21 - 40 of 49 Posts
@Rick Crann -- I believe A3 models got the next generation MIB MMI systems before the B9 A4/A5/Q5 models (starting in MY2016 for EU/RoW). If the software version in your S3 doesn't start with "HN+", you're in the wrong place (and the process described by @mubmoh does not apply to your cars). --g
to add to previous post…
I went through “standard” option to install both firmware & then maps. Followed to the instructions given in notes.
do I have to go through “user defined” option & select all application for UK maps?
after installation (took only 5 minutes) it doesn’t show Nav version.
mid there something I am doing wrong?
plz help
Thanks for this post - I have exactly the same issue with a recent A1 import from Japan, namely the radio and sat nav don't pick up UK stations/locations. Could anyone recommend someone in the South West (UK) who might be able to do this work for me as i don't have any of the kit/software required. Many thanks in advance.
Hi did you find a solution to your Japanese import issue?
Thanks for the thread and all the information. The job has been complete (and hopefully stays so)! The car is on media version HN+EU_AU210_K09000 and has been successfully converted. The radio stations now come up by name thanks to this update, everything is in English (+ optional ROW language) and info page doesn't have static freq anymore either. View attachment 184165 View attachment 184162 View attachment 184163 View attachment 184164
Shout out to @congo for providing the DL links, and also @DrGER whose comments throughout the threads (across the years) really gave me insight. I have learnt a lot through the process of this. Also there were many other contributors who shared useful information in snippets, once you go through them all you can build a great picture.
Here are images of the Japanese MMI unit if anyone is interested.
View attachment 184167 View attachment 184166 View attachment 184168
Assalam brother,
Hope you are fine. I am having same issue as you had, icon without text. Now I got OBD11 pro, plz tell me how to resolve this issue.
Language HMI system en_JP
language NAVI TTS: en_JP
What update or coding did you apply to resolve this issue?
Look forward to your reply.
Thanks.
The Japan radios although they can be converted are not tuned for the full frequancy range here in the UK. I have done a tonnnn of Conversions and always the same. Although you can select the channels the reciever itself is not tuned for the additional frequncies. Most with 3G+ just live with it because of the bluetooth streaming available to those units. With 3G High units we normally replace the radio with a UK spec one with DAB.
Hi guys new to this forum. I have bought a 2016 Audi Q3 Jap import here in Ireland. Radio frequency in Japanese. Any idea how a novice with limit tools can change the frequency to irish frequency
Welcome. I assume you read this thread. It’s not a straight forward task.
Hi, looking for someone to convert 3 Jap Audi imports A1, A4 and Q5, could you get in contact with me DavidB8 please. Just signed up to the forum but it will not let me send you a private message
I have read it can be done with OBD Eleven kit and app but not sure if need to pay fro subscription to access the necessary functions to carry out the radio change from Japanese to Europe. I have a youtune vid, and if anyone can say this works or don't work or do i need to pay subscriptions fee.
I have a Japanese Audi A1 Import car 2012 3 Door White. My MMI should be replaced to UK unit. I would like to get some suggestion from you because I am really struggling to find the replacement one. Let me know if i can get some help and I have spent more than 6 months sitting out this. This is my last hope.
All the UK units have the same pins
Only German and Japanese units are same like mine
The orange cable which is plugged in is the new one and the cables are different in the Japanese unit
Looking for eeprom dump for A1 JP , @mumboh would you have a back up by any chance ? This thread has been very helpful in identifying issues with the unit. The car has been bought with broken mmi unit and no comms via vcds . Serial connection and flashing firmware did not help. Eeprom showed no data which is odd ... so can't take a back up. I would seem that there was some sort of issue with battery also as it was fully drained when car arrived- not sure if it is related.
Found donor eeprom dump.
Attempting to flash with correct language in eeprom yielded some results but not successful . I suspect some hardware issues with the unit , given the below error aswell as the fact that MOST was not available from the start so no VCDS ( although could be broken circuit (?) ). Anyone has any clue / guidance what could be wrong with the unit so atleast know wheather to continue or donate it for parts :) @DrGER would you know if 3GP units prone to memory failures ?
Error :
Bash:
[t(p) usr/bin/slogger 16390 1 21 7034deb6]
Boot timed out
ERROR: Memory Mapping allocation failed hMemory=0 dspAddr=0x0 length=1724
*** ERROR: nvTiInit: nvDspAllocateMemmap failed
** nvTiInit Failed
ERROR: Version mismatch between host and DSP binaries (Host API rev 3022, DSP API rev 0)
checkFreeMem: problem getting system time.checkFreeMem: no log to rotate.
Audi 3G+ dumper: dumping to /HBpersistence/core/io-media-nvidia.core.gz
Full log :
Bash:
IPL: Audi 3G 9308 (SH7785) / QNX 6.3.0 [PL_qnx_ipl-3g_9308-sh7785_08253A, built 2008/06/18_15-16-25_UTC]
CPU: SH7785 (>= 5th cut, clk mode 20. 4xDDR), 792MHz
RAM: 512 MB (probed, DBCONF=e30002)
FLASH: Spansion S29GL512N (32bit): 512 sectors x 256K
FPGA: PL_MMI3G_PLUS_FPGA_9411_D1_11384A (0ms)
*** Old-fashioned mark found on IFS @0x1c0000: .zero=0x30000013
*** Old-fashioned mark found on IFS @0x680000: .zero=0x10000000
starting image @680000 ...
Startup: PL_qnx_startup-sh7785_11292A, built 2011/07/19_08-03-38_UTC
RAM  : 128 MB @0x08000000
RAM  : 128 MB @0x40000000
NVRAM: 36 MB @0x5dc00000
RAM  : 220 MB @0x50000000
FLASH: 128 MB @0x00000000
FPGA IRQ: Interrupt Controller ID:33 Ver:2.1.0 ILVL:7 Lines:255
System page at phys:0800a000 user:0800a000 kern:8800a000
Starting next program at v8804aae0
Welcome QNX6.3.2 (QNXLabel RL_qnx_os_632_PSP3_08041A)- Harman/Becker MMI3GP Build 9436 C1 D1-12321A
USB-stuff (QNXLabel RL_qnx_os_632_PSP3_08041A)
# NV: Waiting for the minirm init done indication file /dev/shmem/nvminirm.finished'
NVLOADER: Booting DSP (DRAM Setup time = 1000 us)...
DM642 Init failed after retrying max reset cycles
NVLOADER: Going to call nvTsrmRawLoad for file /etc/NvDspCodecs.elf
NVLOADER: Done
Enabling DMA using channel 11
Overriding default Interrupt Priority
Current debug level = 0x7fffffff
dmaChannel = 11, interrupt thread priority = 21
devg-NVMEM: Mapped vaddr 0x38100000 to paddr 0x5d597000
[pcidma] PL_qnx_pcidma_FMod08363A_09274A, built 2009/07/02_11-10-37_UTC
multicored [000000001.570]:version 4.6.d, verbosity 1 (supported 4), scope 0x00000001, console: /dev/ser1 (fd=3), FILE_LOGGING, TESTCONTROL, DYNAMIC_LOAD
multicored [000000001.573]:using 750 buffers of size 1460 (total  1095000 bytes)
multicored [000000001.616]:version 4.6.d, verbosity 2 (supported 4), scope 0x00000001, console: /dev/ser1 (fd=3), FILE_LOGGING, TESTCONTROL, DYNAMIC_LOAD
multicored [000000001.637]:udp: broadcaster created
multicored [000000001.645]:attached to filesystem at /hbsystem/multicore, port 851
multicored [000000001.662]:MACHINE:SH(1), total MEM 499122176, 1: 271582976 SH7785 (SH4A) 792MHz, FPU
multicored [000000001.668]:sloop active
multicored [000000001.670]:lo0    127.0.0.1    255.0.0.0
multicored [000000001.671]:pflog0    0.0.0.0    0.0.0.0
multicored [000000001.698]:listener_activate()
multicored [000000001.700]:listener on port 851 active, fd=7
Mask = c3
GPIO 7 set to Low
dev-nvram: PL_qnx_dev-nvram_07225A, built 2007/06/01_15-44-08_UTC
dev-nvram: page_size:4096
dev-nvram: signalling register 10ee:9411:0:40:40 [vid:did:bar:offs:mask]
dev-nvram: CPU: SH7785 (5th cut or higher, clk_mode 20) [10300700:250, 133735fa]
dev-nvram: map '/dev/nvram/navi' to 0x5dc00000-0x5fffefff
dev-nvram: map '/dev/nvram/.guard' to 0x5ffff000-0x5fffffff
dev-nvram: SelfRefresh was inactive
UART: Mod:0E Date:09503A Ver:2.2.2
devc-ser8250hb: UART supports FiFo counter
devc-ser8250hb: UART supports 32bit access
devc-ser8250hb: RX_FIFO_SIZE:2048 TX_FIFO_SIZE:2048
devc-ser8250hb: set IBUF size to 16384
devc-ser8250hb: RX_FIFO_SIZE:512 TX_FIFO_SIZE:512
devc-ser8250hb: RX_FIFO_SIZE:32 TX_FIFO_SIZE:32
Debug filehandle = 4
For further debug messages have a look at multicore output consoles '/hbsystem/multicore/navi/g'
[pcidma] PL_qnx_pcidma_FMod08363A_09441A, built 2009/10/26_07-46-16_UTC
mam0 available
NAVI: sys_alloc_shm_area(/dev/nvram/navi) open() ok: 9
NAVI: sys_alloc_shm_area(/dev/nvram/navi) filesize() = 37744640
NAVI: sys_alloc_shm_area(/dev/nvram/navi) mmap to 38100000
NAVI: sys_alloc_shm_area(/dev/nvram/navi): physical of 38100000 at 5dc00000
[t(p) usr/bin/pci-sh7785 24586 2 21 703494c0]
[t(p) usr/bin/pci-sh7785 24586 2 21 7033497a]
[t(p) usr/bin/slogger 16390 1 21 70314106]
[t(c) usr/bin/pci-sh7785 24586 2 21 7033517a]
Path=0 - XILINX ATAPI
target=0 lun=0            CD-ROM(5) - FJ-TEN   DVD-ROM DV-04FT1 Rev: 1423
Path=1 - XILINX ATAPI
target=1 lun=0     Direct-Access(0) -          TOSHIBA MK6050GA Rev: TJ10
[t(p) usr/bin/pci-sh7785 24586 2 21 8041c98]
[t(p) usr/bin/pci-sh7785 24586 2 21 7033517a]
[t(p) usr/bin/pci-sh7785 24586 2 21 70313864]
[t(p) usr/bin/pci-sh7785 24586 2 21 8041e28]
checkFreeMem: giving up searching for process pids
***          Online Speech          ***
***          EncodeStream           ***
***             v1.0.02             ***
[t(p) usr/bin/slogger 16390 1 21 70320400]
[t(p) usr/bin/pci-sh7785 24586 2 21 70346ba0]
[t(p) usr/bin/pci-sh7785 24586 2 21 804e730]
[t(p) usr/bin/slogger 16390 1 21 7034dcd0]
[t(p) usr/bin/pci-sh7785 24586 2 21 7035f38c]
cd0 mounted after 1 try
[t(p) usr/bin/pci-sh7785 24586 2 21 70313a74]
checkPersistence: found efs-dump.gz in /mnt/persistence.
[t(p) usr/bin/slogger 16390 1 21 70320412]
[t(p) usr/bin/pci-sh7785 24586 2 21 7034963e]
[t(p) usr/bin/slogger 16390 1 21 70334eb4]
[t(p) usr/bin/pci-sh7785 24586 2 21 70346240]
[t(p) usr/bin/slogger 16390 1 21 7031f500]
[t(p) usr/bin/slogger 16390 1 21 703147f4]
multicored [000000041.882]:startup phase ending for 0
[t(p) usr/bin/slogger 16390 1 21 7032f5e8]
[t(p) usr/bin/slogger 16390 1 21 70313a78]
[t(p) usr/bin/pci-sh7785 24586 2 21 7035f3a8]
[t(p) usr/bin/slogger 16390 1 21 7035f396]
checkFreeMem: CPU-load at 100% and above 95% during 8 cycles - starting hbhogs (mark 1)
[t(p) usr/bin/pci-sh7785 24586 2 21 703494a4]
[t(p) usr/bin/pci-sh7785 24586 2 21 7035fa62]
Load      Pid   Tid Prio Name
62.6%   24586     2 21r pci-sh7785
26.0%   16390     1 64r slogger
8.6%   36893     1 10r devg-NVTS
0.7%   69668     1 11r ndr
0.3%   32790     2 21r io-pkt-v4-hc         io-pkt#0x00
0.1%   40994     4 18r vdev-flexgps
0.1%   32791     2 10r multicored           ResMgr
0.1%   81960    15 11r NavCore              NavCore_SQA_NavCoreLoader
0.1%       1    10  0  procnto
0.1%   81960    18 10r NavCore              NavCore_ZLF_NavCoreLoader
High system load. Available CPU : 0.000000 %
[t(p) usr/bin/slogger 16390 1 21 8040cd4]
[t(p) usr/bin/devg-NVTS 36893 1 10 8044c34]
[t(c) sbin/io-media-nvidia 53287 1 10 703351b6]
[t(p) usr/bin/pci-sh7785 24586 2 21 7034dc20]
[t(p) usr/bin/pci-sh7785 24586 2 21 8041e20]
[t(p) usr/bin/pci-sh7785 24586 2 21 7032ac34]
[t(p) usr/bin/pci-sh7785 24586 2 21 70346206]
[t(p) usr/bin/slogger 16390 1 21 7033eb3a]
[t(p) usr/bin/slogger 16390 1 21 7033ebf6]
[t(p) usr/bin/pci-sh7785 24586 2 21 703135b8]
[t(p) usr/bin/slogger 16390 1 21 7033f794]
[t(p) usr/bin/devg-NVTS 36893 1 10 703523a0]
[t(p) usr/bin/pci-sh7785 24586 2 21 70313a78]
[t(p) usr/bin/pci-sh7785 24586 2 21 7034983e]
[t(p) usr/bin/pci-sh7785 24586 2 21 7032ade0]
[t(p) usr/bin/slogger 16390 1 21 70352450]
[t(p) usr/bin/slogger 16390 1 21 7033f200]
multicored [000000090.617]:full buff 1460, curr 0198 --> sock 0200
[t(p) usr/bin/slogger 16390 1 21 7031f726]
[t(p) usr/bin/pci-sh7785 24586 2 21 70349612]
[t(p) usr/apps/NavCore 81960 16 12 7034e9f0]
64.7%   24586     2 21r pci-sh7785
23.8%   16390     1 64r slogger
8.4%   36893     1 10r devg-NVTS
1.4%   69668     5 18r ndr
0.3%   32788     1 18r dev-ipc
0.2%   32790     2 10r io-pkt-v4-hc         io-pkt#0x00
0.1%   32791     1 11f multicored           SocketLoop
0.1%   81960    12 11r NavCore              NavCore_CDM_NavCoreLoader
[t(p) usr/bin/pci-sh7785 24586 2 21 7035f3a4]
[t(p) usr/bin/pci-sh7785 24586 2 21 804ea6e]
[t(p) usr/bin/devg-NVTS 36893 1 10 8044c2a]
[t(p) usr/bin/pci-sh7785 24586 2 21 703494b4]
[t(p) usr/bin/devg-NVTS 36893 1 10 7031df60]
[t(p) usr/bin/slogger 16390 1 21 7033f388]
[t(p) usr/bin/pci-sh7785 24586 2 21 7034964e]
[t(p) usr/bin/pci-sh7785 24586 2 21 70335170]
[t(p) usr/bin/pci-sh7785 24586 2 21 7033498a]
[t(p) usr/bin/slogger 16390 1 21 7034de82]
[t(p) usr/bin/pci-sh7785 24586 2 21 80417ae]
[t(p) usr/bin/pci-sh7785 24586 2 21 70336266]
[t(p) usr/bin/slogger 16390 1 21 804123e]
[t(p) usr/bin/pci-sh7785 24586 2 21 703494d0]
[t(p) usr/bin/devg-NVTS 36893 1 10 80414ac]
[t(p) usr/bin/pci-sh7785 24586 2 21 804ea00]
66.5%   24586     2 21r pci-sh7785
24.9%   16390     1 64r slogger
6.9%   36893     1 10r devg-NVTS
0.2%   32790     2 21r io-pkt-v4-hc         io-pkt#0x00
0.1%   69668     1 11r ndr
0.1%   32788     2 21r dev-ipc
0.1%   69668     4 18r ndr
0.1%       1     7  0  procnto
0.1%   81960    16 12r NavCore              NavCore_SOB_NavCoreLoader
0.1%       1     4  0  procnto
[t(p) usr/bin/pci-sh7785 24586 2 21 703495e0]
Boot timed out
** nvTiInit Failed
/HBpersistence/core/io-media-nvidia.core.gz: Read-only file system
Could not write to default logfile location
checkFreeMem: problem getting system time.Time of Dump: ���@��,_���@|6_���
Process 53287 (io-media-nvidia) terminated SIGSEGV code=1 fltno=11 ip=08154d06 ref=00000004
checkFreeMem dumping 2048 bytes of serial log
core dumped for pid 53287
sh: no closing quote
Open connection to '/dev/irc'...
Inside Open to
ircCtrl: Flush_Files_Ready failed with err=-4
closed.
ircCtrl writes control commands to infotainment device.
ircCtrl Device Command [arguments]
Command =
    Notification [configFile] U16functionID U32NumberOfEntriesToRead
         Register for some log and reads a number of entries.
         Filter settings in config group "SLogReader" is used for
         functionID mapping (as for dev-irc config).
         If no config is given, the default functionID mapping is used.
    GetBlockInfo
    GetLogfile U16FunctionID U8Instance U16BlockNb
    Startoperation U16FId U16Parameter
         Starts an internal operation.
          0x502 = SessionControl 1 = start
                                 2 = stop
          0x503 = LogFileInit    FId
          0x504 = SaveLog        FId
    Data
    Error
    Status
    write_Misc source type message
    Flush fluhs IRC log, wait for finished
i.e.: ircCtrl /dev/irc Status
WARNING: NON PERFORMANT MODULAR STARTUP!!!
DSIVersion: 0.0.0
DSISource: DSI 2012_26_26
DSI-Build-Version: Mon Jun 25 11:24:44 CEST 2012 / DSIGEN v1.138.4
ReleaseLabel: Int_AU210_EU_SOP9_12272P
start JDSI bundle
[t(p) j9/bin/j9 200707 10 10 8c7fbf8]
HBTRACE: jdsi.verboselevel = null => verbose-level = 0 because property not set or invalid
jdsi.loglevel : 2
No External Component found
stream factory memory mode : no pooling
dsigen v1.138.4 - core v2.1
prop os.arch : sh4
prop jdsi.3SoftOSGi : true
DSI dispatcher disabled!
[t(p) proc/boot/procnto-instr 1 1 0 8807922e]
checkFreeMem: process 'io-media-nvidia' monitored, error 2 (No such file or directory)
Inside Open to
closed.
Command =
    GetBlockInfo
                                 2 = stop
          0x504 = SaveLog        FId
    Data
    Error
    Status
checkFreeMem: process terminated, send SIGABRT to applications
multicored [000000160.138]:full buff 1460, curr 0323 --> sock 0324
[t(p) proc/boot/procnto-instr 1 1 0 88073440]
checkFreeMem: Debug thread hanging since 10 ticks
checkFreeMem FATAL ERROR: watchdog triggered for debug thread
checkFreeMem: Debug thread hanging since 11 ticks
checkFreeMem: Debug thread hanging since 12 ticks
checkFreeMem: Debug thread hanging since 13 ticks
checkFreeMem: Debug thread hanging since 14 ticks
checkFreeMem: target reset failed. killing more processes.
Based on these pictures Which connection is for GPS Antenna ??
@frank087234 -- Your A1 main unit has FAKRA HSD connectors for the display (gray) and USB/iPod data (curry), and the coax GPS cable (blue). If the car is configured for nav, you should find the blue GPS connector in the space behind the main unit in the instrument panel. --g
Yes the blue connector is present at back of unit but nothing attached to it..I think the lead attached is missing or removed by the car dealer. I want to know how it looks like from both ends so I can order it.
Thank you
The Fakra connectors are crimped on using special tools. You can buy a fakra extension (green connectors) that have a universal fitting. You would have to solder the connection but it may be subject to interference unless its screened correctly.
21 - 40 of 49 Posts
