441 - 460 of 1,588 Posts
Hi Alex, bought 64 GB full size Sandisk SD card ultra, extracted 2022/2023 maps on it, put it in the SD 1 slot, still the same result:
Any ideas what am i doing wrong?
Thank you
the map on sd card FAT32 (tool https://github.com/usbtool/formatusb/releases/download/1.0/formatusb_x64.exe )or test if working exFAT will only work in sd1 slot if you installing the congo activator!!
otherwise the FEC that your actual unit has, will not allowed to use newer maps
FEC maps
02500028 > 2021
0250002a > 2021/2022
0250002c > 2022
0250002e > 2022/2023
02500030 > 2023
02500032 > 2023/2024
Tiguan
MST_EU_VW_P0890D
Hello, does this device have the latest firmware update?
The updated map "DiscoverMedia2_EU-AS_2010_V17" works seamlessly in VW vehicles with 16 GB SD Card.
Change made (Deleted content);
\maps\00\cfg\Delphi\V1\MAN
\maps\00\cfg\mapcfg\SEAT
\maps\00\cfg\mapcfg\SKODA
\maps\00\cfg\mapcfg\se_default.cfg
\maps\00\cfg\mapcfg\sk_default.cfg
Experience and working on 2017 Passat and 2019 Tiguan(MST2_EU_VW_P0890D).
Tiguan
MST2_EU_VW_P0890D
its on you, my recommentation are:
stay actual on your software, even its an older one, see here: release history P9122D (MU0842) ➔ P0867D (MU0867) ➔ your actual P0890D (MU0890) ➔P0891D (MU0891) ➔ P0876D (MU0876) ➔ P0879D (MU0879) and run only the congo activatorfor MST2 ... version 2.1
run congo activator takes (5min.) and use the last maps, this will work good
if you like to update because the actual software are with bugs then here the way:
1. update to MST2_EU_VW_P0879 (under mibsolution.one/ MST2 Delphi)
2. run congo activator v2.1 ...VIN
3. update maps 2022/23
read the readme and pdf inside the activator file
1. sd card with congo activator
2. push menu button for 3 sec.
3. plug the sd card in sd1 slot
4. run the activator
5. after 2 reboots wait someminutes, then its done (green screen normally comes - successfull)
6. take out the sd card and go to pc to read the log.txt file on sd card if all was OK!!
7, test the new function with CAR button push often to change to differant screens now, Carplay/Android Auto, etc.. see FEC´s
use standard sd card with new EU maps
that all
Hi ! Man thanks for your hard work . Do you have any firmware for austalia version?
main unit version FM2-P-TNDL-RW-AU-MLE
Thanks a looooot!
Discussion starter · #450 ·
Hi all,
MST2 is not MHS2 :) Please try to keep the topic about MHS2.
There are too little MST2 units in Audi cars anyway and they cant do navi or carplay so not worth patching them :)
It is true i put a link to MST2 activator too but the main topic here is MHS2.
Regards.
that all
[/ALINTI ]
Are you suggesting I install an older version?
Because "P0890D" installed
MST2_EU_VW_P0879 is this what you recommend?
@gorangoran
yes,
if the usb port support it, push the red menue to get the actual software version running on the MMI
@gorangoran
yes,
I already used the activator that Congo posted and managed to insert the new maps 22/23. I need instructions to further activate apple car play. do i need to upgrade the software or is this enough?
all well done(no new software needed, helps not), if FEC 00060800 - Apple CarPlay, if its not working on your usb port it can be missing coding or wrong usb port actual(only charging), then needs a media usb port and wiring change.
if obd11 at hand, you can check the coding for carplay:
[*]Module : 5F. (Information Control Unit)
Adaptation
Vehicle Configuration
google_android_auto (on)
apple_car_play (on)
Mirror_link (on)
Apple_DIO = On
[*]byte19 usb, has to be ipod (not full)
FEC
00060300 Mirror Link
00060800 Apple Carplay
00060900 Android Auto
am able to enable the android auto and apple carplay.
In 5F- adaptation - Vehicle configuration - activate the following
Smartphone_interface_for_rhmi
Apple_DIO
Google_GA
all well done, if FEC 00060800 - Apple CarPlay, if its not working on your usb port it can be missing coding or wrong usb port actual(only charging), then needs a media usb port and wiring change.
Adaptation
apple_car_play (on)
Mirror_link (on)
Apple_DIO = On
FEC
Apple_DIO
Google_GA
Unfortunately, I only have one usb port only for charging, but I haven't tried to connect the phone via that usb port. Is it possible to work through that input? What should I do?
no its only charging, its missing inside the media chip/support
you can testing it using the orig. phone usb cable and plug it in, it will not work, so other usb hardware and coding needed
read this posting all writen:
#287 ·
First of all -> Hello to everyone.
I recently owend a Audi A4 B9 without navigation system. Android Auto and Carplay was enabled by default, and usb-connectors are in the car.
My MMI has Software MHS2_ER_AU_P2035 currently installed.
I ran the Activator from the SD Card succesfully (green Screen - OK). Then downloaded the 22/23 Maps from the first page. Put an SD Card (FAT32 formated) and put it in the first slot of the mmi.
But after initzializing it always said no navigation data.
Do I have to enable navigation with vcds? Is there any programming in the control unit necessary?
Thanks a lot
Roman
