421 - 440 of 724 Posts
One of the coding options it says on your list as you select 2 for this is something to do with memory position or something? I thought this might have something to do with it as it work with this 2nd option not ticked also
Discussion starter · #422 ·
Not sure what you mean without looking at it. I'm 99.9% sure you can't do move any more due to limitations of the non folding mirrors. However..... I'm happy to be proved wrong!
Hmm, it actually says to tick Bit 3 and change Bit 2 to 1 but both mine are only tick options, I don't have the ability to select 1 but one of them, Bit 2 or 3 says something about memory position.
I'll be playing again later so will have a gander and a fiddle :)
Any idea on the TPMS at all?
Massive thanks for all this btw :)
Does anybody know Audi's stance on doing things like enabling ADS while the car is still under an approved used style warranty?
I presume they will try to push for invalidating the warranty if they could see it was done?
Can I activate ADS on a basic symphony MMI non 2G or 3G?
Yes but you will get an Error for Charisma but it doesnt put CELL on the dash
you wont be able to change the setting from the MMI menu though you just have to force the car to Dynamic
No, your not able to do this I'm afraid
yes you can
they didnt care about mine and i even warned them over the error before it went in. its an Audi feature that is on the car they shouldnt have a leg to stand on unlike having a remap done. i kept quiet about that one
No my question.. the Average MPG
is there a way to change how this increments?? eg my car will go 46.4 mpg to 47.0 then 47.7
its annoys the hell out of me. any one know if i can force it to increments of 0.1 like real time data?
Figured the TPMS, it won't work on my module as I have the 1AS.
Now another question, I have the sensors on my door handle for the keyless entry but I don't think I have ever tried if I have keyless entry? I don't think I do as Im sure I have seen the option disabled in the VCDS.
Can I simply turn these on and see if it works?
Discussion starter · #429 ·
You only have keyless entry of you car has advanced key. You'll know if you have advanced key if you have a start/stop button
Discussion starter · #430 ·
You will have the rectangular groove in your handle regardless
Ah, I do not have start/stop button.
So then I think Im done with the Vagcom mods?
Not sure what some are tbh like the Aux heating. Is that have the ac on while car still locked or something like that?
Discussion starter · #432 ·
Yes, you can turn the blowers on at set times. So in summer of you know you leave work at 5pm you can have the car blow the hot air out from 4.50pm. It doesn't use the AC as the engine isn't on.
how do you adjust the time and is it do able on a non MMI car?
Discussion starter · #434 · (Edited)
I don't think it is on the chorus/symphony. It wasn't something I activated on my B8 A4 with that stereo and I'm sure I would have if I could have.
ODIS To carry out the coding mods
Hi Guys, Does anybody know if you can carry out these mods on ODIS software and not VAGCOM and if so how? Thanks
Discussion starter · #436 ·
If you have access to ODIS then changing the parameters will be a similar process. The steps however will not be the same.
Does anyone know if there is a code that enables the car to do the windows up automatically if the rain sensor senses rain?
A friend mentioned it to me but didn't know if it worked or where he heard it from.
This is not an available option / modification.
Radio preset list
Everytime you start a car again, the scroll-button on the steering wheel lets you scroll through ALL available radio stations (listed by frequency). You have to look at the dashboard, scroll all the way up, to "Memory list", click on that, and only then you will be scrolling through your favorites, i.e. preset channels. Well, this is really annoying as it distracts you attention for quite some time (if you stop scrolling up, the selector is back to current line in 1 sec.) - to the extent that this scroll-button became unusable for me. I only use it for phone options.
Is there a way to tell MMI that I want to always start in the preset radio channels list???
I.e. Default list = Memory list.
2014 Audi Q7
