Status
Not open for further replies.
781 - 800 of 3,801 Posts
Discussion starter · #783 ·
.. have to create a manual :(
do not copy the following folders
pkgdb/LIT
pkgdb/LIT2
pkgdb/LIT3
You might need GEM (Green engineering menu) activated and use User Defined Mode and manually select all that is under AUDI_MMI3G_ECE if it's not selected.
@congo can you upload the 2017 map to the other platform you used for the others please? mega stops free users downloading any more than 4gb per day, where as the other you could just download multiple 4gb folders all at once.
Also do you have any thoughts on what I posted a few posts up?
Thanks!
Save
pkgdb/LIT
pkgdb/LIT2
pkgdb/LIT3
You should add this to the first post :thumbsup:
Save
Went through this thread start to finish and finally had the balls to get it done. Thank you @congo for everything and also the most important PDF because really it has everything covered there.
Mines which is 2014 stock went straight to K0942 without any hiccups. For maps I decided to use 6.22.4 rather than the 6.24.2 only because I had a 32GB memory card.
One thing I would like to know is what the difference is between K0900 and K0942 firmware as I couldn't find anything on it.
Thanks!
You have to reboot your router and then you are good to go with new IP adress and 5 gb download.
Save
MMI 3G+/3GP navigation 6.22.4 and firmware updates - currently 2016
I copied all to sd card except those 3 folders named LIT as Congo said. Choosed user defined and entered in AUDI_MMI3G_ECE where question mark was (photo is taken after I manually selected all so Y is there on the end because of that)
Then selected all options in there except Bootloader
Am I doing it right or not? I didnt start update yet. Waiting you to confirm.
Save
Well Im 27% downloaded on mega, now paused waiting for another 7 hours for their 4GB bandwidth restriction to reset... think I'll be ready to update by Thursday/Friday at this rate sadly :(
Save
Dude imagine downloading it finally and then to see that some were downloaded incorrectly ie corrupt, that would annoy you - nah?
Well thats what happened to me [emoji30], ended up using the other link provided and good thing about it was that there were no restrictions.
I have just updated the maps to 6.24.2 on K0900 firmware. So far so good, old activation with Vlasoff Activator is valid on new maps.
Status
