461 - 480 of 1,588 Posts
Discussion starter · #461 ·
im sure this was covered in the very first page or in the manual too.
If the car was w/o navigation means that its not coded. You will need to check coding of 5F
Byte 1 and 24 to start with.
Regards.
Thanks for the info, I will try as soon as my new HEX-V2 is arrived. Currently I only have the old vcds device available. :-(
In the red menu all codes are written as legal, so I thought it should work.
Edit: It's written in the manual ;-)
Best regards
Ă–ncelikle -> Herkese merhaba.
Yakın zamanda navigasyon sistemi olmayan bir Audi A4 B9'a sahibim. Android Auto ve Carplay varsayılan olarak etkindir ve usb konektörleri arabadadır.
MMI'm şu anda MHS2_ER_AU_P2035 Yazılımına sahip.
Aktivatörü SD Karttan başarıyla çalıştırdım (yeşil Ekran - Tamam). Ardından ilk sayfadan 22/23 Haritalarını indirdi. Bir SD Kart (FAT32 formatlı) takın ve mmi'nin ilk yuvasına yerleştirin.
Ancak başlatma işleminden sonra her zaman navigasyon verisi olmadığını söyledi.
Vcds ile navigasyonu etkinleĹźtirmem gerekir mi? Kontrol ĂĽnitesinde herhangi bir programlama gerekli mi?
çok teşekkürler
Roma
[/ALINTI]
Have you allowed the External SD Cards from the Green Menu?
No I don't have enabled the use of externals cards, because I currently do not have a working vcds interface in my hand. Should come next week.
But thanks for the info, this was not written anywhere. I will test when the vcds adapter arrives.
Roman
Roman
the video are not for Delphi units, we have here.
the congo activator does this automatically by CID_off, that are written inside the readme or pdf from activator, so any standard sd card can then be used for the maps.
the map on sd card FAT32 (tool https://github.com/usbtool/formatusb/releases/download/1.0/formatusb_x64.exe )or test if working exFAT will only work in sd1 slot if you installing the congo activator!!
otherwise the FEC that your actual unit has, will not allowed to use newer maps
FEC maps
02500028 > 2021
0250002a > 2021/2022
0250002c > 2022
0250002e > 2022/2023
02500030 > 2023
02500032 > 2023/2024
Thank you for the reply.
These are the codes in my unit currently:
Does it mean i have to activate maps? My unit didn't come with navigation activated.
1. No, looks like OK (FEC 025d00f0)
2. needs coding with other tool like obd11 or vcds if it was never active NAVI, hope gps and all other hardware are in der car
FECs are encoded in the 0BDRRRUU format, where:
B - brand. 2 = Audi, 3 = Bentley, 6 = Porsche, 7 = Seat, 8 = Skoda, 9 = Volkswagen, C = MAN
D - device type. 1 = MIB1 HIGH (Harman), 3 = MIB2 HIGH (Harman), 4 = MIB STD2 (TechniSat / Preh / Delphi), 5 = MIB HS (Delphi)
RRR - region. 000 = Europe, 100 = USA and Canada (NAR - North America Region), 200 = China, 400 = Middle East (AGCC - Bahrain, Kuwait, Oman, Qatar, Saudi Arabia, UAE), 401 = AGCC + Turkey, 402 = AGCC + Israel, 500 = South Africa, 600 = Australia and New Zealand, 700 = India, 800 = Argentina, Brazil and Mexico, 801 = Chile, 900 = Asia / Pacific, D00 = Rest Of the World
UU is the release number. As mentioned above, if all of the "Installed FECs" have releases numbers less than the matching ones in "Supported FECs" - maps are not accepted.
For example: in order to get Audi (MIB HS) to accept RoW maps, in the "Installed FECs" list, there must be a FEC code 025d0030 for 2023 (023000ff > 2075), where the last digits 03 indicates the maximum release number of map updates that can be used on your MIB.
/SPOILER]
Roman
Today my vcds adapter arrived! I coded the steps which are written in the manual and ... it worked!!!
Thanks a lot.
Only thing which is not working is the navi in the small FIS.
I did the following steps:
STG 5F Informationselektronik 1
Anpassung
[VO]_Dashboard_Display_Configuration (RDID $0B5A)
[LO]_navigation_map_transmission_mode --> Neuer Wert: _MOST_Streaming
[LO]_navigation_map_compression_mode --> Neuer Wert: _H264
[LO]_navigation_map_Resolution --> Neuer Wert: _resolution_1
Hier noch mal genauer:
Den Anpassungskanal "ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode" auf "MOST_streaming" ändern.
Den Anpassungskanal "ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode" auf "H264" ändern.
Den Anpassungskanal "ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution" auf "resolution_1" ändern.
And I have the Multifunctional Plus Steering Wheel with the left and right buttons on the left side of the wheel. But after waiting 20 min (BUS silence) or restarting the MMI, nothing happens.
Does anybody has an Idea what I can do anymore?
Thanks a lot
Roman
coding fromm Audi wiki are correct, so if you use left button on Multifunctional Plus Steering Wheel, nothing coming, so changing around,
if you press the left and right buttons, only the driving data comes to the radio and the phone. Are you missing the selection for the navigation there?
the normal Multifunctional Steering Wheel will not work!
Hi guys! first of all, @congo - thanks for awesome work!
I was able to update my US MHS2 to EU P2037 and run 2022/2023 on it.
But I have a question, since I know that it is possible to change US P2037 to EU P2035 - there is some instruction/tutorial how to do it? I heard something about SWDL but i don't know details.. Thanks for any advice and help!
I'm totally lost. Version is MHS2_ER_AU_P0448. All I want to do is have new maps. Do I still need to activate? The manual honestly makes me want to pull my hair out as it says I need to code? Can someone explain the process to me like I'm a 5 year old?
