1 - 8 of 8 Posts
Hey bud
I do not think they will fit. The hub size for A5/S5 is 66.5. This is the new size that will run through the whole Audi line once the car are updated. The prior hub size was 57.1. Thought you should know
LOL
I can not see that number. Sorry In the pic here in the forum cannot tell. But I do know the hub is 66.5 and if it says that then they will fit. BUT what about the offset? Thats a 10mm difference.
My 20" x 9.5" RS6 wheels had a 57.1 centre bore, I had them machined out to 66.5. This is a simple process that you should be able to get done at most engineering workshops or a wheel specialist will point you in the right direction.
The offset for these wheels is 36, so 35 will be fine. I actually put 25m spacers on the rear and am about to put 10mm spacers on the front. (see pic with rear spacers fitted)
1 - 8 of 8 Posts
