Fitted some 3mm wheel spacers to provide a bit more caliper clearance to go with my 20" Vossen VS1 (1mm was a little close for my liking).
When fitted the wheel spacer is not the same diameter as hub and wheel face so there is a visible gap as if the spacer needs to be another 25mm in diameter, ie the wheel face is not fully supported. While i'm sure it wont flex that much, I unsure if this is a safety issue or not.
Is this an issue ? (left is how it mounts, right is how I think it should be)
