Water methanol and supercharging
6K views 24 replies 11 participants last post by  DML
#1 ·
I get some negatives about supercharging where the only pump fuel you can get is 91 (r+m/2). With the Rotrex supercharger the boost increase is so linear that a simple AEM w/m kit works fantastic. It also has safety features so you can take action if there is no flow for whatever reason. I have used it many times on my Honda kits and worthwhile gains are always there. I spoke with Eurotek in LV while I was there over Christmas and they say its the only way to have fun with boosted cars. Its a cheap precaution. What members have had experiences in the S5.
#2 ·
Here on the east coast we get 93 and there is no problem with octane. While speaking with my sc installer there was a 100 octane program but we can only get that at the track and the power increase is only 10 horse so it's not cost effective.
#4 ·
Interesting thread this, I have been doing some research on water meth and the reasons why so many have failed to get results from it on the Audi V8 engines (FI or no FI). I believe I've got some answers but need to put the information together in a logical format before I post. Will try to get it sorted over the next few days ;)
#5 ·
throwaway, we only have 91 here in Oregon too. Washington is the same as are some of the inland western states. I recently made the cross-country trek from NJ and noticed by the time I hit Wyoming the octane at the pumps was lower. It's very disappointing, considering I just spoke with Jeremy at Matrix last night about the TTS kit, and he feels the higher boost levels combined with our low-quality, low-octane gas here may not be a good mix. :( Further research will be done by them....
We do have one station in a local suburb that I have read about that sells ethanol-free 92. Unf I just read about it last night after filling the tank so I have to wait another week to check it out.
#7 ·
I think Jeremy told me it's ~$10/gal.... I fill the tank once a week, so it probably wouldn't be the most wise financial decision. Then again, neither is a s/c :p hahaha
Richard told Jeremy he was going to try to get his hands on some 91 and do some testing.
#12 ·
/\ /\ exactly, just think of it as an octane booster so you'll have to lean things out. I use w/m in my turbo 3000GT with great results. Makes for a great knock suppressor and keeps a cool charge. And more important especially for these cars with direct injection is it'll keep the valves nice and clean. Only thing you have to make sure of is to have fail safes in place if anything fails, there are various ways to do this.
Another thing to keep in mind is to use good quality W/M or mix your own as I do and not use windshield washer fluid which can have other chemicals and vary in percentage of W/M
#13 · (Edited)
^Unfortunatley, W/M has been shown to not really help the carbon issue on the FSI as much as many had hoped (even with S/C). I believe it was kryponite (who has now sold the car and kit) that ran a PES S/C with meth as well as a catch can and was still showing carbon build up.
Good point about the meth with fuel trims too. The ECU should be able to calculate for some of it, as O2's will show lean with no adjustment. Meth by itself requires more fuel to hold a constant AFR. But additional tuning in a s/c setup is often advised.
Also, just a side note, I've read that some advise to not spray w/m prior to the blower as it's not good for the internals. Just something to think about, unless a port spray kit was developed, which is obviously unlikely.
#14 ·
Interestingly APR disueded me from installing a catch can
#16 ·
Honestly the only solution for carbon buildup is a catch can AND disabling EGR AND getting valves that are resistant to carbon buildup. Even then, all of the above together would only reduce it. Cam overlap is necessary, and with it comes carbon buildup. Only real solution is the lexus method.
#17 ·
The only thing they said was that it wasn't needed or advised-Soldier runs a PES kit and has a catch can, fromm what I can tell it dosen't effect his car adversely. But I did ask and it was a NO. Maybe Arin from APR can shed some light on this subject?
#20 ·
Usa
#21 ·
For those who are using water/meth kits -- how large is your reservoir and how often are you refilling it? For a daily driver, would it be terribly cumbersome? As I plan on keeping my car for a long time, I have toyed with getting one after a carbon cleaning -- simply to try to keep the build-up down. I know that there are nay-sayers... but it does seem from good authorities that it may help prevent buildup -- but certainly not clean up caked on crap.
#22 ·
DML I too was thinking about this but remember our cars only have the ability to have one program so we would have to run 100 all the time a bit of a pain in the ass and only for a 10 hp at the wheels. Plus a $2-300 for the reprogram.
#24 · (Edited)
I don't believe DML is looking for power gains so there'd be no need for enhanced fuel or a reprogram. Even with both the reason there would be little performance gains on either the M90 PES or the previous TVS1320 APR kits is because they are already pretty much at their limits.
Heat reduction for retaining power under hard and persistent use (i.e. mostly on track) is where a water meth kit can be an advantage on either of these two kits. There are a number of PES clients Aquamist water meth kits specifically for this reason.
DML's target is carbon reduction. As I have explained to him via PM before I viewed his comments on this thread, as far as I am aware no one in the S5 scene has used water methanol to target reducing carbon build up. It would be very much a hit and miss project, a lot of expense using a full 8-port injector system that would have to include precise injection but there'd be no guarantee this is a solution to carbon build up.
DML, when I replied to your PM I'd forgotten there is a guy that started a similar project on a B7 RS4 which you can read up further information on here .... RS246.com Forum :: The World's #1 Audi R, S and RS Enthusiast Website • View topic - My Water Meth Installation thread
In some knowledgeable circles there is a certain amount of belief that when changing out the manifold to add an supercharger you are also removing the flaps and this should reduce the build up. Personally I'm waiting to upgrade the PES kit to the Whipple and see how mine has faired (it was cleaned on the original install) before deciding if to try any way to keep the carbon away rather than just clean it once every 30k miles.
Ultimately water methanol is a far more complicated issues than most appear to appreciate. I'd suggest staying away from it unless you understand all implications of running it.
