1,281 - 1,300 of 1,583 Posts
Thank you for the activator, new maps are available now, I have successfully added the activator, however I've received following errors after:
01 - Engine - U105400 - Information electronics control module 1
15 - Airbag - U112100 - Databus missing message
17 - Dashboard- U111100 - Databus missing message
74 - Chassis Control - U112100 - Databus missing message
A5 - Driver Assistance - U112100 - Databus missing message
Old alarm: 5F - Multimedia - B201A00 - Checking software version management
I already had coded the small map on the center of the cluster a few years ago.
I have cleared them once and they reappeared, no check engine light, car is working just fine.
Did I missed something, should I try/need to update software from MHS2_ER_AU_P1240 to MHS2_ER_AU_P2035, would I be able to rollback to previous software version if something will not work properly, I do not see any back up folder as it is for MIB2?
Thank you for your time
Hi, this errors are normals, probe to close the door and close the car 5 minutes and wait to sleep the can bus, probe again to erase the fails and you must see sporadic fail and you must can erase.
This is it!
The proper activator for Audi MHS2 systems made by delphi.
It a result of deep system analysis and some good reverse engineering.
The time has come and i have decided to share it!
Now is available free of charge for everyone!
Unlike the leaked version of the activator this one is tested and in use for quite long time now.
You will not loose ability to install custom POI's and for sure it will not cripple your legal function enabling codes.
I cannot guarantee that will work on every MMI out there, but i never had issues ever since i created it back in 2016.
Regardless of what some might say, update of the MMI is not mandatory. This is entirely up to you.
If your MMI is working properly and you have not noticed issues then you can continue using same version.
Believe me, i know these systems inside out.
As you will see bellow the supported versions list is quite long and will only get longer with time!
In case that you do decide to update then subscribe to this topic as i will update it to include software update info and files.
In the archive you will find a manual how to use it.
It is very simple process and you will only need one empty SD card size 8-32GB FAT32 formatted.
After activating the MMI you will be able to use latest navigation maps.
Here is list of supported versions, it was tested on many more but for now i decided to include the following.
If your software is not the support list then send the backup that the activator will make and i will add it. Always make sure you are using the latest version of the activator.
Almost any version out there!
If for some reason you cant get it to work following the manual then its likely that your unit was already patched.
In such case contact me and i will see what i can do about it.
Please have in mind that im doing this in my free time and that means that im not 24/7 available :)
The map of MHS2/MST2(soon to be released) is not installed, you copy map on SD and just insert in the unit. If coding is ok and fecs are shown as valid then map will work.
Simple as that :)
MAP 2022/2023 -> 11.64 GB file on MEGA
MAP 2023/2024 -> 12.23 GB file on MEGA
Warning : Original version is only one and can be found on the link bellow.
Any other version with other names on it or "autobackup" shit ... is not supported by me.
If you decide to use it then check the forum, there are more than 50 cases of broken units from that shit!
Activator -> 3.12 MB folder on MEGA
MHS2_ER_AU_K0129 -> 2.09 GB file on MEGA
MHS2_ER_AU_K0471 -> 2.53 GB file on MEGA
MHS2_ER_AU_P1242 -> 2.55 GB file on MEGA
MHS2_ER_AU_P2035 -> 2.54 GB file on MEGA
MHS2_US_AU_K0471 -> 1.02 GB file on MEGA
MHS2_US_AU_P1242 -> 1.01 GB file on MEGA
MHS2_US_AU_P2037 -> 1.02 GB file on MEGA
Software update instruction -> 720.9 KB file on MEGA
After using the activator unit will accept modified meta.
What you need to do is take the meta from 1242, remove any SupportedTrains or BlockedTrains and then replace MetafileChecksum with skipMetaChecksum.
For for example with the meta from 1242:
Remove those two lines
BlockedTrains = "MHS2_EU_AU_P01*,MHS2_EU_AU_K01*"
MetafileChecksum = "cd15b1487917b24e0ca50e0716bfa3d6dd7d710d"
And add these two:
skipMetaChecksum = "true"
Then make sure all components are select, the bare minimum is - MCM,78K0R,AP_ZR_HIGH1,TNRREF. Nice to select SpeechRes,SpeechAppRes.
Keep in mind that if something goes wrong you might not be able to fix it yourself and might need to send it to me.
This document and activation are provided by THE PROVIDER "as is" and "with all faults." THE PROVIDER makes no representations or warranties of any kind concerning the safety, suitability, lack of viruses, inaccuracies, typographical errors, or other harmful components of this document. There are inherent dangers in the use of any software, and you are solely responsible for determining whether the procedure described in this document is compatible with your equipment and other software installed on your equipment. You are also solely responsible for the protection of your equipment and backup of your data, and THE PROVIDER will not be liable for any damages you may suffer in connection with using the information found in this document. You are also solely responsible for any modifications to the software of the MMI system, THE PROVIDER will not be liable for any claims from the vendor of your MMI system concerning the use of third-party software on the MMI system.
Selling this document and activation is forbidden.
Including this activation or its parts in any other tools should happen only after contacting me.
Attempts to modify the files might render the system inoperable.
Warning: Always make sure you are using the latest version of the activator from this topic. I will repair free of charge (w/o shipping expenses) any unit broken by using the original activator! I will charge every recovery that used clone version of this activator made by "professionals"
Enjoy :)
hi, the map 2024 I can´t download, is imposible, do you have other diferent link please?
How do I install POI?
- How do I import a POI package into my MMI?
To import a POI package, please proceed as follows:
Insert the SD card into the MMI.
Press the "Menu" hardkey.
Select the "Setup" item.
Scroll down and select "System information".
Select "Update software".
The MMI now displays "Searching for software update". Select "Next" and then "OK" and "Now".
The device will now restart. The POI package will then be available in the navigation context.
- How can I display my POIs in the map view of my MMI?
To display the POI collection, please proceed as follows:
Import the POI package as described above ("How do I import a POI package into my MMI?").
Press the "NAV" hardkey.
Select the "Setup" button.
Select the "Map" item.
Select "Categories for special destinations".
Select the name of the categories that should be displayed on the map.
Hi guys! a little bit off-topic.. about "SpeedCam MIB" from: SpeedCam MIB
I managed to install the latest EU - Audi EXT and I want to know if I can increase the range alert ? It is annoying and nonsense to receive the alert within 10 meters.
Also, what is the main difference between EU (AUDI) and (AUDI EXT) ?
Thank you!
Hello guys,
I'm quite new to this, so please excuse my dumb question.
I have a 2017 Audi A3 without android auto / apple car play.
My version is MHS2_ER_AU_P0470
And I have the following codes:
00040100,
02500018,
00050000,
00070200
And I have the 2017 MMI maps.
What I would really like to get is android auto/ apple car play.
Does anyone know if it is possible to install android auto/ apple car play on my car?
If yes, what do I need to install? Is there any Instruction on how to do it?
If installing android auto / apple car play is not possible, how should I proceed to update the MMI maps to 2024?
Thanks you for any support!
Hello guys,
00040100,
02500018,
00050000,
00070200
I advise you to start reading from the beginning of this topic.
you will most likely find all the answers you need,
Hello guys,
00040100,
02500018,
00050000,
00070200
about how to do it read first page if its not clear, then read #423 (fw+activator+maps2024) #287 (use the right usb-port)
for AA or Carplay you need to install the congo activator v2.5 then you get this FEC codes:
"00060800" # Apple CarPlay
"00060900" # Google AndroidAuto
PS: FEC codes
"00040100" # Navigation
"02500018" # 2017 MAPS
"00050000" # Bluetooth
"00070200" # SDS for Nav Systems
hi if I download the 2023 maps it tells me file removed then I noticed that my fw is not listed which one do I download? I have mhs2_er_au_p0463 fw: MU 0170
in the listing are the available fw for the versions we have as download, so its not meaning only this fw are working for the activator or maps
first use the activator v 2.5, then use the last maps 2024, check the FEC codes you get (REM menu) after the activator installation, if the activator does not work, then update your fw to the P0471 or P1242 and then again the activator v2.5.
use an standard sd card with FAT32(not micro sd and adapter)
Just to clarify, PDF instruction has VCDS coding for Coding – Enable navigation.
Does it mean that I cannot patch and use latest maps unless I have VCDS to enable navigation menu on my MMI? As I understand, after patching navigation will disappear from MMI, or am I wrong?
Thanks in advance! Apologies for novice questions.
question what MMI unit you have?
if its an MHS2 unit, you can use the congo activator v2.5 without getting any problem/issues this has nothing to do with VCDS coding
if you MMI unit has the navigation activated, then the activator helps you to get the lifetime maps FEC code, so you can then use the last on first page offered maps
