Has this only recently occurred? Or happened since a replacement or retrofit?
~Alex
~Alex
There's actually a flap or actuator that directs the dip beam to main beam within the headlight unit itself, it is actually audible "click" sound. You'll need another person to help you listen for that sound while another is flashing the full beams on and off. If there's not audible sound then that would be your culprit and that flap is obviously stuck in full beam.Just happened, nothing has been replaced or changed on the car.
