1,281 - 1,300 of 1,462 Posts
hello, congo
I followed mibhelper tutorials but I can't update the mapping. I passed for the software.
I have version MHIG_EU_AU_K1555 (after the update MHIG_EU_AU_S1545)
activation key 02100020
And I downloaded version P330_N60S5MIBH3_EU of the 2023 maps.
The MMI tells me that it cannot find any valid data.
Can you help me ?
Thanks in advance
I updated everything but when I want to use the navigation it asks for the (original) DVD. But when I insert the DVD it wants to use this old data, everytime I start up the navigation. I thought by updating to the latest version it wouldn't ask for the DVD anymore. Did I do something wrong??
I just bough a 2011 Audi A5 cabriolet (with B&O) with the stock firmware and maps. I would like to upgrade to the 2023 maps, but it looks like I need to upgrade to a newer firmware first. The documentation states that I upgrade to K0257 first, but I can't find the firmware on Mega. Only K0260 is available. Can someone point me where I can download K0257?
@bugboy -- The interwebz are full of dodgy information about undocumented systems like our old Harman-Becker MMI3G systems. A close inspection of the 8R0906961DP (BNav_EU_K0260_1_D1) media shows that it is complete (that is, not incremental from the earlier K0257 release). This is true for the HNav and HN+ updates, too. Unless someone has a documented reason for presenting BNav updates incrementally, you should be able to update to K0260 from any P (production) or K (update) version. --g
I found the K0257 in one of the earlier posts and updated to K0257 and then K0260, but I think K0260 would have been fine as well. It contains all the modules (AFAIK). Everything went fine, but I can’t access the green hidden menu anymore. I’ll wait when my VCDS cable arrives and enable it again.
I also have an Andreas CarPlay module, but upgrading went fine. Only Car and Enter button went to the Andreas camera. But was easily bypassed by pressing the Enter button another time. Maps went fine as well. I have B&O, but it didn’t try to apply any DSP updates. All is fine with K0260.
@congo Thanks for the detailed instructions. Highly appreciated.
go I am Italian ... my system does not bring the hard dis
You already have the answer
there is no solution for that problem yet, since I've been looking for the same one for a couple of months.
Anyone?? I'm not able to use the navigation so help would be appreciated!
It will be useful to examine how your MMI3G Basic (BNav) system software is configured to try to solve this. Can you run my MMI3G Info script ? The ZIP is posted here: MMI3G-Info/mmi3ginfo3-231116.zip at main · DrGER2/MMI3G-Info (select "View raw" to download the ZIP file).
Extract the ZIP file to a blank/empty FAT32 SD card, start the MMI system & wait at least 3 minutes, insert the nav DVD and wait for the error messages, then insert the script SD into either open slot. After within 5 or so seconds, you should see a prompt on the MMI screen to "press any button to continue" (if you don't the prompt after 10 seconds, eject the SD card, count to '5', then reinsert). When the script is ended, another prompt will be displayed to eject the SD card. Post the resulting plain-text log file from the SD card to shared cloud storage (like Google Drive or OneDrive) for review & comment by the community. --g
Hi nothing for my Audi a3 8v mstd software? I read many many threads but find nothing working for me. I download the new maps seems correct for my software but not recognized by the car on a SD. I need an activator? Where I can find? Thanks to anyone
Hi All, went to update my A6 to K0260 from p0260 (I think). I have the Bose sound system, however, during the user defined update process, it was showing DSP_G3_C6 instead of a Bose related setting. Is that normal or has someone overwritten the Bose DSP at some point?
@Bolly200 -- All early MMI3G Basic/High platforms got the same updated software for either MU9304 (BNav) or MU9308 (HNav); package DSP_G3_C6 is for the Bose system fitted in C6 platform models (A6/S6). If should not be selected normally for update (the software in the update is the same as the production version, which was produced in 2008). If your MMI3G main unit had P0xxx software, it was the production/factory version. --g
Hello, I can use both version if I activate with script 3gb Fix? I want to use West and East . Or how is it possible to use both versions like to switch between them ?
Hi All, I have updated my A4 MMI 3G BASIC to K0260. The firmware update is done, but I have problem with next steps. In the Green Menu I could not "Delete NAV HDD partition". I got a message: "Script not found!".
I have tried to install the EUE 5.33.2 (BASIC), it recognizes, I press "Start download" but on the next screen I can press only the "Abort". I can choose the START but it does nothing
Any suggestion?
@csarp -- Your MMI3G Basic/BNav system does not have an internal HDD, so the GEM script, which is part of the HNav firmware, is meaningless on your system. With a FAT32 SD card in slot SD1, does your MMI3G Basic system save screenshots as PNG files when you press and hold the [<<]+[>>] keys for about 3-4 seconds ? Can you try this for the Setup > Version information and Red Engineering Menu screens ? --g
