1,921 - 1,940 of 2,928 Posts
@piotrek -- The HDD partition for the nav database on NAR cars is too small for this release of the ECE MMI3GP nav database. You can try to delete the HDD Nav partition using the Green Engineering Menu, but it may not be enough.
See this recent thread: MMI 3G+/3GP navigation 6.36.0 and firmware updates -...
BTW, P1001 was not meant for NAR MMI3GP 9411 main units. The proper update is HN+R_EU_AU_K0942_3. --g
thanks for help I removed old database and now all is working,
I made update: maps 6.36.0 2023 MMI 3G High/Plus Europe works without problems
About soft originaly in car was:
HN+R_US_AU_P1001 i changed it to
HN+R_EU_AU_P1001
HN+R_EU_AU_P1001
Yes, that makes sense now -- the Q3 was the last model to get MIB MMI, so 2018 Q3 MMI3GP were likely fitted with hardware sample F2, which requires P1001. Thanks for confirming that information. --g
I have created my SD with new map on it but when I put it in my car I'm not getting a notification to update
@geordie47x The SD card insert won't automatically invoke update; you have to use the appropriate MMI key combination to invoke the 'Red screen' aka Engineering screen.
[Download and read the document in thread #1].
Hello, i have a question about update for A8 D4 MMI3G+ with rear seat entertainment system. Is update and maps same for back MMI ? If Yes, how is update done can i do both front and back at the same time or must be done one after another ?
Thank you.
@Slavov9510 That is a 3GHigh firmware level. I believe there is a link to it at the following
Thank you.
@Vidokas I'm surprised no-one has answered your query. I have an A8 but no RSE but I believe the updates are the same and you do the front first and then the rear ...
J
Hello guys, I had a little of a problem at the moment of installing the maps. When I try to update then, the system brings 146 ErrorCode at navipersistence script:0. I already tryed to format slowlly and tranfer the data again but it didn't work. Can someone help me with this?
MEDIA version: HN+_EU_AU3G_K0942_3
Navigation data: 8R0060884AH ECE 5.13.8
Trying to install : 6.36.0 2023 MMI 3G High/Plus Europe
We know that Error code 140 likely means out of space on the HDD and Error code 160 means the source file is not found on the SD card, so using "Retry" on these will not work, generally. We don't much about Error code 146, so you should try "Retry" a few times before cancelling the update process.
Also: use only full-size, high quality SD cards (Samsung, Sandisk) for MMI updates. And: you might try updating from SD Slot 2. --g
Hi everyone,
I have a Q3 2016 with HN+R_EU_AU_P0900 firmware. After doing some research, I came across this forum that explains how to accurately perform updates. My question is, can I update the maps without updating the firmware? If it can be of use, the navigation database is: 8R0060884CT LA 5.66.2
Thanks in advance
