I would like to buy a cable to work with ross-tech vcds software. I found 2 cables at a local store that seem to be compatible:
the one is called HEX-USB-CAN VAG-COM for 704 and has the following description: VAG-COM 704 OBDII CAN-USB V704.1 Full Compatible with the newest cars which require a direct CAN connection for diagnostics including all Golf-5 platform cars and latest Audi A3, A6 and A8,Q7,etc. Protocol timing indistinguishable from a real VAG/VAS tool. Works reliably even with "difficult" control modules such as the 1991-1994 1Z Audi TDIs and the 1993-1994 Audi 2.6L with Hella ECU. Built-In VAG-Saver functionality -- instantly alerts the user if either the K/K1 line or the L/K2 line is shorted to Ground or Vbatt. Full support for dual-K lines found in "new" (B6/8E chassis Audi A4 and 2002+ Audi A6,A8,etc. OBDII CAN-USB V704.1 Full Compatible with the newest cars which require a direct CAN connection for diagnostics including all Golf-5 platform cars and latest Audi A3, A6 and A8,Q7,etc. Protocol timing indistinguishable from a real VAG/VAS tool.
the other is called HEX USB CAN VAG-COM for 805.1 and has the following description: Compatible with the newest cars which require a direct CAN connection for diagnostics including all Golf-5 platform cars and latest Audi A3, A6 and A8,Q7,etc. Protocol timing indistinguishable from a real VAG/VAS tool. Works reliably even with "difficult" control modules such as the 1991-1994 1Z Audi TDIs and the 1993-1994 Audi 2.6L with Hella ECU. Built-In VAG-Saver functionality -- instantly alerts the user if either the K/K1 line or the L/K2 line is shorted to Ground or Vbatt. Full support for dual-K lines found in "new" (B6/8E chassis Audi A4 and 2002+ Audi A6,A8,etc.
Which one should I buy? Does anyone know the differences?
Thanks! Vangelis
Dude,
That's an unreadable post...shape it a bit otherwise nobody will be able to read it and reply...
regards
nocarder
