1 - 9 of 9 Posts
I have a feeling I'm going to feel stupid with this one, but....
When I open the car door there is noise that lasts for 4 or 5 seconds. It sounds like a little electric motor moving something but for the life of me I can't suss out what it is. Anyone know?
Thanks in advance.
JTR
You're not the only one. I've always wondered about that sound too. In addition to what you described, there is also a faint, high-pitched sound that I hear during that short duration. Would love to know what that is all about.
This answer is based on the behavior of my wife's Eos, with the 2.0T FSI engine. But I imagine it's the same behavior for all modern VAG cars.
The "electric motor" sound you get when you open the door is likely the fuel pump starting up to pre-pressurize the fuel injectors. The car does this to make starting easier. It probably doesn't do it if you open the door again after a short time...it's only supposed to do it when the car has been sitting for a while, and allowed the fuel lines to lose pressure.
My wife's fairly old 1L polo does the same!
Good call. My Subaru would have to wait a second to start as the fuel lines pressurized. I put in a higher flow fuel pump that was louder and you could easily hear it working before it started.
Definitely the fuel pump priming the injectors -- happens when you open the front driver side door for the first time.
Ya its fuel pump. Other cars that dont power up when opening the door will make the same noise when you turn on the ignition. Its always a good idea to let the pump run before starting. Most people wouldnt let the pump run before starting so moving to door activation insures it runs fully before starting.
1 - 9 of 9 Posts
