Status
Not open for further replies.
861 - 880 of 3,801 Posts
Hi Guys,
This post is massive, I assume my current MMI and Maps are out of date (See image).
Does anyone have the link to the latest maps and update? This says 2016 but I'm sure i read a 2017 in a few posts.
My car is a 2011 S5 MMI 3G HDD - Guessing the down load will come with a readme?
Check first post of this topic. All links are there mate.
I've just read through that.... still confused by which one i need?
Audi A4-A5-Q5-Q7
 8R0 906 961 EB – HN+_EU_AU3G_K0900 (A4/A5/Q5/Q7) SVM: 3GPEU900AU3G
[Modified] [Untouched]
 8R0 906 961 FC – HN+_EU_AU3G_K0942 (A4/A5/Q5/Q7) SVM: 3GPEU942AU3G
Got this from the Manual but whats the difference?
Same with the Maps?
Map & activator:
8R0 051 884 DF – 6.22.4 2016 MMI 3G High/Plus Europe 2016 [Link on cloud.mail.ru || Link on Mega (use 7z/7zip to open the files)]
8R0 060 884 DF – Activator [Link on cloud.mail.ru || Link on Mega]
8R0 051 884 ED - 6.24.2 2017 MMI 3G High/Plus Europe 2016 [Link on Mega (use 7z/7zip to open the files)]
Am I right that if i a MMI 3G High?
Check which one you do have. Download the manual and go to settings and check the version you are currently on. Take a picture and post it here.
Hi Guys,
It has a high 3G mmi, look at corresponding post
Enviado desde mi SM-G930F mediante Tapatalk
Thank you for letting me know i have a high.
My next questions is still which one of the maps & which one of the ones under A5 do i need to use? I've been looking at all of them and i can't work it out. Sorry, i'm new but i can't see anything glaringly obvious
Not the maps from this topic obviously as they are for 3gp. Go to A5 General Q&A and there is a topic with maps for MMI 3G.
Right boober - you've confused me even more now?
I thought this was everything i need for 3G High? The 3G one says basic in the other thread?
So i can only take firmware from here? Again, which one, there is several listed under A5?
MMI 3G+/3GP navigation 6.22.4 and firmware updates - currently 2016
HNav is not 3gp, 3gp is HNav+. Yours is 3g. And there is basic as well. There are 3 topics listed.
If I'm not mistaken off course as I'm am also new to this relatively, but that is the conclusion I got from reading many posts on different forums.
Here is the picture of MMI showing current software version and map versions.
I need to install GEMMI, can I download the file from first post and use it to update the firmware for my C7 A6?
I'm a little confused, hope you can help...
I've a B8.5 S4 and would like to update both firmware and maps.
In terms of firmware, I'm not sure why I would choose the K900 over the newer K942 - is the older one on the first post still for any reason?
In terms of maps, it makes sense to me to go for the 2017 version but on the first post there is only an activator for the 2016 version - does this activator work with the 2017 version? If not, where can that be found?
Thanks in advance.
P
Q. Only thing is that my Google Maps option is greyed out... any hints?
A. Reinstall the GEMMI_nav component from the K0900.
Does this mean, when I insert SD card for upgrade, I only select GEMMI to install and leave rest as N
When I had to do this, I just started the update again as normal, and only GEMMI, MapStyles and CombiStyles were selected Y, all else were automatically set to N. So I ran with that, and everything worked perfectly.
- Pud.0
Can you update firmware whilst driving? I noticed someone say it takes a total of 4hrs to update all 4 firmware and maps.
Does anyone know how long it takes per firmware and what's the consequences of cutting out during an update?
Status
