421 - 440 of 1,588 Posts
Hello everyone, please explain some nuances to me:
1. Can I change the region from US to ER and what is needed for this?
2. Do I need to update my MHS2_US_AU_P1242 MU software: 0160 ?
3. If you want to update, do you just need to put the new firmware on the SD card and do the update through the red menu?
Thank you if you answer, I just don't understand how to do it correctly (
Hi guys, would you be so kind to guide me thru the process.
I am currently using very old maps in my car 2015/2016 and i would really like to perform an update to the most recent 2022/2023.
So, in order to do this, do i have to update the software too, or just the activator installation is enough + maps on the SD card ?
My current software version is probably the first one ever release 🫣
Thanks a lot !
its on you, my recommentation are:
1. update to MHS2_ER_AU_P1242
2. run congo activator v2.5
3. update maps 2022/23
you can also only run activator (5min.) and use the last maps, this will work also good
Hello, i bought car with US version software ( MHS2_US_AU_P2037 ) but I’m in Europe and would like to change software to EU no matter even if downgraded version, can someone have guide or at least some basic steps if it’s possible. Green menu and engineering menu activated, my hardware: 8w0035652f
Guys, did you managed to change MHS2 US to EU without problems?
Hi everyone, new owner of Audi A5 Sportback 2018 here. Looks like my car did not have Navigation in the package since it displayed "Navigation system not activated" or something like that. So i searched through internet and found this forum with Congo activator and latest maps. I successfully patched my unit, but when i copied the map data on the SDcard, loading stops @24% with the message "the navigation data is invalid". Do i need to have an original SD card? I used a plain Verbatim 32GB SDcard.... Thank you
All you need is a 32GB FAT32 SD card, unzip the contents onto the blank SD card and insert it into the mmi's SD1 slot.
1. maybe the download was corrupted, so do it again, or you used a mac pc for it, that also causes problems, only use windows pc for it
2. Do not use Micro SD card with adapter
3. which current software is running in mmi MHS2_xx_xx_Xxxxx
4. what says the log.txt file on congo activator you have used
Hi Alex, thank you for a reply.
1. Already tried that, used windows PC, same result
2. Don't have full size SD card currently, could it really be an issue?
3 and 4. This is a log file:
Activator for Audi-MIB Scale made by Congo
SW rev: 1073
Device type: MHS2
Brand: AU
Device region: EU/ER
FW ver: MHS2_ER_AU_P2035
FW MU ver: 0235
HW: 050
FAZIT: GRO-63331.03.1809010146
VIN: WAU*****
Install location ffs - should be as safe as possible :)
SE: 1
Metainfo patch successful.
SWaP patch successful.
EL list created successfully.
So i assume the only solution would be to buy a full sized SD card and try again?
Hello, can someone explain me how to activate the green menu on MHS2 (AUDI A4 B9) with VCDS , so i can update my license to lifetime the activator not working for me because i have only 1 usb (Charging port only)
hi,
if you have an sd 1 slot, then run the congo activator, it will work for lifetime navi-maps!
it takes 5 min. only,
what actual MHS2_ ... software are running?
Open with VCDS STG 5F
1. Access code: S12345
2. Go to Customization [10]
3. Select IDE02122 developer test mode ==> GEM(Green Eng. Menu)
4. Set it to active
5. Restart MMI UNIT → Press the ON/OFF button for 30 seconds
hi,
4. Set it to active
I think the cango activator will not work for my car because i have 1 usb port only charge, i think the cango activator is for two usb ports unit
my software is MHS2_ER_AU_P2035
it will work too!!!! what you are saying are not true!!!!!
has nothing to do with usb ports! usb port are only for carplay/Android Auto function!
Hello, unfortunately not, but from the information I read on the Internet, you need to have a D Link DUB E100 revision D1, which is now very difficult to find, Odis or VCP and through the computer through the Puffy program, change the region from US to ER
I have the D link DUB E100, but did try it with the activator with different SD card and it successfully installed
Hello ! I want to try to update the navigator myself . Tell me , if I want to upgrade to ' MHS2_ER_AU_P2035 ' , it doesn't need 2 USB ports under the armrest , I only have one USB ? I understand that you just need to download the firmware (P2035) to the SD card , insert it into the first slot and update using the red menu . Then activate the activator (Congo Activator 2.5) . Do I understand correctly that I can update with one USB port and the two USB ports under the armrest are only for the carplay function ?
Thats correct your undestanding i right, today i learned that for the activator to work correctly the memory card should be SD card and not micro SD card
hi,
1. if your actual software are working without bugs, stay with it! because if you update to P2035 you can not use if you later like to have it Google Earth!
2. run only on a sd card with FAT32(not micro sd cards!) the congo activator(unpack content to the empty sd card) then you have lifetime maps and maybe some other function on your mmi
this depends on the today FEC you have before installing congo activator and after it you normally has some more FEC!!!
3. if you like to use google earth then read it here how it goes with congo help see here Google Earth ==> #1
later/anytime you can allways update to P2035(but no way back!!), but you need then again installing the congo activator, because the FEC´s they bring are then no longer valid, the original remains active allways.
