301 - 320 of 1,588 Posts
Mmm, normally the activator once finished its deleted from the SD.
Even if rerun should be safe.
Is there a log on the SD ?
Yes, but only with your signature "Activator for Audi-MIB Scale made by Congo", nothing more. It basically, I guess, load the activator on boot :(
Details on software:
MHS2_EU_AU_P0114
main unit on 0102
Now that i read my first post, I think i might not have explained it well, basically, by stupid mystake I made it boot with the SD inside, with the activator.
Dumb, i know. my fault.
Do I have to sell my soul to audi?
I have an A3 with MHS2_ER_AU_P1242 MU0213 which i used activator v2.1 last year and the 2022 maps & POI's . All running fine.
I do currently have Audi Connect subscription but obviosly the Google Earth option just loads the Sd-Card map.
Should I upgrade to MHS2_ER_AU_P2035 MU0235 - To get Here Maps as an option (is it any good? - asume standard maps and tmc traffic still work - even if i don't keep subscribing)
If I do upgrade firmware, do I merely install activator v2.4 afterwards?
If i dont upgrade firmware should I run v2.4 over the top of v2.1 anyway?
@ Fontana
if you update the firmware to 2035 you only can get Satellite map(no way back to Google Earth!), if you remain on 1242 you still can have it from
the google earth (without need of connect subscribtion, you need only an mmi with sim card slot)! Audi has stopped the google earth support, Google Earth stopped working in most Audi models since 1st January 2021 , as far as I know
if you upgrade the firmware, then you have to use again the activator, congo recomment the v2.3 over v2.1 so v2.4 you will not need!
1. if all running fine, no need to upgrade the firmware, you will nothing new see on fw upgrade, its only internal software bugs that are handled
2. yes without subscribtion TMC and maps remaining, so use the new 2023 maps, if you like to update the maps
3. if you ugrade fw then its ok afterwards use the v2.3 (without fw update your of v2.1 then the of v2.3)
Hi guys
I have a problem with the activation of the navigation system and the maps do not work.
Is my version also supported?
My navigation is MHS2_ER_AU_P0463.
I would be very grateful if you could help me.
Thank You
I updated my system using your activator. Now everything went so smooth and then at last I see a green screen saying successfully complete and nothing happens. I can not use anything on my media center. Anything any suggest that can help. :(
I have this version. Mst2_eu_vw_po891d
hi, can you post here the content of the log.txt file that you have on the sd card after use of the activator?
have you done an reboot(software restart/reboot unit), means hold/push the Power-ON button for about >20 sec. whats then?
you see the VW logo restarting?
Nothing happen pushing the buttons holding it.
It stays on a green screen saying successfully complete.
here is the log
Activator for MST2 Scale made by Congo & Duke
SW rev: 1901
Device type: STD2Nav
Brand: VW
Device region: EU
FW ver: MST2_EU_VW_P0891D
FW MU ver: 0891
HW: 851
FAZIT: GRO-63305.08.1707010124
Patch for /tmp/developer successful. Check ReadMe.txt how to use it.
Metainfo patch successful.
SWaP patch applied successful.
EL list created successfully.
Backup of current SWaP codes done!
Adding 00030000 to FEC list.
Adding 00040100 to FEC list.
Adding 00050000 to FEC list.
Adding 00060100 to FEC list.
Adding 00060200 to FEC list.
Adding 00060300 to FEC list.
Adding 00060400 to FEC list.
Adding 00060800 to FEC list.
Adding 00060900 to FEC list.
Adding 00070100 to FEC list.
Adding 00070200 to FEC list.
Adding 00070400 to FEC list.
Adding 09400008 to FEC list.
Adding 09410008 to FEC list.
Adding 094D0008 to FEC list.
Adding 094200ee to FEC list.
Found FECs in pg dir, will use VIN and VCRN from them.
Parse 1107
you write: Nothing happen pushing the buttons holding it.
so, only hold the ON/OFF button as long as unit are powered off and restarting(without any sd card in the unit, are this working?
I was on P0870D I updated to p0891D and it did work fine without any problem. Activator I used was 2.1 now the screen is gone after holding on off for 1 minute. but facing multiple problems with the car. All the sensors and automatic system is stopped working after this update. Is there any way to restore to the original or factory reset it ?
Update. The car battery drain too so now the car stopped turning on. Have called the auto help to assist me to take the car to Vw workshop
after you get your car back check if all working fine let all like its now, if not *, use the fw MST2_EU_VW_P0879D_MU0879 this are the last one official, then all patched are gone and factory original FEC code working
here the update history
of the 08xx versions : P9122D (MU0842) âž” P0867D (MU0867) âž” P0890D (MU0890) âž” P0891D (MU0891) âž” P0876D (MU0876) âž” P0879D (MU0879)
I dont know if this way helps you, if I have your issues, this way I would use this approach*
Discussion starter · #320 ·
Man, im not sure what green screen you are talking about.
MST2 Activator does not have green screen in it !
Maybe you installed MST2 and then MHS2 on top of i dont know.
MST2 have only one screen that is red - if someone is messing around with the files.
Normally the process goes as in the documents.
Not sure what im looking at here.
