1,241 - 1,260 of 1,583 Posts
Hello, I mistakenly updated MHS2_ER_AU_P2035 because I hadn't seen that this version prevented me from having Google Earth. So I would like to install the previous version MHS2_ER_AU_P1242 but I didn't understand the "downgrade" tutorial at all. How and where should changes be made? in the "metainfo2.txt" file in the "MHS2_ER_AU_P1242" folder and then restart an update? Isn't it possible to simply reset the system from the car? (factory setting?). Thank you in advance.
Wait! Google Maps are still available in 2024 for Audi (without dedicated server) for older firmware ???
has nothing to do with older firmware
Google Maps via Android Auto or Carplay
Google Earth stopped since 2020 by Audi, only via special server or like offer from congo on his thread
My bad, I meant Google Earth. Based on Jojoggy's question, I thought there might be another way to keep using Google Earth besides the dedicated server by Congo, but I guess that's what Jojoggy is using. Thanks for clarifying.
A bit off-topic, after activating carplay and installing the USB data port, I bought a wireless CarPlay dongle: ELEACC - you can find it online.
The problem is that I am not happy with the way it runs, at least once per day, it doesn't start together with the MMI (I mean it starts, but faulty, no image, or frozen carplay image).
Do you have any experience with this dongle, or do you recommend another? Thank you.
Greetings community! Is there anyone that can point me to the right direction and support me in getting the language pack that contains Ukrainian language and some kind of howto/instructions about how to achieve that?
Thank you in advance!
on the maps you can find Ukrainian as well, on fw, never seen for Ukrainian
Thank you for your answer.
I know that in Ukraine there are people who can update MHS2 with the Ukrainian lang pack. But it goes together with the firmware update and maps update. for that, they are asking 200$. I have everything except the language pack, and I don't want to pay this amount of money just for the language pack.
I have 2 usb sockets but they are not side by side; is carplay will work ? View attachment 189118 View attachment 189119
check it self out, if you has run the congo activator and using the original usb-Iphone cable on the phone and if its not working(with the right coding for Carplay:
Coding: Activation of App-Connect with any OBD2 adapter
5F → Long Coding → Byte: 19 → Bits: 6-7 → enable App-Connect compatible USB port
5F → Adaptation → vehicle configuration → Apple DIO → enable CarPlay
5F → Adaptation → vehicle configuration → Google GAL → enable Android Auto ), then your usb-port are only charging!
then you need to change it to an usb-port that supporting Carplay
its OK for booth,
1. you load the activator on the sd card
after that and all works well then
delete the sd card and load the maps
then the navigation will run
please check your post conversations in your account details ;o)
Olá a todos. Tenho um Audi A4 Avant 2016, que tinha a versão de
Hello everybody. I have a 2016 Audi A4 Avant, which had the map version MHS2_ER_AU_P0448, and the 0148 software. I installed the CONGO 2.5 activator and then tried to install the 2024 maps, but to no avail. Afterwards I successfully installed the 2035 software and the activator again, but when I insert the card with the maps it gives me the information that the card was removed.
The licenses that appear active to me are the following:
00030000, 00030001, 00040100, 00050000, 00060100, 00060200, 00060300, 00060400, 00060800, 00060900, 00070200, 023000f0, 02 3100f0, 023d00f0, 02500016, 025000f0, 023100f0, 023d00f0, 025000f0, 025100f0,025d00f0.
What am I doing incorrectly, and how should I go about updating the maps?
00030000, 00030001, 00040100, 00050000, 00060100, 00060200, 00060300, 00060400, 00060800, 00060900, 00070200, 023000f0, 023100f0, 023d00f0, 02500016, 025000f0, 023100f0, 023d00f0, 025000f0, 025100f0,025d00f0.
... maybe your actual sd card are bad, or needs an slow formatting in FAT32
I hope you are using a standard SD card with FAT32 (for the future maps updates 32GB) and not a micro SD with an adapter.
Also, everything should be done on a Windows PC, there are problems with the Mac!
PS: your original maps FEC was 02500016 > 2016/17
the new activator FEC are now 025000f0 > 2075 - lifetime
thanks. Yes, it was a standard SANDISK SD card formatted in FAT32. I will try again with another card. thank you very much
Hi everybody!
I know I am going to make some of you guys angry by asking this, as I assume you explained thousands of times, but I am new to all of this and i just want my car to work. So excuse me 🙏 . I have some activation keys that say "legal" and some "ilegal" my version is mhs2 P0448, and if it is possible to explain me what steps do i need to do. Do I go with "Activator made by Congo" as first step like this (#252), after this get the maps on the sd card and install them into the car. Or is this "ilegal" going to mess something up.
Note: I do not have an original audi navigation SD card
Thanks to all for the helpful discussions,
and special thanks to the congo.
Hi to all. If i buy the Connect license for a month on a modded MHS2 there is a risk of brick the unit or it should work as expected on a unmodified unit?
Someone has tried that??
@congo did you have experience on this? I'm going to go on a driving holiday and would be great to have traffic information on, so 20€ for a month doesn't scare me. I'm scared of fucking up the unit activating Connect on a modded MHS2 unit... Activation of Connect should be fine or could give me some problem??
