Thread closed. Please see new 2021/2022 thread here
www.a5oc.com
MMI 3G+/3GP navigation 6.31.1 and firmware updates - currently 2020/2021
Map & activator (activator works for 2018/2019 maps):
8R0 060 884 GA - 6.28.2 2019 MMI 3G High/Plus Europe 2019 [Link on Mega (use 7z/7zip to open the files)]
2020/2021
8R0 060 884 HF - 6.31.1 2020/2021 MMI 3G High/Plus Europe 2020/2021 [Link on Mega (use 7z/7zip to open the files)] Password: 8R0060884HF
8R0 060 884 DF – Activator [Link on cloud.mail.ru || Link on Mega]
Firmware:
Audi A1 [Link on cloud.mail.ru || Link on Mega]
• 8R0 906 961 EC – HN+_EU_AU210_K0900 (A1) SVM: 3GPEU900A1
Audi A4-A5-Q5-Q7
• HN+_EU_AU3G_K_0900 - Stock firmware
• HN+_EU_AU3G_K_0942 - Stock firmware
• HN+_EU_AU3G_K_0900 Modified firmware - Green Menu enabled / User Defined Mode / No Sound systems
• HN+_EU_AU3G_K_0942 Modified firmware - Green Menu enabled / User Defined Mode / No Sound systems
Audi Q3-A6-A7-A8
• HN+R_EU_AU_K0900 - Stock firmware
• HN+R_EU_AU_K0942 - Stock firmware
• HN+R_EU_AU_K0900 Modified firmware - Green Menu enabled / User Defined Mode / No Sound systems
• HN+R_EU_AU_K0942 Modified firmware - Green Menu enabled / User Defined Mode / No Sound systems
Manual:
3G_3GP.pdf [Link on Mega || Spanish translation thanks to homarc || 2017 MAP Update thanks to homarc]
Cheers :wink2:
In order new 2019 map to fit in 32GB SD do not copy the following folders
pkgdb/LIT
pkgdb/LIT2
pkgdb/LIT3
You might need GEM (Green engineering menu) activated and use User Defined Mode and manually select all that is under AUDI_MMI3G_ECE if it's not selected.
Warning - FW update K0900 is removing the "Emergency Update" option from the "Green Menu". There is a way that this can be fixed.
• Emergency menu activation on K0900 firmware. [ Only for A5OC ]
• To enable the Green Menu you could use VCDS, VAS or the following script [ Green menu activation ]
• 03623 [ 03623 Remove ]
1. Unzip it on the SD card.
2. Put the sd card in the MMI.
3. When prompted press the center knob.
4. After the script is done you will see confirmation screen.
5. Remove the SD card and reboot MMI
Do not use MAC to unpack and/or copy the files to the SD card.
A. Not for now.
Q. I have mmi 3gp , version p0XXX can i go straight to k0900?
A. Yes.
Q. Have found the activation script and it includes "2380_00040009.fsc". This should be changed according to manual Page 31 to the MAC address specifically to my MMI or should I continue to use the "2380_00040009.fsc" as stated in the manual page 18.
A. Leave the filename as it is now.
Q. The 2380_00040009.fsc file contains a VIN number. Should that be changed to my VIN number?
A. No, do not attempt the edit the fsc file.
Q. Will my VIN be visible and correct in the MMI
A. Yes.
Q. Only thing is that my Google Maps option is greyed out... any hints?
A. Reinstall the GEMMI_nav component from the K0900.
Q. What does the new firmware bring in terms of added functionality?
A. Not much, apart from K0770/K0767 fixing the issues with the SIM data connection and Bluetooth usage at the same time.
skipMetaCRC = "true"
Recovery of "bricked" MMI 3G units, RNS850 unit, MIB1/2 units, PCM4/5 units.
Google Earth/Sreet View on RNS850 and all MIB1/2 units, PCM4/5 units
MMI 3G+/3GP navigation 6.36.0 and firmware updates -...
MMI 3G+/3GP navigation 6.36.0 and firmware updates - currently 2023 Europe Its time for a new thread and i hope this one will be kept clean :) Here is a link to the old one, please check there before asking questions that might have already been answered in the past. Links to the latest...
2020/2021
Firmware:
Audi A4-A5-Q5-Q7
Audi Q3-A6-A7-A8
Manual:
Cheers :wink2:
pkgdb/LIT
pkgdb/LIT2
pkgdb/LIT3
Q&A section
A. Not for now.
A. Yes.
A. Yes.
