2020 maps version 6.30.1 - PLEASE NOTE - this package is ONLY suitable for 3G and not 3G+/3GP so if your firmware version doesn't match the style indicated in the instructions do not bother downloading this file, as it's been cut down to make the download smaller and so it'll fit on a 32GB SD card without issues.
26.99 GB folder on MEGA
The link above includes an activator file, but if you've successfully updated in the last couple of years you shouldn't need it. Note that the activator needs to go on a seperate SD card, and shouldn't be copied with the map files.
For facelift cars with 3G+/3GP see other thread for correct links - don't muddle them up as it doesn't go well.....
Update instruction guide below - this one is a better layout than the one I produced a couple of years ago, and covers firmware updating etc
MEGA
PLEASE NOTE - THESE ARE FOR EUROPE, NOT ROW OR NA and I cannot help with questions about where to find them.
I did not need to re-activate, having done so for 2018 maps. I did still get the SVM error in VCDS, which doesn't stop it working if you leave it/don't have VCDS.
I recommend using JDownloader to grab the links and WinRAR for extracting the archives when finished downloading. If you hit the download limit from Mega and don't want to pay for premium downloads I can recommend using the Opera browser, which has a built in VPN tool so all you need to do is switch location and it will allow you to continue downloading. You do lose the option to use JDownloader if you go that route.
These files are from a variety of sources, so credit due to all those who compile and make available :grin2:
If you don't have up to date firmware, links in the thread below:
MMI 3G navigation 6.24.2 Europe and firmware updates -...
MEGA
