721 - 724 of 724 Posts
Is there any type of mod through VCDS/ Vagcom that turns off the suspension dampener checks on electronic dampeners?
I have KW Dampener Cancellers, but I'm getting a fault on the 'Rear Right' after a particularly cold (for the UK) winter. I replaced the module with another one of KW Dampener Cancellers, but the fault is still there. I don't want to have to buy another of the modules at £100+ a piece so a software fix would be much, much easier!
Thanks all
Hello guys, I have an A5 2014 Sportback and changed my main front light bulb to LED white, so it looks better. But my parking lights which are still yellow are always on with every setting. I tried to turn off DRL in the menu but that did not help. I guess I will need to disable them manually via any code? I have an ODBeleven diagnostic at home and I tried to play with these...
Enable DRL
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 2
Bit 1 = DRL via Front Side markers
Bit 2 = DRL via High Beams
Bit 3 = DRL via Fogs
Bit 4 = DRL via LEDs
Bit 5 = DRL via Parking Lights
Bit 6 = DRL via Side markers
Bit 7 = DRL via Tail lights
But it did not work for my problem. Is possible that my car cannot do it or there should be a way to do everything? Does anyone know how to disable them or turn them low at least?
