141 - 160 of 229 Posts
I best warn brotek of the incoming flood of washer orders
Yes Merc HX on order via Brotek. 82mm TB in hand, adaptor plate and harness winging their way to me too.
Then it's porting s/c to suit, install all that with a 206mm crank pulley and 70mm gates idler, then off to MRC for them to work their magic.
Only hitch in my plan is a 3.5" intake that mates to the stock airbox.
Any ideas/tips/advice on how to achieve this most welcome.
Found this but way to much $ for my liking
GAS Titanium Supercharger Inlet Pipe, B8 S4/S5 3.0T
Sounds like a project! Can't wait to see the results! :)
Not measured it, but the stock airbox is probably around the 3.5" mark? The intake pipe increases in diameter at the airbox end.
Yeah the stock box is 3.5".
The issue is most aftermarket inlet tubes 'neck down' at the TB end.
So I'm looking for a solution that's 3.5" all the way.
Worst case I will have to use some Alu tube and silicone bends/connectors and butcher them to fit. The result may not be pleasing on the eye
Ah, ok! What about a good exhaust fabricator? Then just put silicone collars at either end? Maybe wrap it in Carbon fibre to look more pleasing to the eye? :)
Yeah I'll make some enquires with exhaust fabbers
Should have asked them to give you some commission as I think I'm pretty much sold also on it 😂
Reactions: cadguy77
I just checked these out too as the standard ones are pretty crap.
Wasn't sure if we need the spacer or not?
Anyone else know if it's needed?
No spacer needed on the B8/8.5
When you go to order from Brotek, it lists the models that these jets fit and it also mentions next to the model whether it needs a spacer, but as said we don't need the spacers. :)
2015 S5 Coupe
Look at us all getting fan sprayers.. They best be good 🤣
I dunno why, but I feel nervous y'all won't like em now
2015 S5 Coupe
They had better be good otherwise we'll send the boys round....
To be fair, I did similar on my Land Cruiser, one of the cheapest easiest and best mods to do
Early lockdown I purchased Carista, worth the money just to deactivate the start stop... Enabled auto dipping wing mirrors on reverse, added oil temperature to the display.
I had stage 1 map and egr blank end of May and now returning 30 miles more per tank.
Paint correction and wax came shortly afterwards.
Last mod will be to relocate my crankshaft pulley to its correct position
Edit
Ordered the washers also, thanks for sharing
Sent from my VOG-L09 using Tapatalk
