3.0 TDI How important it is to replace fuel filter?
33K views 5 replies 2 participants last post by  gtx2010
#1 ·
3.0 TDI How important it is to replace fuel filter? I know during fuel filter replacement if you don't run the pump with VCDS then you may damage high pressure pump and injectors which needs diesel for lubrication. If you don't replace fuel filter then what problem it can cause?
Discussion starter · #6 ·
Done this using VCDS, exact instructions I followed from ross-tech
Fuel Pump Basic Settings for PD, PPD, and CR TDI Engines
The CR (Common Rail) TDI engines should not be operated without fuel which may be an issue after repairs such as fuel injector and fuel filter replacement. The electric fuel pump, located in the fuel tank or externally mounted in-line, can be operated via basic settings to fill the system.
These instructions do NOT apply to the VE TDI Engines.
The PD and PPD TDI engines are not as sensitive to low fuel volume however those engine management systems typically include provisions for electric fuel pump priming.
Prerequisites:
Ignition On, Engine Off.
Battery voltage at least 11.5 V
Fuel tank has a sufficient level of fuel
Contents [hide]
1 Fuel Pump Basic Settings
1.1 Special Notes
[Select]
[01 - Engine]
[Basic Settings - 04]
Set Group to "035" if Available. Substitute using the details in the Special Notes section when needed.
[Go!]
[ON/OFF/Next]
The electric fuel pump should run for 30 seconds
If the vehicle had a simple repair such as a fuel filter that should be a sufficient amount of time for the filter to fill up.
If the engine had extensive repairs such as injector replacement and/or fuel system flushing this process should be repeated no less than 3 times. Click [On/Off/Next] to reinitialize the process if needed.
[Done, Go Back]
Special Notes
If the vehicle uses the latest KWP-7000 (UDS/ODX) engine controller, conventional Basic Setting group numbers do not apply. Instead, choose the Transfer Fuel Pump (FP) test or similar operation from the drop down menu followed by [Go!] to activate the Basic Setting. The EDC should display "Running" and the electric fuel pump will run. After the result of Finished Correctly appears click [Stop].
In my case I didn't have any option to set group 35, instead I had to choose " Transfer Fuel Pump (FP) test" from drop down list under basic settings
