Hi all,
Due to extreme condensation i recently discovered my drivers side matt and carpet underneath to be soaking wet.
So far I’ve checked the drain point under the skuttle/bulkhead panel which is clear, the fuel point drain which is clear, fuse box on the drivers side which is dry, and the rear sunroof drain points which also appear clear.
I’ve seen a diagram that suggests there are front drain points on the sunroof too, but I can’t see them?! Can’t anyone confirm?
Anywhere else I should check?
Not yet sure if it’s condensation or a source, but it looks like there may have been some water coming from the bonnet latch.
Thanks!
Thanks!
