1,421 - 1,440 of 1,462 Posts
Hello, Sorry for my english, I'm french :). My car is a A4 Avant 2.0 TDI 2011 and when I have buy it, there haven't the support for GPS.
So a big thanks to @congo for this perfect tuto with files 👍.
I haved MMI3G P_0054 and I have put directly K_0260 without troubles and the map 2022/2023.
Thanks again.
Squale
Hello, I'm a new Audi owner and this is my first VAG group car. I want to update the system and load the maps. Am I right in thinking that it's enough to download the latest system and upload it using an SD card?
all the instrucitions are in the 1st post of this topic.
after that you will have to download the navigation maps on a SD card and activate them.
Reactions: xottod
I had doubts here because my version is P0054, so I understand that it is lower and I need to perform K0257 and then K0260? And where can I find K0257 because in the links there is only the latest version?
Hi nothing for my Audi a3 8v mstd software? I read many many threads but find nothing working for me. I download the new maps seems correct for my software but not recognized by the car on a SD. I need an activator? Where I can find? Thanks to anyone
Have you found a fix I’m trying to update my whole software and it’s saying the same thing, that it can’t be found and then I tried again and it says out of date or incompatibility issue
Don't wait for replies, your Highness, time to start reading like the rest of us, plebes. :D
Who told you that P0054 is below K0257?
From P0054 you can directly go to K0260.
Hello @congo,
First thing first, thank you for the versions and the answers.
Could you please help me with my doubts:
- On my car (Audi A5 2.0TDi S-line) it shows the information on the photo, the version you posted is newer right? Also can I make the update directly to the BNav_EU_K0260_1_D1?
- I search for a while and some say its not the most common for a S-line have a basic MMI, also I read online that the software versions Pxxxx are the factory ones so it should be right, but is there someway else to check if I have the supposed equipment physically installed?
- The most annoying thing is that I don't get the music from my phone via Bluetooth to the radio, is there any solution known?
MMI 3G Basic navigation 5.35.2 and firmware updates - currently 2022/2023
Map & activator:
MMI 3G Basic 5.34.2 Europe 2022 [Link on Mega] [Activator]
MMI 3G Basic 5.35.2 Europe 2022/2023 [Link on Mega] [Activator] (pass:4G0060884AM)
Latest maps activation HERE
  • DVD 1 West : Germany, Lichtenstein, Austria, Switzerland, Andorra, Belgium, France, Gibraltar, Great Britain, Ireland, Luxembourg, Monaco, Netherlands, Portugal, Spain
  • DVD 2 East: Germany, Lichtenstein, Austria, Switzerland, Albania, Bosnia- Herzegovina, Bulgaria, Denmark, Estonia, Finland, Greece, Italy, Croatia, Corsica, Kosovo, Latvia, Lithuanian, Macedonia, Moldavia, Montenegro, Norway, Poland, Romania, Russia, San Marino, Sweden, Serbia, Slovakia, Slovenia, Czech Republic, Ukraine, Hungary, Vatican City, Belarus
Firmware:
MMI 3G BASIC A4-A5-Q5-A6-Q7 [Link on cloud.mail.ru || Link on Mega]
• 8R0 906 961 AA – BNav_EU_K0031_2_D1 (SVM: 3GBEU031)
• 8R0 906 961 AH – BNav_EU_K0070_2_D1 (SVM: 3GBEU070)
• 8R0 906 961 BD – BNav_EU_K0206_2_D1 (SVM: 3GBEU206)
• 8R0 906 961 AL – 3G_DAB_K0098 (SVM: 3GRU0098)
• 8R0 906 961 BC – BTHS_0400
Manual:
3G_BASIC.pdf [Link on cloud.mail.ru || Link on Mega]
Q&A section
A. Not for now.
Q. I have mmi 3g , version p0XXX can i go straight to k0260?
A. Yes.
A. Restart the MMI and remove the key from ignition then put it back in. The error should change from 01043 - Control Module; Incorrect Software Version to 03276 - Please Check Software Version
Cheers :wink2:
My update failed before it started, it says cannot read files. Is it because i used a micro sd with sd adaptor? As otherwise i managed to download everything from site.
usually a micro-SD with an adapter does not work.
there are many posts about this.
you should use a good quality full-size SD-card.
@Ratzoi -- The Harman-Becker MMI3G BNav main units are hardware variants 9303 & 9404, mostly. This was produced by my MMI3G Info reporting tool:
Code:
[INFO] MU train name: BNav_EU_K0260_1_D1
[INFO] MU software version: 0191
[INFO] MU variant: 9304
[INFO] MU hwSample: n/a
You might consider running my MMI3G info reporting script and sharing the plain-text log file to a cloud storage site like Google Drive or OneDrive for our quick inspection; you can find the SD script ZIP file here: GitHub - DrGER2/MMI3G-Info: MMI3G Information Report Script --g
