141 - 160 of 2,935 Posts
that's good to know, thankyou
firmware update for HNAV
180772
So, with the help of this forum I managed to complete the update, however it gives this error code at the end. Any ideas what it may mean?
The software has definitely been updated, as version shows as 8R0 060 884 HQ ECE 6.32.1
Hello I was searching for answers but didn't find them. Maybe I am missing something.
First of all, I am new here. I own Audi Q5 2017/18. It comes with preparation for navigation that needs to be activated but due now I haven't needed it, but I am planning to activate it in the near future.
But now, first of all I would like to update of the MMI software to the latest version because like I have been told that with the current version of my MMI there are available for download only maps from 2016 and l would like newer ones.
Here are my MMI information: Software version : 0771 Media driver : 1.2.0 Telephone driver: 2121
In advance, sorry that I have posted in this thread, but I found it most appropriate for the latest firmware updates.
Best regards.
Hi I just bought the A5 2017 Coup that has same version as your software. My dealer says you can only replace the whole MMI system as tehre are no upgrades. Did you come right ? Regards Bruce
Hi All, I apologise if you have heard this question 100 times already, I have tried searching for the answer, but to no avail.
I have a Q5 with a 3G High MMI, which I believe hasn't been updated in many years if at all?
The attached picture shows you what my current software version is, but which thread do I need to update the firmware, how old is it and what should the link look like.
Thanking you all in advance.
Micron
180829
Micron
You need the links at the start of this thread.
Do version 0253 first, then 0257.
Thank you very much for the reply, I will download them and swot up on the procedure
Just tested on my MMI... Worked!
-Get this file, unzip and copy everything to a FAT32 formated SD
ACTIVATOR_3GH.zip
-Turn on your MMI and check if every function is working. It needs some minutes until it is fully working. Test all buttons!
-Insert the SD. I used slot 1 but it should work on either of them.
-The pop up should appear, if not remove SD and wait a couple more minutes. If it doesn't then you might have some difference on your firmware. Can't help you there as my firmware is not the latest...
-The script will delete the 2 files from the MMI, copy them again from the SD to the MMI and, to check, copy them from the MMI to the SD with the .ACTIVE extension. These two new files on the SD should have the same content of the mmelauncher.cfg and mme-becker.sh.
-REBOOT your MMI and test navigation/jukebox.
hope it helps!
Hi, could you reupload the file, the link is expired.
Hi I just want to know what should i do wrong i get on mmi3g+ radio error for both front bass speakers and gps antena error. Audi a7 mmi3g+ not Bose speakers. I follow all instalation looks like all works all cracks and activator worked.
If You want to copy the files for 3GP, you need to delete the following folders to fit to the 32GB SD card (Only LIT1-3 is not enough!).
CTY
LIT
LIT2
LIT3
Hope it helps, for me it worked!
I have Audi Matrix A8 2014, and i have the files of map but i dont know how to recocgnize with usb, can someone please help me!
I have Audi A5 Cab 2011 MMI 3G, Train Version K0070 MU SW 0175. I downloaded the latest set BNav_EU_K0260_1_D1_(A4-A5-Q5-Q7) with Maps Audi BNav 5.31.2 West 2020-2021. Then prepared SD cards as described by congo.
I followed his instructions: Software update, SD Card1, BNAV_EU_K0260_1_D1, Standard (User-defined is grey-I cannot choose), got the whole list, scrolled down till the end, chose Start update, the get the screen with "Start" and "Abort", pressed Start and waited but nothing happened (how long shall I wait?). I tried this 3 times, last time I waited all night long but still nothing happened. The next screen "Update progress" did not came, No download...
The only chance was to abort the update. The logging menu showed the tried update, but with NOK.
Did I make something wrong or forgot something? Any workaround? Please help me :)
unfortunately, you are in the wrong topic.
you should go here:
Hi guys, any solution for removing 03677 - Missing Secruity/Release Code fault code?
installed modified K0900 and maps + activator from the OP over the factory installed SW and map. Installation and activation went smoothly, I successfully cleared 03276 - Please Check Software Version Management fault code, but I can't find a solution (if there is any) for clearing 03677 :oops:
Hi, Just to confirm that i need a different activator script for maps 6.32.1, other than the one on the first page, as when i insert the sdcard into the slot nothing happens?
I have tried both links.
If this is the case if someone can repost the latest activator i would be grateful.
A5 MMI 3gPlus
Many Thanks
John.
Hello. After trying multiple times I still can't update... My firmware is hn+r_eu_au_k0942_4 and as far as I know the map update should be piece of cake. Unfortunately in the engineering menu when I scroll to the bottom the "Start update" is greyed out. Also all the selections are either N or N/A. Anyone able to help me?
Nevermind... Didn't know I had to select the updates I wanted.
Anyway it works now althoughtraffic sign recognition now tells me its outside of operational area but I think I already know a fix for it.
Thanks OP for the maps!
MMI 3G+/3GP navigation 6.32.1 and firmware updates - currently 2021 Europe
I have mmi version: MHI2_ER_AUG22_S2148 so please, which eu maps can i install... Thnx
Its time for a new thread and i hope this one will be kept clean :)
Here is a link to the old one, please check there before asking questions that might have already been answered in the past.
Map & activator:
6.32.1 2021 MMI 3G High/Plus Europe [Link on Mega (use 7z/7zip to open the files)] Password: 8R0051884HQ
6.20.1 2019/2020 MMI 3G Plus NAR [Link on Mega] (use 7z/7zip to open the files)] Password: 8R0060884GJ
5.10.4 2018 MMI 3G High/Plus ROW - ANZ,SA,ME,HN,SM ... soon!
Activator [Link on cloud.mail.ru || Link on Mega]
Firmware:
Audi A1 [Link on cloud.mail.ru || Link on Mega]
• 8R0 906 961 EC – HN+_EU_AU210_K0900 (A1) SVM: 3GPEU900A1
Audi A4-A5-Q5-Q7
• HN+_EU_AU3G_K_0900 - Stock firmware
• HN+_EU_AU3G_K_0942 - Stock firmware
• HN+_EU_AU3G_K_0900 Modified firmware - Green Menu enabled / User Defined Mode / No Sound systems
• HN+_EU_AU3G_K_0942 Modified firmware - Green Menu enabled / User Defined Mode / No Sound systems
Audi Q3-A6-A7-A8
• HN+R_EU_AU_K0900 - Stock firmware
• HN+R_EU_AU_K0942 - Stock firmware
• HN+R_EU_AU_K0900 Modified firmware - Green Menu enabled / User Defined Mode / No Sound systems
• HN+R_EU_AU_K0942 Modified firmware - Green Menu enabled / User Defined Mode / No Sound systems
Manual:
3G_3GP.pdf [Link on Mega || Spanish translation thanks to homarc || 2017 MAP Update thanks to homarc]
How to user 64GB SD card [Link on Mega]
Cheers :wink2:
In order new 2021 map to fit in 32GB SD do not copy the following folders
pkgdb/LIT
pkgdb/LIT2
pkgdb/LIT3
You might need GEM (Green engineering menu) activated and use User Defined Mode and manually select all that is under AUDI_MMI3G_ECE if it's not selected.
Note: For update of 3GHigh remove the LIT3GP folders instead.
Warning - FW update K0900 is removing the "Emergency Update" option from the "Green Menu". There is a way that this can be fixed.
• Emergency menu activation on K0900 firmware. [ Only for A5OC ]
• To enable the Green Menu you could use VCDS, VAS or the following script [ Green menu activation ]
• 03623 [ 03623 Remove ]
1. Unzip it on the SD card.
2. Put the sd card in the MMI.
3. When prompted press the center knob.
4. After the script is done you will see confirmation screen.
5. Remove the SD card and reboot MMI
Do not use MAC to unpack and/or copy the files to the SD card.
Q&A section
A. Not for now.
Q. I have mmi 3gp , version p0XXX can i go straight to k0900?
A. Yes.
Q. Have found the activation script and it includes "2380_00040009.fsc". This should be changed according to manual Page 31 to the MAC address specifically to my MMI or should I continue to use the "2380_00040009.fsc" as stated in the manual page 18.
A. Leave the filename as it is now.
Q. The 2380_00040009.fsc file contains a VIN number. Should that be changed to my VIN number?
A. No, do not attempt the edit the fsc file.
Q. Will my VIN be visible and correct in the MMI
A. Yes.
Q. Only thing is that my Google Maps option is greyed out... any hints?
A. Reinstall the GEMMI_nav component from the K0900.
Q. What does the new firmware bring in terms of added functionality?
A. Not much, apart from K0770/K0767 fixing the issues with the SIM data connection and Bluetooth usage at the same time.
skipMetaCRC = "true"
