber side markers (U.S. vehicles)
[46 – Central Conv.] [Coding - 07] -> Long Coding Helper -> Byte 9
Bit 7 set to 0 (Uncheck)
Disable LED 'wink' on turn signal - pre facelift
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 3
Bit 2 - LEDs remain at full brightness with parking lights (1 = active)
Bit 7 - Turn off LED-strip DRLs with indicators (1 = active)
09 – Cent. Elect.] [Security Access - 16] (enter security code. One of the default codes is- 20113)
[Adaptation - 10] -> Channel 3 (Heading Wink Brightness)
Default Value is 26, Setting value to 88 (Makes it identical to normal brightness)
Dim LED wink on turn signal for US cars
Instead of complete wink off, there is another mod that comes as stock in Europe. There is an LED dim instead of wink.
Starting with factory setting:
Central Electronics 09
Coding 07
Long Code helper
Byte 02 - Check bit 6 (Side Marker as DRL)
If you have already eliminated the winking, the you will need to go to Byte 03 and undo the modification. In other words, the winking DRL options (Bit 7) will need to remain checked/on as it was in the factory setting.
http://www.a5oc.com/forums/a5-performance-mods/27314-cree-led-reverse-lights.html#post296914
Disable "Lights are on" Warning
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 5
Bit 3 - Set to 0 to disable "lights are on" warning when you open the door.
[5F - Information Electr.] -> Adaptation -> Set channel 2 & 3 to 250
[17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 0
Bit 2-4 – Seat Belt Warning
To mute the Soundaktuator
A9 Structure Borne Sound
Adaptation 10
At Channel drop down choose "Volume of structure borne noise actuator" (only choice)
Enter a value in the proper box (0% = mute )
[46 - Comfort System] [Coding - 07] -> Long Coding Helper -> Byte 8
Bit 0 – Emergency Brake Flashing via Turn Lights active (1 = active)
Bit 1 – Emergency Brake Flashing via Brake Lights active (1 = active)
Enable Optical rear parking for cars without front parking sensors
[10 - Park/Steer Assist] [16 - Security Access - 71679] do it [07 - Coding] Byte 0 - Bit 4 change 0 to 1
[02 – Auto Trans] [Adaptation – 10]
Select “Single Gear Display” from top channel drop down menu
Select “D on/S on” from New value drop down menu
Enable Automatic Hill Hold Assist ‘lite’*only works on certain abs modules - see below link*
[03 - ABS brakes][Security Access - 16] (Enter code presented by program)
[Coding – 07] -> Long Coding Helper -> Byte 1
Bit 6 set to 1 to enable hill hold assist.
http://www.audienthusiasts.com/VagComABS.html
[5F - Information Electr.] [Coding - 07] -> Long Coding Helper -> Byte 6
Bit 1 – Set to 1
[Hidden menu] [car] [cardevicelist] [Auxiliary heating] Enable
[08 - Auto HVAC] [Coding - 07] -> Long Coding Helper -> Byte 1
Bit 3 – Set to 1
Bit 4 – Set to 1
For MMI equipped cars
[Hidden menu] [car] [cardevextdevicelist] [Battery] Enable
[Hidden menu] [car] [carmenuoperation] [Battery] Set to 5
Reset MMI
or
[56 - Radio] -> Adaption -> Channel 39, add 16 to your value
For symphony, Chorus and Concert
Select module 56 - Radio
Select “Adaptation – 10
Select channel 39
Add 16 to the present value
"test"
"save"
“Done, Go Back” and "Close Controller
Enable DIS with Efficiency Program for MY2010+ (Not a complete Program without the Start/Stop System)
[17 - Instruments] [Adaptation - 10] -> Channel 77
change 0 to 255
[46 - Central Conv.] [Adaptation - 10] -> Channel 63
Add 4
ensure Module 46, Byte 1, Bit 2 is ticked. This activates the alarm audible notification option
36: Seat Mem - 07 Coding - Long Coding Helper - change Byte 2, bit 0, to 1
Seat memory will be there however greyed out in MMI
Press and hold down unlock button on key fob for 5 seconds for the windows to come down
Press and hold down lock button on key fob for 5 seconds for the windows to go back up
In MMI, Seat Adjustment you are now able to find Driver's seat, you can set Key memory on/off. Set it "on" for both keys separately.
[09 – Cent. Elect.] -> [Coding – 07] -> Long Coding Helper -> Byte 3
Bit 5 set to 1
Enable DRL
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 2
Bit 1 = DRL via Front Side markers
Bit 2 = DRL via High Beams
Bit 3 = DRL via Fogs
Bit 4 = DRL via LEDs
Bit 5 = DRL via Parking Lights
Bit 6 = DRL via Side markers
Bit 7 = DRL via Tail lights
By far the best guide is here - http://www.audienthusiasts.com/Project_ADS.html
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 9
Bit 0 - Set to 1
Enable interior lighting option for pre-facelift
MMI Basic (Symphony/Concert radio) - (NON-MMI - 2G/3G):
Code:
[56 - Radio]
[Coding - 07] -> Long Coding Helper -> Byte 8 Bit 7 - Interior Light Settings active - (1 = active)
MMI high (2G):
Code: Enable the Interior lighting (extended) MMI item:
[07 - Control Head]
[Adaptation - 10] -> Channel 1 add 2 to the existing value
MMI high (2G hidden menu as alternative)
If you choose to use the 2G hidden menu you will find the setting using the following:
DIAG SETTINGS -> APK 0x01, 0x0B, 0x0C -> Interior lighting (extended)
MMI 3G and MMI3G+
This can only be activated through hidden menu
Enter hidden menu - choose car - choose carmenuoperation - select interior light - set to 5 to allow adjustment whist moving - press return - select cardevicelist - choose interior light and press to fill box in - press return
*at this point 3G owners do step below, 3G+ go to (3G+ only) below
(3G only) Reset MMI (press setup, scroll wheel and top right button next to scroll wheel at the same time)
(3G only) Option will show in MMI
(3G only) [09 – Cent. Elect.]
[Coding - 07] - Long Coding Helper -Byte 16 Bit 6 - Set this bit manually to 1
(3G+ only)
Facelift needs an extra setting to activate the option.
Hidden Menu > car > carbusassignment > Interior Light > change from 9 to 1.
Reset MMI
Enable interior lighting for facelift cars
[09 – Cent. Elect.]
[Coding - 07] -> [Long Coding Helper] -> Byte 16
Bit 6 - Interior/Ambience Lighting Adaptation active
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 4
Bit 0 - Check the box or change :Bit 0 set to 1
Bit 0- Check the box or change :Bit 0 to 1
Once the change has been made you can enable the front turn signals as DRL's by making the following change:
Bit 6 - Check the box or change :Bit 0 set to 1
[17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 1
Bit 0 - Check the box for "Gauge Test/Needle Sweep active"
Enable Headlights on all the time
Bit 5 - Check the box or change (Bit 5 Set to 1)
[46 – Cent. Convenience.] [Coding - 07] -> Long Coding Helper -> Byte 1
Bit 2 - Check the box or change (Bit 2 Set to 1)
[Hidden menu]
Main/Diagnose/Settings
Import Media
Set to 4 of 4 "Copy/Ripping"
Bit 1 – (Front) Uncheck the box or change :Bit 1 to 0
Bit 2 – (Rear) Uncheck the box or change :Bit 2 to 0
Enable Lap Timer
Bit 3 - Check the box for "Lap Timer active"
Enable Remote Operation Windows and Sunroof
[46 - Cent. Conv.] [Coding - 07] -> [Long Coding Helper] Byte 2
Bit 2 - Set to 1
Bit 7 - DRL's via Tail Lets Active (1 = Active)
[53 - Parking Brake][Security Access - 16] (Enter code presented by program)
[Adaptation - 10] -> Channel 4 Set to 0
[Adaptation - 10] -> Channel 7 Set to 0
[52 Door Elect, Pass.] -> [Coding - 07] -> [Long Coding Helper] -> Byte 4
Bit 3 and Bit 2 set to 1
Module 56 - Radio
Adaptation - 10
Channel 2 --> change 0 into 1 (driving school mode active).
New menu item: Under Radio Setup "ON/OFF" driving school mode.
[09-Central Elect]
[Coding – 07]
[Long Coding Helper] - Byte 4, Bit 6 = 1
Enables the 'connection' between Cent. Elect and the Headlight Convertor MMI menu item
[55-Xenon Range]
[Adaptation – 10]
[Channel 10] - 0 = Disable 1 = Enable
Press ‘Test’ and then ‘Save’
Enables the Headlight Convertor MMI item under the CAR button.
Restart MMI to see changes.
Enable TPMS
* only works with certain ABS modules - see below link *
Enable Video in motion on MMI
[5F - Information Electr.] [Advanced ID - 1A] Note 1st Serial number
[Security Access] Enter Digits 6, 13, 10, 14, 11 of the 1st Serial number
[Adaptation - 10] -> Channel 48
Set to 255
Reset MMI
[10 - Park/Steer Assist] [Adaptation - 10] -> Channel 23
Set to 20 (max value in km/h)
Set ADS to specific preset Comfort, Auto, Dynamic or Individual
[09 – Cent. Elect.][Security Access - 16]
Set to 01 - Comfort, 02 - Auto, 03 - Dynamic or 04 - Individual
[Adaptation - 10] -> Channel 64
[Adaptation - 10] -> Channel 65
[Adaptation - 10] -> Channel 66
*Note all four channels needs to be set to the same value.
Set Headlight washer - Duration
[09 – Cent. Elect.]
[Security Access - 16] [Adaptation - 10] -> Channel 6
change to e.g. 500
Set Headlight washer - Cycles
[09 – Cent. Elect.]
[Security Access - 16] [Adaptation - 10] -> Channel 26
change to e.g. 10
[17 - Instruments]
change 100 to xxx (see samples below)
Sample 1 - Calculation based on volume per distance (e.g. l/100km):
DIS: 9,3 l/100 km.
Real: 9,8 l/100 km. (100 * 9,8 / 9,3 = 105,38)
Channel 3 will be changed from 100 to 105
Sample 2 - Calculation based on distance per volume (e.g. MPG):
DIS: 23 MPG.
Real: 24 MPG. (100 * 23 / 24 = 95,83)
Channel 3 will be changed from 100 to 96
Adjust LED brightness
[09 – Cent. Elect.] [Security Access - 16] (enter security code. One of the default codes is- 20113)
[Adaptation - 10] -> Channel 03
Set between 5 and 100 (5 being lowest and 100 brightest)
Select language in DIS:
17 - Instruments
Byte 8 -> Bit 0-4 - ->
Select the language.
Activate SDS for cabriolet:
5F–Information Electr.
Change Byte 15 – Bit 0 to 1
Change Byte 16 – Bit 0 to 0
Change fuel-tank charisterics:
17 - Instruments
Adaption - change channels 30 and 33
To increase radio play time after car is turned off:
In the Hidden Menu:
MMI 2G:
"MMI->SETTINGS->Standby Timer" - will allow you to hear e.g. Radio or CD longer before MMI shutdown (if ignition is OFF) - default 10 min. and the max. is 60 min.
MMI 3G:
From the main screen select 'onofftimer', set 'Standby delay'. The maximum value is 30 minutes
Administrator
comprehensive list :)
but there is always more:
17 - Instruments
17 - Instruments
17 - Instruments
17 - Instruments
Please add any I've missed off, I want it to be as comprehensive as possible. If you post them like this I'll add them to the first post. :thumbsup:
17 - Instruments
Not sure what a charisteric is or why I would want to change it :) ... what does this mod actually do ?
Those last couple you posted are already in the list.
Discussion Starter · #11 ·
You beat me to it!
I've added all the ones you fellas have listed, thanks for the help! Keep going (as long as they aren't already on the list! Haha)
Come on guys I know they're in the list already :thumbsup:
The links I've posted add extra bits to the coding that you've posted.
The TPMS coding you've posted doesn't show you how to enable the TPMS MMI item, the coding in the link does.
The MMI hidden menu link I've posted shows you how to enable it in both 2G and 3G MMI versions.
Also you missed a bit off the bottom of the 'Enable Audi Drive Select without the buttons' coding.
In MMI hidden menu go to Diag settings, Car menus maske, check 'Charisma' box and go down to Accept changes. Whilst still in the hidden menu go to Diag settings, APK 0x01, 0x0B, 0x0C, check 'Charisma' box and go down to Accept changes.
:cheers:
Ahh ok, sorry, didn't follow your links, just read the descriptions.
Discussion Starter · #14 · (Edited)
I'm trying to ensure the codings are all on this page rather than links sending people of all over the place, some like the TPMS is just too long to condense effectively do I've added a link. f there are any mistakes could you post the mistake here so that I can add it to the list above.
Thanks!
One (more or less) central database is the desired ending!
Administrator
if you get a message to re-fuel and you check how many miles the car thinks you have left, you can calculate how many liters of fuel you have left in the tank.
this usually does not come out right.
there is always more left over than you think.
with these channels you can adjust the charisteric of the float-element in the tank.
this way, you can come closer to the real left-over fuel / miles.
Any chance of getting the coding required for the LED facelift added to this list (if anyone has them)? :)
S5mafia just to say thanks for doing this. As a newbie to VAGCom I've spent hours looking all over for the various mods. I wished at the time that there would be a central repository for all mods VAGCom wise, so thanks again
Discussion Starter · #18 ·
Your welcome. I'll just need to keep it up to date now!
Discussion Starter · #19 ·
I'll certainly add it however I have no way of testing with my lowly pre-facelift!
1 - 20 of 706 Posts
