1,341 - 1,360 of 1,583 Posts
Hi everyone. I applied a patch to my unit. By the way, my unit is MST2 DELPHI SW 0965D. FEC values were added with Congo Activator. I have bad news for you. Audi software does not include Carplay/Android Auto binary files. I examined the VW firmware files. I saw the AA/CarPlay service files. If we add them to the Audi software and recompress them, can they work? :) Congo, I would like to talk to you about this. Thank you very much again for your efforts. Unfortunately, Audi always likes to disable such useful features. Who will be harmed if I use Carplay in my car?
Do I need to use the activator or can I just download the maps on to a sd card and use it? It’s a Quattro 5 2018 I don’t know the system
you better find out what system you have.
if you try to install the wrong maps, you can run into big trouble.
Hi everyone, I have successfully applied the activator on my MMI (MHS2_ER_AU_P1242) and the new 2024 maps work. I tried to update the firmware to enable CarPlay in the menu, but I can't. Following the procedure, I insert the SD card into slot n1, enter the red menu, click on "SD card 1", and the "User-defined" menu is not selectable so it doesn't let me go forward. What should I do to solve the problem? Thanks
Dear all, I have already applied congo activator and my navi can handle latest maps.
So if I buy this cable, and then remove my unit (MHS2-MIB2)(without removing glovebox compartment), attach yellow tip to back of my unit, attach black and red cables to green connector accordingly in this video, finally connect green tip to usb out (part code 5Q0035726E). Will I have carplay once I update coding via OBD11 as below?
[*][*]Module : 5F. (Information Control Unit)
Adaptation
Vehicle Configuration
google_android_auto (on)
apple_car_play (on)
Apple_DIO = On
[*]byte19 usb, has to be ipod (not full)
Hi, thank you so much for the work you've put in to this. I have updated my FW to p2035, installed the activator and am using the 2024 map successfully. My only issue which I hope someone can help with is since updating to p2035 from p0463 I can no longer connect my phone via Bluetooth for handsfree, It will only connect for media. when checking the profiles they are all greyed out except for media player and the telephone option in the factory reset screen is also greyed out. When selecting telephone from the control panel I am just left with a screen stuck on "please wait".
Before the upgrade to p2035 my phone would always take 5 minutes before it would connect for handsfree which was frustrating hence why I tried to upgrade FW to hopefully resolve this issue and allow instant connection of my phone. Now I am left with no connection for handsfree at all.
Any help would be much appreciated.
hi, delete all bluetooth connection on the phone and as well on the MMI, then reboot booth units and connect it new with bluetooth/settings
Thank you for your suggestion. I have just tried this but has not worked. It connects as a media player but not handsfree and when trying to connect as a phone says "connection could not be established" and handfree, messages and phonebook profiles are all greyed out.
phone ? android or Iphone? test with an other phone done?
have you any error/fault code message, reading it with an diagnostic tool like VCDS or OBdeleven ? (scan the telephone control unit, as well as the BT control unit)
I have a samsung fold 5 which was working with it before the FW update although would take 5 minutes to connect. I will try a different phone incase of a conflict with new FW and will do a new scan with obdeleven. Previous obdeleven scans haven't shown any issues so far.
Thank you for the assist.
