Status
Not open for further replies.
901 - 920 of 3,801 Posts
@congo I updated MMI to latest firmware and 2017 maps. Now I don't see signal strength or google and online logo at bottom. What do you reckon why is that?
Picture for attention
Hello
Audi S5 year 2012 MMI 3G+ , I already have SIM card with 3G and Google earth via audi connect , but no service to update maps via audi connect
My initial config
HN+_EU_AU3G_P0513
Maps
8R0060884AH ECE 5.13.8
So I reply to myself I do first update FW to HN+_EU_AU3G_K0612 and then to this one HN+_EU_AU3G_K0900 without any pb
Secondly I want to update maps to 6.22.4 2016 or to 6.22.4 2017 ?
I read forum and manual but understand nothing about activation ??? there is a lot of way and so many différents files for activation ? , dont know how to do , dont find explanations for 3G+
The activator is this one for 3G+ ? 8R0 060 884 DF – Activator ? it work on 6.22.4 2016 I presume ?
Thank you
Save
Hi.
Car info: C7 A6 2013 with MMI 3G+, sim card, SD slots, Bose system, Google earth, Audi connect, etc.
I updated my car last year to:
Firmware 8R0 906 961 EA – HN+R_EU_AU_K0900
Map 8R0 051 884 DF – 6.22.4 2016
Now I updated to the 2017 map and used the manual instructions:
- I had to delete the LIT catalogs to get it onto the 32 GB SD card.
- I enabled the green menu and activated the " user defined mode" in swdl.
- Deleted both database and NAV HDD partition. A bit confusing when to reboot. It should only take a 30++ seconds on both. I waited much longer, but nothing more happened.
- Installed the new MAP (had to activate all flags in catalog AUDI_MMI3G_ECE !)
- Reboot and tried to activate MAP, but seemed to be activated as nothing happened when activating script was run (6.22.4 Vlasoff maps activation).
- Google earth did not work, same problem as previous MAP installation. Had to reinstall GEMMI from FW k0900, as it said not installed in the green menu. Then it worked fine again.
Thanks a lot to Congo and to other contributors in this forum. You are great, and the the dealers suck when it comes to price on NAV update (4000 NOK/ 450 EUR).
rst.
Hey all, looking for some help. I would like to do both the maps and firmware update on a 2012 A8l (US car). I'm not sure if these files will work or not..
What I have:
SW version: HN+R_US_AU_P047
NAV db version: 8R0060884AD NAR 5.5.5
What I'd like to do is update to the 900 firmware and US 2016 or 2017 maps.
My question is...
Can I sue the software version from Page 1? HN+R_EU_AU_K0900 with US cars?
Has anyone posted a download for a US version of maps? Or point me in a direction to look?
As you can see my current version is old.. :)
TIA!
First of all: thanks a lot for all the information, manuals and files. Great job!
I am about to update my firmware. Can I do this while driving - will it interfere in some way? Or am I creating extra risks this way?
Same question for updating the map.
Cam anyone help with MMI not showing time nor sim signal strength and google logo after firmware update??
Discussion starter · #908 ·
@ksarauer - do not try to install EU soft on US unit. It need to be converted first. I can do that but i need the unit :( PM for details
@Devilz - honestly i tried to reproduce your problem but i was not able to. The clock might be hidden because it's turned off. Look at the settings menus. You can always try one more time with emergency ...
I have read Congo guide and have a few question
1 he recommend backup old FSC how do you do that ?
2 if you use modified FW is it so that you don`t need to enable green menu With script or VCDS? just put in the SD Card and use standard update ?
3 I have B O sound system do i have to do anything if i use modified FW
4 what`s the different onK0900 and K0942 ?
Discussion starter · #913 ·
1. Obsolete now ... i dont think that you will ever go back to the old map.
2. You wont need VCDS
3. No, using the modified FW you will be safe
4. Not much, you wont see it in the MMI. Some minor stability fixes that most of the users never had problems even with older version than K0900
Hi Congo Thanks for your reply,
Can I go direct from HN+_EU_AU3G_P0485 to K0942 ?
Should I select user-defined or standard when I use modified FW ?
Hi all, Could anyone please help me? 0:)
I'm not sure if this is the right thread for me.. Could anyone please confirm this?
I'm reading this thread and can see people mentioning Audi Connect and Google Maps and I'm pretty sure I haven't got this option :crying:
Also I been reading the other thread on here and I can see people are updating the firmware in stages? Could anyone please tell me if I would need to update my firmware in stages or would I just go straight to the newest version?
I'm really new to this stuff and really don't want to mess anything up! :thumbsdown:
Any help is much appreciated! Cheers :grin2:
Brilliant cheers! Do you know if I update in stages or just go for the newest firmware update? Also I have the B&O sound system, So i assume I download the modified firmware? Thanks! :thumbsup:
Hi Jaycraven1994
I just updated S5 2012 with B O system direct from HN+_EU_AU3G_P0485 to FW K0942 modified, without any problem
Hi Jaycraven1994
Ahh Great! I can see 2 different versions and haven't got a clue what the difference is! Would you know if I need:
8R0 906 961 EB – HN+_EU_AU3G_K0900 (A4/A5/Q5/Q7) SVM: 3GPEU900AU3G
OR
8R0 906 961 FC – HN+_EU_AU3G_K0942 (A4/A5/Q5/Q7) SVM: 3GPEU942AU3G
And what is the difference? I assume one is just a later version? Cheers!
I don't want to push it but maybe my post got lost in between all the screenshots. Does anyone know if updating firmware during a long drive is a smart idea to do?
Status
