361 - 380 of 724 Posts
I followed the instructions at the beginning of this thread and it worked first time. I didn't even have to enable it on the mmi.
Enable Optical rear parking for cars without front parking sensors
[10 - Park/Steer Assist] [16 - Security Access - 71679] do it [07 - Coding] Byte 0 - Bit 4 change 0 to 1
I have a 2010 model so yours should work too. I haven't updated my software yet from 2010 so it can't be an update problem as yours is 2011. Are these the instructions you followed?
Indeed they are the instructions.
However when the unit was installed it came up as a 2008 version but the nav has been updated to 2013...not that the nav should affect it
So tgif and had a wee tinkle with my vagcom cable and that list is the mutts nuts, thank you very much and they're a few man hugs that I need to give out in the form of beer tokens.
The ones I appreciate the most are central locking beep ( so I can show off in the lidl car park, obviously) and I'm itching to try out the ADS as I don't have it installed but have read it makes the steering heavier, which I really miss from my Mazda RX8.
MERRY FRIDAY ?
Hello,
I'm looking for your help as I have a '09 S5 and I tried to swap my tail lights to a facelift ones, but after connecting the Kufatec dongle to make the changes, the result was not what I expected, the city lights do not come up correctly and are all messed up. I returned my previous lights and now I logs the reverse light and all inner lights are gone.
I tried to post pictures but it doesn't allow me. But you can check it out at this link
http://www.audizine.com/forum/showt...owthread.php/603551-HELP-Led-Tail-Light-Install-and-Euro-Spec-Head-Lights/page3
Is there someone that can help me to code it correctly? Maybe someone local at DFW area? I can pay for the service if needed just want yo have it done correct.
Thanks for your help and support
a5 headlight retrofit
Seems to not work on UK cars.
Hi mate (S5mafia), I live not far from Manchester and need some help with headlights retrofit conversion. Is there any chance to have an email or contact number please?If possible I would like to pop down to you with the car?
I was looking to access the "hidden menu" in my 2015 S5, but according to the instructions I should press the CAR and SETUP buttons together. As you can see in the photo below, I have no SETUP button. Any ideas?
on a Face-Lift it is Car and Menu :)
1st you press Car and immediately after you press Menu.
now hold them both down, untill the hidden menu appears.
Hey, if anyone wants any of these mods near Lincoln, Boston, or Doncaster get in touch and I have the equipment and software to do them.... Give me an idea what you want in advance tho :) Enjoy.
Hi. Is there any way to code security options to be on "off" as a default. Im talking about these two buttons on driver doors. I got this habit from many years to switch these off due to car being secure in 90% of its locations anyway (work and own garage with cctv and move activated sensors). Each time when I leaving my car I have this habit to deactivate them
why would you want to deactivate them though isnt that the Alarm and tilt sensor?
well good question and answer is: simply that my OCD i would say. Started many year ago when I was leaving car locked in garage for over two weeks and was deactivated this to preserve battery and and stay like that.
I've just done most mods I wanted using the info here, thanks!
I am struggling to get hidden menu with mmi 3G+, I have been pressing car & menu with no joy and have followed instructions to enable...
Any advice would be welcome!
Have you activated it with VCDS?
Enable Hidden menu in MMI 3G
[5F - Information Electr.]
[Adaptation - 10] -> Channel 6
change 0 to 1
To access the hidden menu, hold down car and setup together for 5 seconds
Use this hidden menu at your own risk.
It can take a few tries before it works! :thumbsup:
Yep I've activated it, will try a few more times then! Just trying to activate on our A4 with 2G MMI
Yay! After a few attempts it's worked...
One last question, can dynamic steering be turned on?
