1,261 - 1,280 of 1,462 Posts
Does anyone have a link for: • 8R0 906 961 DK – BNav_EU_K0257_2_D1 (SVM: 3GBEU257) thanks in advance! Theard is amazing - thanks for the work
Hello, Mr. congo
I followed your instruction for updating my Audi A4 B8 K2 (2012) 2.0 TDI with maps and firmware update. I managed to set up the maps but when it comes to update firmware ( i have 0257 version and what to install the 0260 veriosn) , i have an issue: the START DOWNLOAD button is not active/enabled ( is should be red coloured, instead it is gray coloured, inactive). I formated the SD card 8GB as FAT32, no problem about that, then copied the files from "8R0906961DP (BNav_EU_K0260_1_D1)" unzipped, as indicated in your 3G BASIC.pdf file . i did this twice but the same issue.
What do you think is the problem ? Ah, and all the files lines are with "N>" in the MMI install process.
the image attached if from PDF but i wanted to point the phase where i got stucked. i can not acces the START DOWNLOAD button, is inactive not active as it should be,like in the image.
Thank you very much for your help with all this topic.
BEST REGARDS !
Hello, Mr. congo
BEST REGARDS !
Hello all,
This is an incredibly long thread, I am hoping someone (like Mr Congo) can point me in the right direction. I have recently bought my 2012 Audi A5 and the Nav system isn’t working. It reads 0 satellites, doesn’t have nav database version and won’t let me do anything other than stare at the nav screen wondering why I can’t choose sub areas to play around with. The current software version states that it’s BNav_EU_PO206_D1. I have taken it to my local Audi dealer and then suggested doing it for 250+, I took it to a local car specialist and they recommended paying 800 for an apple interface or a 400 diagnostics check … none of these are viable to me and I wish to do this as many of you have, as cheaply as possible! Is my system good enough to hold the support of an updated CD/SD card? Is my antenna broken?
Any help would be much appreciated!
Update the firmware to version 260, install the map and activate.
After that go for a driving to recalibrate the GPS nad you'll know is it OK with your GPS antenna?
... and the Nav system isn’t working. It reads 0 satellites ...
First thing to do is scan the car with a proper VAG diagnostic and report any fault codes in the MMI main unit J794. If there's a problem with GPS sat antenna, it should throw a DTC. --g
I have run a systems test using fox well and it reads malfunctions:
03276 - checking system version management
00862 - antenna for gps navigation (r50 r52) - sporadic 011 - open circuit
What are my next suggested steps?
About this 03276 - checking system version management not worry...
But about this 00862 - antenna for gps navigation (r50 r52) - sporadic 011 - open circuit GPS position will give you on wrong places, like Africa or China...
Need to change antenna...
And to change antenna I need to replace gps only or do I need to change fin on top of car?
I have had a look behind the dvd player where the blue cable connecter is connected and I cannot follow this cable to the gps - it looks like it travels behind the glovebox.
Hello,
What is the best way to update MMI version Bnav P0022? In congo post it is said that I should update first to 0257 and than to 0260, but I don't see 0257 installation available in congo's post. I want to update MMI in order to be able to update maps.
