Status
Not open for further replies.
881 - 900 of 3,801 Posts
Can you update firmware whilst driving? I noticed someone say it takes a total of 4hrs to update all 4 firmware and maps.
Does anyone know how long it takes per firmware and what's the consequences of cutting out during an update?
It depends on SD card speed. When I did mine it took around one hour.
Firmware update from lower versions to K0900 takes about 35min with no name sd card. After that update to K0942 took 15 minutes only. Map update to 6.22.4 and later to 6.24.2 takes same time about 1.5 hours with SD Card Sandisk Extreme class 10 32gb
Save
Hi Guys,
I read lot of comments but I didn't found exact description about the upgrade process.
I have MMI 3GP with K900 firmware and 6.22.4 map. If I'll like upgrade to k942 and 6.24.2 what I have to do?
I think the followings
1, upgrade the firmware 900 to 942
2, reactivated the existing 6.22.4 map
3 upgade the map file
am I right?
or what happen if now I upgrade only the map file (because it's simply) and later the firmware?
Anybody have experience about it?
If I'm wrong pls somebody summarizes the process of the update.
lot of thx
zs
broken MMI 3GP+
Hi guys, i have read all our posts and could not see if anyone ever had the problem i have now. Please please help..
I have Audi A7 with 3GP+ mmi with Bang And Olufsen sound system, Sim card google earth etc..
Original MMI version was: HN+R_US_AU_P0409
Car is from US, so i tried to update the MMI with EU version software and maps. I copied all the files *unfortunately not from this forum, but i have got them earlier* and tried to update like normal EU car. The SD card was not even seen. And error showed up: REGION CONFLICT OCCURRED! Main UNIT USA. Release info region: EUROPE ROW" So managed to find in forum's that i need to tick the box in green menu within swdl "ignore region and varian" tab. So i did that as well as "user defined mode".
So once that was done, my SD car was finally accepted and the update started to run (k900 one)... (BOSE option could not be found, i cant see anything to untick for my sound system...so i have left as it is) It took about 1 hour till the first error came up: KBD_FC7:0. i had only two options like "cancel" and "retry". Retry did not helped so i hit cancel.. After that update went further for about 40min. it rebooted several times, all as per manual and normal update. However once it ended i never came u to the point where it shows "abort documentation" I think the screen was there, but those two last options were just invisible. I could use the shift know but there were no text!! Super strange...So...i waited for another 10min and the screen view did not changed. It alredy allowed me to use my shift know, the screen lookt exact like the one i was waiting for just without the otion to abort documentation. I rebooted MMI manualy then. And.. I scred up.
My MMI looks like somone got deleted all the letters and numbers. All options are invisible, whichever knob i press i get empty screens. I do hear the radio playing but nothing else. I have some pictures made, but cant see where i could atatch them here..
@congo, i see you have a lot of experience here. Please PLEASE...help :) I have read that i it possible to re-enable the emergency update from the green menu, since K900 update disabled that? Can someone guide me how to do it on my MMI? It is disabled in fact. Green menu works fine, however Engineer menu is broken as it is not usable now...
P.s. Just tried the Emergency enable script - not working..
What options do i have???
pictures of my current views. All screens look the same. I can click it and i see that it does something, but as there are no letters i have no clue what am i doing inside, since i cant see the options. Engineering menu is stuck - i can enter but no options or letters...
Discussion starter · #892 ·
@SKL - what you did is region conversion .. and that is not only software update. It's not covered by this manual.
I can fix that but not remotely, i will need the unit on the table. It's up to you.
Where are you from? It's not on the profile.
p.s. Emergency script is working as people have used it many times ... so it's something in your end.
I just did exactly this, updated the maps (I used a 64GB FAT32 formatted SD card), then the next day decided to do the firmware as well. Maps stopped working at that point and this morning I used the activator and that's it, all working and all updated :)
Reactions: zspatak
Save
@congo
Thanks for so quick answer. This is tricky... i am based in Lithuania. I did however managed now to add back the emergency update... shall i run the update again?
Which activator did you use and over which version of the maps?
Sent from my EVA-L09 using Tapatalk
Thread title updated to reflect 2017 map availability.
@congo if you want to open a new thread I'm happy to close this one down and post a link to the 2017 one to try and keep the thread length sensible?
Just need 3G High activator now so I can do my car lol
Adrian
Save
Hello
Audi S5 year 2012 MMI 3G+ , I already have SIM card with 3G and Google earth via audi connect , but no service to update maps via audi connect
My Config
HN+_EU_AU3G_P0513
Maps
8R0060884AH ECE 5.13.8
I have to first update to this FW : HN+_EU_AU3G_K0612 and then to this one HN+_EU_AU3G_K0900 or directly to HN+_EU_AU3G_K0946 ?
Secondly I cant update maps to 6.22.4 2016 or to 6.22.4 2017 ?
The activator work on 6.22.4 2016 I presume ?
Il dont understand if there is something to pay You says p.p.p.s. There are paid activation too ? What does it mean , what il the difference between this activator 8R0 060 884 DF – Activator ?
Thank you
Save
Discussion starter · #900 ·
Adrian
I would like to continue in this one if that's ok as there is a lot of info here :)
But if i have to i will open a new one.
You can change the title and replace 6.22.4 with 6.24.2
About 3G High, yes we need only the FSC :)
Status
