Status
Not open for further replies.
841 - 860 of 3,801 Posts
Hi guys. Your work is really appreciated. I have 3gp audi a6. I updated the firmware to 900(not modified) and applied the script to turn on green menu. Unfortunately it didn't work. I cannot access the hidden menu. I wanted to delete old maps before updating them as the manual says, that's why I need to access the green menu. Should I flash modified firmware or is there another script make to turn in green menu? Any ideas?
Can some help me on my problem?
What is activator for 6.24.2?
I have 6.17.3 on K900, A6 2014 4G.
Do I need first update to 6.22.4 then 6.24.2 or I can go direct to 6.24.2?
Do I need to make selection on AUDI_MMI3G_ECE ?
regards
Zorislav
Discussion starter · #849 ·
@zspatac
Hi I had also the same problem as you with downloading the files (limitations) and a fix IP address.
If you have the files can you upload it to me DELETED LINK
@congo
After downloading the MEGA files in 4 days (problem with quote limitation).
I extracted the files on a PC with 7zip and had 4 errors on these files:
\pkgdb\XAC\kN161EUx08_0.db
\pkgdb\XAC\XAC.conf
\pkgdb\XAC2\kN161EUx08_1.db
\pkgdb\XAC2\XAC2.conf
So I do not dare to use the extracted files with these errors to install on my audi.
I've shared on my cloud drive a part, can you upload those files?
DELETED LINK
Thanks a lot!!!
Do anyone else have the same problem ... i wonder if the archives are ok ...
MMI 3G+/3GP navigation 6.22.4 and firmware updates - currently 2016
Dont worry it is individual problem caused by bad download or copy to sd card. Archives are ok I can assure you
Save
I don't know how it's possible but while activating, the MMI did not turn off and didn't reboot.
I waited like 15 minutes and rebooted it by myself and the navigation seems to work. Did I miss anything?
// update: the map is not activated. Nothing happens. I have the wlan error. Xcode calculated on the website. No idea.
The error is:
01/01/1970 00:03:40 - activation failed, was the ignition switch on?
I checked the mac and it was ok. WLAN was switched of in the menu by default like that
Both files are on the card and the code is 25382. Anybody has any idea?
Anybody?
You dont have to calculate the Activation code just copy files from Vlasoff Activator to sd card
Save
No, download Vlasoff Activator and just copy two extracted files to sd card and insert in mmi sd slot.
Save
So I guess I was using older keldo's activator when you had to rename the file based on the MAC address. In that case I'll try the one from vlasoff. Thanks.
Hi Guys,
This post is massive, I assume my current MMI and Maps are out of date (See image).
Does anyone have the link to the latest maps and update? This says 2016 but I'm sure i read a 2017 in a few posts.
My car is a 2011 S5 MMI 3G HDD - Guessing the down load will come with a readme?
Status
