Afternoon all!
Does anyone have a wiring diagram for the brake wear sensor (/ABS) loom in the nearside wheel arch?
I'm actually interested in where the 2 wires from the brake wear sensor end up inside the car. I've got a current flow diagram which suggests they make their way to the J519 connector (which is behind the driver's side dash lower trim I think?).
Basically I've got an issue with the brake wear indicator lamp coming on every drive, though normally only once the wheels are turned. The pads are fine and I've tried bridging the connector so it seems there's a fault in the wire somewhere; I just want to be able to buzz it out to confirm before I replace the harness.
Thanks for any help!
J
J
