No, my iPhone is synced with my Exchange server.
No, my iPhone is synced with my Exchange server.updated to 4.3.1 and i still have the issue, quick question, do you sync your iphone contacts with MS exchange? or do they sync via itunes directly with outlook? I'm beginning to think it's because I have contacts enabled on my exchange account on the phone that causes the problem... this is damn frustrating![]()
I've now deleted any additional contact folders/groups other than the primary off my exchange account, and still refuses to sync a single contact, I don't get how you get yours to work.....No, my iPhone is synced with my Exchange server.
I already tried that:If we think about this logically the only think that is different between us all is the contacts. To test I would do a factory reset on the MMI, then backup and delete all you contacts on your iPhone (for testing sake a would format and set the iPhone up as a new phone, don't restore from backup) then add 1 contact and try to pair with the MMI and see if it syncs. It could be a character within one of the contacts which causes the MMI to throw a hissy fit ( technical term ;0) )
When i restored the iphone i did it as a new phone, not from the backup.I have restored my iphone and adding only one contact to see if it could sync, but it still displays that circle clock. I have restored it many times and it still does not sync my contacts. I also deleted all profiles, previous paired devices of the mmi and set all settings back to default of the mmi.
been throuhg all of the above in various orders and levels of frustration, no luckIf we think about this logically the only think that is different between us all is the contacts. To test I would do a factory reset on the MMI, then backup and delete all you contacts on your iPhone (for testing sake a would format and set the iPhone up as a new phone, don't restore from backup) then add 1 contact and try to pair with the MMI and see if it syncs. It could be a character within one of the contacts which causes the MMI to throw a hissy fit ( technical term ;0) )
what part of the world are you in? I'm starting to suspect the firmware release is slightly different depending on region...No, my iPhone is synced with my Exchange server.
Warren - who hopefully doesn't mind me butting in - is in UK, as am I, and likewise not experiencing any issues at all. Updated to latest version earlier this week and all seems fine.what part of the world are you in? I'm starting to suspect the firmware release is slightly different depending on region...
which might explain things, and thanx for butting in, I'm in the USA.. i suspect the firmware is *slightly* different, the map data definitely is, and, i suspect you guys may have had a map update in the last year? we've not had map updates in a year and a halfWarren - who hopefully doesn't mind me butting in - is in UK, as am I, and likewise not experiencing any issues at all. Updated to latest version earlier this week and all seems fine.
hi 3space, the company did the install by pulling the cable that is in the glove compartment into the dash and routing it through the center console with an extension into the compartment in between the two front seats, no special dock or anything, just a free cable that connects to the iphone, will take some pics if you really want some but nothing special to see reallyHey theron.roland,
Can you post a pic of what you mean about the custom routing of the iPod cable to the centre console? Or at least describe what they did? Do you have some kind of dock, or is it just the loose cable? By centre console, do you mean the arm rest location, or more in the centre dash?
Thx!
iPhone bluetooth phonebook contact sync issues resolvedanyone have ANY luck syncing contacts yet? it's been months now and I still can't get my contacts onto my MMI![]()
This should happen automatically. Try checking both bluetooth setting screens on iphone and MMI system if there is some setting like auto discover or something. Mine automatically connect when I hop in the car and turn the egnition on.I've been syncing/ pairing my iPhone and my A5 every time I get into the car. Is there a way for them to automatically pair when they're both on and within range?
Hello theron.rolandhi 3space, the company did the install by pulling the cable that is in the glove compartment into the dash and routing it through the center console with an extension into the compartment in between the two front seats, no special dock or anything, just a free cable that connects to the iphone, will take some pics if you really want some but nothing special to see really
hey Keef, check on amazon for iphone sync extention cables, basically has a male sync port on the on end and a female on the ohter, I bought two of these, chained them together, and plugged the female end into the male end from the short cable connected to the carHello theron.roland
I’m new to this forum (to be honest I’m an A4 owner!!)
I hate the fact that the AMI is in the glove box and not in the arm rest (which IMO is where it should be for iphone users)
So I’d be interested to know more about the custom cable, how is it connected to the original 'short' ipod AMI cable?
I’ve tried all sorts of dock extension cables but none of them work and
I’m thinking about getting the kufatec extension cable:-
KUFATEC GmbH & Co. KG - Audi AMI/ VW MDI Verlngerungskabel 37010
But this is only 800mm long and for that price I might make some enquires about a custom cable
Keef
hi boozeman, could you describe exactly what you do to sync/pair each time?I've been syncing/ pairing my iPhone and my A5 every time I get into the car. Is there a way for them to automatically pair when they're both on and within range?
