481 - 500 of 1,588 Posts
I see a lot of files in this archive but no google maps or activator. Also cannot see what file I need for the update? Do I put all these files on an SD card and then get the activator and map from another download?
Anyone that can help me out with this bit?
actual are MHS2_ER_AU_P0448 ? if so use the RED Eng. Menu to update the soft/firmware first, use an standard sd card FAT32(no micro sd with adapter!) here the Software update instruction -> 720.9 KB file on MEGA this will take about 40min., after it reboot the MMI and then install congo activator (read the read me and pdf) and later maps
1. Firmware update to MHS2_ER_AU_P1242 -> 2.55 GB file on MEGA
2. Activator -> 2.56 MB folder on MEGA
3. MAP 2022/2023 -> 11.64 GB file on MEGA
do in that order
do in that order
Thank you. I have tried following those instructions before but I get lost reading the activator manual, my car does not have 2 usb ports and I have no idea how any of that coding works or where to even begin.
so actual you have MHS2_EU_AU_K0129 with an MU0159 ?
what you like to do? are somthing not working well?
1. firmware update
2. activate FEC?
ok then, all writen an page 1: #1
1.a you can go to this firmware update(take about 40min.) and still you can later installing Google Earth
MHS2_ER_AU_K0471 -> 2.53 GB file on MEGA
1.b you can update to this and later no more Google Earth update possible
MHS2_ER_AU_P2035 -> 2.54 GB file on MEGA
see link for Google Earth possible update Google Earth for MMI 3G+ / VW RNS850 / MIB systems
2. after update, then you need to install the congo activator version 2.5 (takes 5 min.) to installing newer maps on standard sd card´s
3. maps 2022/23
Hello,
US units dont have NAVI option from factory there for the MAP was also never released for it.
Yes im working on enabling that and yes will be possible remote.
Will it be free or will it have some symbolical price will see early 2023.
Hi @congo! I have a MHS2_US_AU_P2037 unit (without nav from factory), and have applied your activator and coded the required settings in 5F. I know that there are no MHS2 North America maps, but when trying the 2022/2023 EU maps the unit only gets to 11% initialization. Tried several different map versions and SD cards, all the same result. Even re-applied full P2037 firmware update, performed many resets, and setting the 5F navigation region to EU does not work either.
Is this expected behavior? Will I need to wait for your new NAR navi option to make further progress? Thank you and @alex-07 for all that you both do!
Edit: This person (Polo25) has the exact same problem. The guys over there are saying it's a navi region coding issue but not specifying.
hi, I wrote you an PM, because has nothing to do with this thread
as long as it is not solved, you can use actual for navigation carplay or android auto,
for the navigation with the apps google maps or waze navigation
Thank you, I read your PM. I might have confused you as I don't want to region change, and ultimately want to activate NAR maps. Do I need to wait for congo to let us know what his new tool might be able to achieve?
