Status
Not open for further replies.
961 - 980 of 3,801 Posts
@Devilz .. that's strange. You need to find someone local that have debugging skills :) I cant do that form distance :(
@K Al Ali .. that activator will work for RoW map, but the map have bug in it :(
@congo
Thanks for your quick reply, I do have 2016 RoW maps, but without activator.
To clarify I have MMI 3G High, which activator should I use? The one in your post or the one in Adrian's Post for RoW map.
Thanks.
@sooflan
Use the activator of the first page, under 6.24.2 map
And read carefully the Manual of the first page
Reactions: soofian
Save
Can anyone help with iPod not showing in MMI??
I looked at diagnose/settings in green menu hoping may be when I updated to k0942 it disabled the AMI but no. It's enabled. Anything else I can try to make it work?
Thanks @filou96
On the first page, its the Vlasoff one. I'll try it tonight and post an update.
Yes it works fine , and keep the original VIN of your car in MMI
You just have to clear expected fault code
Clear 3276 and 3623 fault code
Save
Google earth greyed out after 6.24.2 2017 map update
Hi again,
I have now performed the update of the maps 6.24.2 2017, and activated with the Vlasoff files. The map comes up, but google earth is greyed out and i can'tt get it to navigate.
Any ideas?
Yes just reinstall K0942 FW , it will reinstall GEMMI , no need to chose manually the files
Save
??? It works fine for me , no need to reactivate if you have 3G connection and original VIN of the car in the MMI
Save
procedure to re-activate the licence?
Hi there again,
The maps are activated and the firmware is working fine. I checked the VIN number and it's there too.
The problem is when I try to use traffic view, or enable the settings, it says that the activation licence has expired. I have done all that you guys have suggested so far.
Am I missing sometning, or is there a procedure to re-activate the licence?
Dont know sorry , perhaps Congo knows
I never need a licence for nothing except maps update ?
Save
Hi there Congo. Would you be able to help me with this issue. I have successfully performed the updates to the firmware and maps (both latest) on a HN+ system, but the traffic licence seems to be expired. Do you have any methods for activation of the licence?
Thanks!
Soofian :)
33 pages takes some working through, especially if much of it is old and possibly out of date. Nobody wants to spend hours reading every post unless they really have nothing better to do!
I need to update the maps in my A5 Quattro cab and much of the above is an issue for me.
I've been solely using Macs (and supporting them) for 30 years and never owned or used a Windows machine so even something as basic as copying data to an SD card in a format that the A5 will accept is a problem for me: EVERYONE I know, without exception, uses Macs! So I'm probably going to have to find someone north of London to help me out with this... as well as activating voice control.
Status
