1,321 - 1,340 of 1,583 Posts
Hi all, I have a 2016 A4, current version - MHS2_EU_AU_P0114 / MU Software 0102. I attempted to install the activator, but nothing happened when inserting the memory card. Am I correct in thinking that I first need to upgrade the software to perhaps MHS2_ER_AU_K0129 and then try and install the activator and then the updated map pack? Has anyone tried updating MHS2_EU_AU_P0114 and did it work for you? I realise this is very old software. Many Thanks.
Hi all, I have a 2016 A4, current version - MHS2_EU_AU_PO114 / MU Software 0102. I attempted to install the activator, but nothing happened when inserting the memory card. Am I correct in thinking that I first need to upgrade the software to perhaps MHS2_ER_AU_P1242 and then try and install the activator and then the updated map pack? Has anyone tried updating MHS2_EU_AU_PO114 and did it work for you? I realise this is very old software. Many Thanks.
I just realised that @Karlo554 discussed this above. Did you have any luck?
controllalo:
codifica di 5F, byte 03 - Country_Navigation ==> attuale ? (buono = => UE)
codifica di 5F, byte 24 - Navigation_System ==> effettivo ? (buono ==> attivato)
All ok for the encodings, after months I still haven't been able to solve it. Only in one case did the map open, that is, I was low on diesel and the system asked me if I wanted to find a nearby distributor, I confirmed and the maps opened. By turning the car off and on again, the map loading screen returned, stuck at 11%.
could it depend on the e-sim inside the mib 2?
[CITAZIONE="alex-07, post: 1642957, membro: 143463"]
controllalo:
[/CITAZIONE]
have you tried another SD card with fat32? it's not the E-SIM
also make then an reboot and use the new standard sd card or, delete / formating the existing and copy the maps again to the sd card
I mean its your sd card!
Actually, a guy on telegram helped me, the maps sd remained the same, nothing changed, the problem was on the gecache, they sent me a new file, I put it on another SD card, and then inserted the maps one, and everything worked.
OK, so all are now OK (y)
Hello friends. You're going to be a little mad at me, but I have a question. I have a MIB2 unit with A4 B9 MHS2 single sd card slot. I know I can't use Congo activator. I only want to activate Carplay in my vehicle. Is this possible? I do not want to change the MIB2 unit in the vehicle. Can it be via ODIS-SVM? Can we make a device-specific patch FEC/SwaP? Thanks for your help.
Device number ? and software train? use R.E.Menu to find it out
Discussion starter · #1,338 ·
You cant or you dont want?
Activator have no limitation ...
