MMI 3G+/3GP navigation 6.36.0 and firmware updates - currently 2023 Europe
Its time for a new thread and i hope this one will be kept clean
Here is a link to the old one, please check there before asking questions that might have already been answered in the past.
Maps & activator:
Europe
6.36.0 2023 MMI 3G High/Plus Europe [Link on Mega (use 7z/7zip to open the files)]
Rest of World
5.13.4 2021 MMI 3G High/Plus ROW - ANZ,SA,ME,HN,SM ... here!
NAR
6.20.1 2019/2020 MMI 3G ... here! If it asks for password then use this one -> 8R0060884GJ
Activator [Link on Mega]
Firmware:
Audi A1 [Link on Mega]
• 8R0 906 961 EC – HN+_EU_AU210_K0900 (A1) SVM: 3GPEU900A1
Audi A4-A5-Q5-Q7
• HN+_EU_AU3G_K_0900 - Stock firmware
• HN+_EU_AU3G_K_0942 - Stock firmware
• HN+_EU_AU3G_K_0900 Modified firmware - User Defined Mode / No Sound systems
• HN+_EU_AU3G_K_0942 Modified firmware - User Defined Mode / No Sound systems
Audi Q3-A6-A7-A8
• HN+R_EU_AU_K0900 - Stock firmware
• HN+R_EU_AU_K0942 - Stock firmware
• HN+R_EU_AU_P1001 - Stock firmware
• HN+R_EU_AU_K0900 Modified firmware - User Defined Mode / No Sound systems
• HN+R_EU_AU_K0942 Modified firmware - User Defined Mode / No Sound systems
Manual:
3G_3GP.pdf [Link on Mega || Spanish translation thanks to homarc || 2017 MAP Update thanks to homarc]
How to user 64GB SD card [Link on Mega]
These are the required files and folders for Map 6.33.1 with 32GB SD card. Thanks to @JulianHicks for creating the lists.
See "3GP_Filelist.txt" (3GP) and "3GH_Filelist.txt" (3G High) attachments in this post.
You might need GEM (Green engineering menu) activated and use User Defined Mode and manually select all that is under AUDI_MMI3G_ECE if it's not selected.
Warning - FW update K0900 is removing the "Emergency Update" option from the "Green Menu". There is a way that this can be fixed.
• Emergency menu activation on K0900 firmware. [ Only for A5OC ]
• To enable the Green Menu you could use VCDS, VAS or the following script [ Green menu activation ]
• 03623 [ 03623 Remove ]
Do not use MAC to unpack and/or copy the files to the SD card.
A. Not for now.
Q. I have mmi 3gp , version p0XXX can i go straight to k0900?
A. Yes.
Q. Have found the activation script and it includes "2380_00040009.fsc". This should be changed according to manual Page 31 to the MAC address specifically to my MMI or should I continue to use the "2380_00040009.fsc" as stated in the manual page 18.
A. Leave the filename as it is now.
Q. The 2380_00040009.fsc file contains a VIN number. Should that be changed to my VIN number?
A. No, do not attempt the edit the fsc file.
Q. Will my VIN be visible and correct in the MMI
A. Yes.
Q. Only thing is that my Google Maps option is greyed out... any hints?
A. Reinstall the GEMMI_nav component from the K0900.
Q. What does the new firmware bring in terms of added functionality?
A. Not much, apart from K0770/K0767 fixing the issues with the SIM data connection and Bluetooth usage at the same time.
skipMetaCRC = "true"
Maps & activator:
Europe
Rest of World
NAR
Firmware:
Audi A4-A5-Q5-Q7
Audi Q3-A6-A7-A8
Manual:
- Unzip it on the SD card.
- Put the sd card in the MMI.
- When prompted press the center knob.
- After the script is done you will see confirmation screen.
- Remove the SD card and reboot MMI
The problem:
I've tried to update my firmware (MMI 3G+) to K0767 and got the following error:
GEMMI_nav:0 error code 141
I could only access "Retry" choice (but update kept blocking at 5% with the same error) or "Back" button that was useless
Unable to do anything else, even the Reset procedure didn't work!
Root cause:
This is a file corruption error, the MMI didn't like what it found on the SD card.
Because I'm a stupid software engineer who thinks he knows best, I didn't trust the forums and copied the files from my mac onto the SD card (using command line to clean-up the .Trashes/ and alike folders)
So this is the lesson: DO NOT COPY FROM A MAC
Sub-lesson: better learn from other's mistakes than redo the experience...
Solution:
As stated previously, even a MMI reset procedure didn't allow me to get out of the error.
So I went to my neighbour's Windows PC, reformatted the SD card and extracted the RAR archive onto it.
Back to the car, update went fine and completed successfully after 30 minutes
Hope this experience will help some fellow here...
Q&A sectionLESSONS LEARNED - NEVER USE MAC OS (or Unix, Linux based OS) for unpack and copy map or firmware data into SD card. Also always format SD card in Windows OS. USE ONLY WINDOWS FOR UNPACK/COPY!!!
I had to upgrade Firmware as well. I could not load map data even they were copied in windows. It means that also Firmware was corrupted.
I found cca 10 000 hidden files on Firmware SD card. Dangerous is that Firmware seemed to be OK all the time but it was not and I could destroy whole MMI
(Imagine that FPGA or EEPROM is burned with some hidden apple .bin file....).
A. Not for now.
A. Yes.
A. Yes.
