1 - 9 of 9 Posts
I am ordering some Asanti's for my A5 and was wondering how wide I could go on wheels and what is the maximum allowable depth of the lip i was hoping about 3-4 inches or 12cm? Please advice...anyone ASAP! I have in mind 19 x 8.5 with a 3inch lip on the back wheel and 1 inch lip on the front...what does anyone think?????
You will have no problem fitting a wheel that wide on the car. Several folks on here have installed 20 x 10" wide wheels all the way around.
And I know for a fact that you can go as wide as 11" on the rear with no rubbing issues, as I have 20 x 11" with a 3.5" lip on the rear. (Details here.) And I believe another S5 owner has installed 20 x 11" on the rear with a 5" lip, and 20 x 9" on the front.
When you spec the wheels with the manufacturer, they should be able to tell you what lip size range you have to work with, which I think will depend upon the barrel width you choose (8.5" in your case) and also the curvature of the wheel face spokes.
Is this mystery man incredibly handsome and wise beyond his years??
:p
Well, I can tell you that he does talk a lot of smack. :D
I think not only wheel width is important, but also ET (offset).
Wheel width without ET says nothing.
can i have 20" wheels if I have the drive select ption on my car???
My Audo dealer says not o get 20'wheels cause I have the drive select option on my A5 3.2. |Does anyone have 20" on their car with the drive select option. I am n Cyprus and roads are not all that great. Please opinions...cause the more i ask my audi dealer here, the less i see they know!
Your dealer is just talking. The only limitation is in the shocks. Wheels won't affect anything....
1 - 9 of 9 Posts
