Following on from my previous water leak post, I now have more information.
Car Audi A5 3.0 TDI
Year : 57
I have a slight leak from the drivers side of the bonnet, very slight. This morning my engine light has came on, car doesnt feel as responsive when I put my foot down although it seems to run fine.
Could this be to do with the water leak? I ran the ar 15 miles to work in 3rd and 4th gear to blast out any carbon in the exhaust but nothing came out, no black soot etc.
Can anyone give an insight into why the engine light would come on?
Thanks all...
Edit : Ok So I was able to get my car scanned with a vag-com cable the results are below
VCDS Version: Release 11.11.0 (x64)
Data version: 20111111
Tuesday,10,July,2012,19:52:28:37412
Chassis Type: 8T0
Scan: 01 03 05 06 07 08 09 0E 10 15 16 17 19 1E 36 37 42 46 47 52
53 55 56 57 77
VIN: WAUZZZ8T58A022238 Mileage: 178700km/111039miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAPA) Labels: 059-907-401-CAP.clb
Part No SW: 8K0 907 401 F HW: 8K0 907 401
Component: 3.0TDI EDC17 H01 0002
Revision: --H01---
Coding: 0114002C180F0118
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM30LTDIA5 A02002
ROD: EV_ECM30LTDIA5.rod
VCID: 2E597F1C710C5AE
2 Faults Found:
5308 - Throttle Body Actuator Bank 1 (J338)
P0638 00 [175] - Implausible Signal
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 11
Mileage: 178564 km
Date: 2012.07.06
Time: 11:27:03
4986 - Glowplug for Cylinder 3 (Q12)
P161C 00 [047] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 178564 km
Date: 2012.07.06
Time: 11:28:53
Readiness: 1 1 0 0 0
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 N HW: 8K0 907 379 N
Component: ESP8 quattro H03 0210
Revision: -------- Serial number: --------------
Coding: 1B4500
VCID: 448D3DB4C780C0E
No fault code found.
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 289 C HW: 8K0 907 289 C
Component: BCM2.01 H38 0253
Revision: 00003002
Coding: 031000
VCID: 39735C40B0428D6
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H34 0050
Subsystem 2 - Part No SW: 8K0 905 852 C HW: 8K0 905 852 C
Component: ELVAUDIB8 H35 0039
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 8T0 959 760 B HW: 8T0 959 760 B
Component: MEM-BFS H09 0043
Revision: AA000000 Serial number: 00001001049374
Coding: 08217025002444111000
VCID: 42813BACDD94CEE
Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
Part No SW: 8T0 035 729 F HW: 4E0 035 729 A
Component: Interfacebox H43 4690
Revision: 00000000 Serial number: 331KT077515644
Coding: 0005002
VCID: 3C7D45547F70B8E
Part No: 8T0 919 609
Component: E0380 BedienteilH08 0100
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T2 820 043 N HW: 8T2 820 043 N
Component: KLIMA 3 ZONEN H05 0120
Revision: D1000000 Serial number: 0112.11.070213
Coding: 36060000
VCID: 3D7B4850A46AB16
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H21 0253
Revision: 05021001 Serial number: 00000000054356
Coding: 260050910014AF010009000300005D5D0F1D038800010141000000
Shop #: WSC 00763 210 91830
VCID: 3065616463384CE
Subsystem 1 - Part No SW: 8T2 955 119 B HW: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 271007 H11 0040
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0002
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
1 Fault Found:
01496 - Bulb for Fog-Lamps; Left (L22)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 165
Mileage: 168428 km
Time Indication: 0
Date: 2012.01.18
Time: 12:53:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 8T2 035 110 B HW: 8T2 035 110 A
Component: MP3-Changer H42 0380
Revision: 00042002 Serial number: AUZ5ZBG4532141
Shop #: WSC 00000 000 00000
VCID: 2A51730C85E436E
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 C HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0010
Revision: 11001001 Serial number: 75230732507851
Coding: 100001
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H23 0409
Serial number: 0038JD11EB4V
Coding: 30323433363030303030554A305238543053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02001
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 3C7D4554B770B8E
Crash sensor for side airbag; driver side:
Serial number: 6334MSME31510E7DH
Crash sensor for side airbag; passenger side:
Serial number: 6344MSME32024C186
Crash sensor for side airbag; rear driver side:
Serial number: 6352QSME46224569F
Crash sensor for side airbag; rear passenger side:
Serial number: 6362QSME462431198
Crash sensor for front airbag; driver side:
Serial number: 63732SME427A496B9
Crash sensor for front airbag; passenger side:
Serial number: 63832SME3D702E433
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H10 0012
Revision: -------- Serial number: 90304GK800090
Coding: 000016
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8T0 920 981 B HW: 8T0 920 981 B
Component: KOMBIINSTR. H28 0214
Revision: 00100000 Serial number: 71Y15AUA7
Coding: 2F05010002002600010000
VCID: 3B7F4648BA7EBF6
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 F HW: 8T0 907 468 F
Component: GW-BEM 4CAN-M H07 0084
Revision: EB002032 Serial number: 3200E07A178202
Coding: 000003
Shop #: WSC 00565 210 66245
Subsystem 1 - Part No SW: 8K0 915 181 HW: 8K0 915 181
Component: J367-BDM H06 0150
Address 1E: Media Player 2 (R192) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 B HW: 4E0 035 785 B
Component: SG ext.Player H15 0700
Revision: 00000000
VCID: 27578A3856F60B6
Address 36: Seat Mem. Drvr (J136) Labels: None
Component: MEM-FS H09 0043
Revision: AA000000 Serial number: 00001001049315
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 T HW: 4E0 919 887 M
Component: MNS ECE H50 1030
Revision: 00000000 Serial number: 333KZ077526907
VCID: 3E794F5C696CAAE
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 HW: 8K0 959 793
Component: TSG FA H09 0149
Revision: Serial number: Gxf
Coding: 011C022250012201
VCID: FDFB085064EAF16
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00003002 Serial number: 0107600570
Coding: 011B0682003904C0002000
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0030
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Address 47: Sound System (J525) Labels: 8T0-035-223-ASM.clb
Part No SW: 8T0 035 223 P HW: 8T0 035 223 A
Component: DSP STD H07 0250
Revision: S2400000
Coding: 010101
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 HW: 8K0 959 792
Component: TSG BF H09 0149
Revision: Serial number: Tvf
VCID: FCFD05547FF0F8E
Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb
Part No SW: 8K0 907 801 C HW: 8K0 907 801 C
Component: EPB Audi B8 H03 0040
Revision: 00000003 Serial number: 00000000033519
VCID: 2F6762187E06536
Address 55: Xenon Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 A
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000002
VCID: 336F6E68522E776
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 336KZ077525284
Coding: 0000001
VCID: 2E597F1CB90C5AE
Address 57: TV Tuner Labels: None
Part No SW: 4E0 910 148 C HW: 4E0 919 148
Component: R0078 TVhybridTuner 0400
Revision: R0H06000 Serial number: 76300800993402
Coding: 0000203
VCID: 234F9E28E2CEE76
Address 77: Telephone Labels: 4F1-910-336.lbl
Part No SW: 4F1 910 336 C HW: 4F1 862 335
Component: BTA H10 0960
Revision: 00H10000 Serial number: 00000007547297
Coding: 0010021
VCID: 244D9D34E7C0E0E
End ---------------------------------------------------------------------
Does this mean anything to anyone? It certainly doesnt here.
I also managed to pull off some further info on the DPF.
20:35:56
0.00 % Air conditioner fan activation 006
279.6 mg/stroke Specified air mass 007
0.00 % EGR valve feedback 033
6 hPa Particul.filter diff.pressure 071
33.2 degC Exhaust gas temperature before particulate filter 074
18.5 degC Coolant temperature at radiator outlet 075
-0.34 mg/stroke Cylinder 3 injection quantity variation 081
28.04 g Soot mass measured 118
33.02 g Soot mass calculated 119
Car Audi A5 3.0 TDI
Year : 57
Thanks all...
Chassis Type: 8T0
53 55 56 57 77
Revision: --H01---
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 11
Mileage: 178564 km
Date: 2012.07.06
Time: 11:27:03
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 178564 km
Date: 2012.07.06
Time: 11:28:53
Coding: 1B4500
Revision: 00003002
Coding: 031000
Coding: 0005002
Coding: 36060000
Coding: 00FD11
Coding: 02532C
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 165
Mileage: 168428 km
Time Indication: 0
Date: 2012.01.18
Time: 12:53:00
Coding: 100001
Coding: 000016
Coding: 000003
Revision: 00000000
Revision: S2400000
Coding: 010101
Coding: 0000002
Coding: 0000001
Coding: 0000203
Coding: 0010021
20:35:56
