81 - 93 of 93 Posts
If the pins are in use splice onto them. Re your errors, you may have the RVC CAN polarity the wrong way around.
I used the CAN connector in the front of the car. I can’t confirm the pins you are using. @dativus may be able to confirm from his installation.
Discussion starter · #90 · (Edited)
@Bluemage
Yes, these pins 19 and 20 are occupied by 2 cables in the T32c cube in the BCM2 comfort module.
I bought a bundle in which the cables were marked with numbers which should be connected to what. So these are 2 cables that need to be connected to the T32c connector of the BCM2 comfort module. In my case, I soldered one cable to the orange-green cable from pin19 and the other one to the orange-brown cable from pin20 of the T32c connector. I insulated it and that's it.
In this case, the cables were well numbered. Not like in post no.73 and 74 :
https://www.a5oc.com/threads/revers...ng-camera-in-a4-b8-lift-a5-q5-original-and-replacement-from-china.180419/page-4
@DrGER , @JohnS4
Sorry for late answer.
Camera working now :)
My error was simply, when i was play with wires, i unplug one plug from comfort module and then i didn't realised that interior lights came up an discharge battery. After charge battery everything came back to normal apart power steering lose position . Reset it and everything now is ok. Now i'm fighting with google earth .
Thank you for help @DrGER ,@JohnS4 ,@dativus
81 - 93 of 93 Posts
