1,241 - 1,260 of 1,462 Posts
Checking medium, please wait
try this topic
try this topic
Yeah, I also ask in the morning on that topic to. But no answear to the problem. I'll keep waiting. Thanks !
Hi all,
My partner has a Q5, which has BNav_EU_P0206_D1 / 4G0919884K ECE 5.13.8 installed.
I've done some basic research and can see 'BNav' appears to mean it's a MMI 3G Basic system.
We are checking if a head unit firmware upgrade is available, but have no interest in updating maps as they're never used.
Are we running the latest version?
If not, is there a changelog between what we have and the latest version?
hi to everyone
suddenly i have a problem with checking medium, please wait
it all worked well for about 2 years, i did not change anything, this message just appered out of blue
does anyone have a solution?
Hello, i habe a problem with my audi a4 b8. MMI 3g, i have touched the green menu, and i have changed something there, i dont know what, and now i receive a red panel wit trigger shut down after countdown please help me to resolve this issue
Hi, thanks all for the great info, I recently picked up an 2009 A6 Avant which came with software K0260 but the map disk from 2010.
I did the map updates last weekend to 22 / 23 and all worked well, but I noticed my MU Software version is 0144 which seems significantly lower than others I see around (previous screenshot shows 0190 as a comparison).
I can't find a list anywhere of the MU Software versions - I read that K0257 is cumulative although K0260 seems the same sort of size.
Does anyone know if K0260 is cumulative please or do I need to be rolling back the versions to older software and then work my way back up?
Some posts seem to say a path such as K0031 -> K0070 -> K0206 -> K0257 and then finally back to K0260 but others say K0257 should do it all.
I did notice I am missing folding parking mirrors in the settings and wondered if the previous owner didn't fully upgrade all modules and went straight to K0260 and missed some cumulative updates or even skipped them if user defined mode (the car does have Bose).
Not sure if it's as simple as sticking K0257 on an SD Card and starting a user defined upgrade and seeing if all MU* modules show as NA (other than Bose!)
I can't seem to attach the mmi3ginfo script output log file or zipped version so it's on Pastebin here - [INFO] Start: Thu Jan 01 00:10:01 UTC 1970; Timestamp: 20230608_085332[INFO] - Pastebin.com
Thanks in advance!
I did notice the timestamps in some of the partitions were from 2010 so I did reapply the K0257 update and there were a few MU parts that needed updating (not the Bose / DSP ones) so they're done and now the car is at MU Software 0188 from 0144.
I'm just about to reapply K0260 and see where that leaves it.
Ok sorted, K0260 reapplied via user defined mode and did the MU software from that and now up to MU 0191 👍 Thanks again all for the posts that got me in the right direction. Everything apart from the MU bit seemed to be up to date in both K0257 and K0260 so not sure why that was done.
The media player isn't currently responding in VCDS but that may be a loose connection, will leave it for a while to try and sort itself. It's got power anyway and has been whinging about an optical error (although CDs have been playing fine).
The car battery is currently on a reconditioning cycle on my Ctek as it's been stood for a while at the garage and seems to have sulphated (Yuasa Silver). Had the same problem on my previous car and once those Yuasa go flat they seem to not ever recover fully and need replacing.
Now that's done it's time to sort out the nadgered turbo actuator and blown pipes!
Hi guys i need help how to update my maps,bought 2 sd cards but i dont know which folders and what i need to download on this cards
atm software version Bnav_eu_p0054_d1 any advice?Thanks
MMI 3G Basic navigation 5.35.2 and firmware updates - currently 2022/2023
Map & activator:
MMI 3G Basic 5.34.2 Europe 2022 [Link on Mega] [Activator]
MMI 3G Basic 5.35.2 Europe 2022/2023 [Link on Mega] [Activator] (pass:4G0060884AM)
  • DVD 1 West : Germany, Lichtenstein, Austria, Switzerland, Andorra, Belgium, France, Gibraltar, Great Britain, Ireland, Luxembourg, Monaco, Netherlands, Portugal, Spain
  • DVD 2 East: Germany, Lichtenstein, Austria, Switzerland, Albania, Bosnia- Herzegovina, Bulgaria, Denmark, Estonia, Finland, Greece, Italy, Croatia, Corsica, Kosovo, Latvia, Lithuanian, Macedonia, Moldavia, Montenegro, Norway, Poland, Romania, Russia, San Marino, Sweden, Serbia, Slovakia, Slovenia, Czech Republic, Ukraine, Hungary, Vatican City, Belarus
Firmware:
MMI 3G BASIC A4-A5-Q5-A6-Q7 [Link on cloud.mail.ru || Link on Mega]
• 8R0 906 961 AA – BNav_EU_K0031_2_D1 (SVM: 3GBEU031)
• 8R0 906 961 AH – BNav_EU_K0070_2_D1 (SVM: 3GBEU070)
• 8R0 906 961 BD – BNav_EU_K0206_2_D1 (SVM: 3GBEU206)
• 8R0 906 961 AL – 3G_DAB_K0098 (SVM: 3GRU0098)
• 8R0 906 961 BC – BTHS_0400
Manual:
3G_BASIC.pdf [Link on cloud.mail.ru || Link on Mega]
Q&A section
A. Not for now.
Q. I have mmi 3g , version p0XXX can i go straight to k0260?
A. Yes.
skipMetaCRC = "true"
Cheers :wink2:
any help what should i do to make my navigation starts work?
Hi Congo,
Many thanks once again for your post.
I'm a bit confused to see that the same FSC activator is used for 2 differents Maps.
Is someone test with 2022/2023 map with act_2022 FSC activator ?
Thanks.
