1 - 15 of 15 Posts
So I've had a developing whiring noise the last few weeks and a squeal under low rev load.
I thought it was Aux belt and wheel bearing, but after Audi checked it out, they told me there's some slight movement out of tolerance in my transmission plate, and that I might have a bearing going on my nsf drive shaft output.
Unfortunately, these noises can't be pinpointed so although these issues are identified, Audi dont know if either of these issues are serious enough to make a noise, and they couldn't be replicated in the ramp, just on a road test.
Does anyone have any experience with such issues?
For background: car is 3.0 TDI, tiptronic 140,000mi, both front driveshafts and main prop shaft replaced at 101,000mi. Driveshaft owing to CV joint failing, propshaft owing to central bearing failing.
Gearbox oil changed at 110,000 mi.
Discussion Starter · #2 ·
179312
This is the open inspection plate of where I'm taking about. The output shaft on the left is the NSF driveshaft.
179313
Better view of inside the inspection plate.
179314
Audi tech pointing at the interior and saying that there's movement within there which shouldn't be there.
Dunno BUT I would want a second opinion. Go to a good independent VAG man and ask his opinion. Could be anything to be honest....
Reactions: savs
Could be a tyre. I had one starting to delaminate and it sounded like a wheel bearing failing. New tyre, no more noise
My tyres are all between 2 and 4mm and are PS4s, so they are due replacing soon. But I don't think it's that.
I have an independent VAG specialist just up the road from me, so at some point I'll book it in with them for investigation. It just feels like a lot of money to be throwing into not a lot of output, even though it needs to be done.
Reactions: SimonRoma
Good luck Max let us know what you find.....
Administrator
i didn’t think it was a tyre either. The only giveaway was the tread was not flat when you put a ruler across the width of the tyre.
Discussion Starter · #8 ·
Well, here's an update - I've opted to replace my tyres (PS4 4mm front, 2mm rear, to PS4S) as where I'm working now is much wetter and I needed the extra tread. Plus kwikfit has a 15% off when you buy all 4.
Since then, the noise has either changed and I haven't noticed it yet, or gone.
Very interesting.
I'll be getting that "longitudinal movement" in the transmission plate checked out by my local VAG garage.
Reactions: JohnS4
how interesting. my tires still have more than 50% thread left, but i do have the whiring drone between 50 -> 55 and then 70 -> 65
I'm hoping it's the tires.
I had PS3 on my B7 DTM with no issues. Then when I replaced all 4 with new PS4 I picked up a drone at 55>. I have PS4S on my A5 and no issues. So I am thinking the drone may be a characteristic of the PS4.
Discussion Starter · #11 ·
My drone was from 30mph, but you guys might be onto something with the part worn PS4 tyres.
Discussion Starter · #12 ·
Update after having had the new tyres on for 1200mi - the whiring drone was the old PS4 tyres.
Reactions: savs and JohnS4
Bloody hell! So you've gone from potential drive shaft replacement (again) to actually it was the tyres.
This is a prime example of eliminate the simple items first before thinking it's catastrophic. Good effort and feedback max2ksr!
Reactions: max2ksr
I've had similar before and it was the tyres, rub the flat of your hand over the tread in both directions if in one direction you can feel some sharper/higher blocks i think this is known as saw toothing and usually impacts rear tyres on front wheel drive cars. The tread blocks raised on the edges is enough to cause a droning. Rotate left to right on same axle and after a few hundred miles should improve, or replace tyres.
1 - 15 of 15 Posts
