Brake pads warning
17K views 15 replies 6 participants last post by  moominjuice
#1 ·
as seen from the picture, my brake pads are giving me a warming.
but which one(s) ??
I would expect to have an error in VCDS, but no such thing.
did look at the meas.blocks values, but nothing there.
so, how do I find out which blocks are worn ??
or at least if it is front or rear ??
Discussion starter · #3 ·
oh, ok :)
for now I have disabled the warning.
Discussion starter · #6 ·
I will inspect the pads visually.
but you can only do this on the outside of the car.
will the inside pads be more or less the same ??
Discussion starter · #7 ·
the visual inspection show ca. 3 mm in the front and 4 mm in the rear.
not bad for 125.000 km :)
what would the original thickness of new pads be ??
Discussion starter · #11 ·
I have my own VCDS-cable, so that would be the way to go :)
but thanks for the heads up :thumbsup:
