1 - 10 of 10 Posts
Hi All,
I currently have a IPE Exhaust fitted to my car but I noticed I have a resonator in my downpipe. My car is currently running MRC Stage 2 which is single crank pulley. My car only has 22k on the clock and I have no issues with my cats.
So my question is, do I swap out my downpipes for no res versions or do I got JHM test pipes and HFC?
Any help would be great.
This is what my car currently sounds like.
I only have non resonated downpipes with the stock exhaust and this made mine quite a lot louder, so if your aftermarket exhaust is louder than stock I should imagine it would be really loud with non res downpipes.
My dsg farts are now much bigger also.
I've no experience with test pipes sorry.
I think i'm tempted to do that as its much cheaper as.
Test pipes do seem better for performance but i think its over 2.5k.
I had mine made up by my indie.
He reused the original flanges and used new flexis and straight through pipes with a slightly larger bore.
Total price-£270 all in.
I'd definitely try non res downpipes first if I were you.
Any sound clips? Am lost what to do with my s5 b8.5 exhaust. Want it deeper but no rasp or drone. Was thinking x pipe baby res and straight pipe mid res. But you have straight piped the lot?
No. I've literally had the down pipes straight piped (apart from the bends lol). I still have the stock centre resonator and rear mufflers.
It's a deeper and louder sound inside the cab with more pronounced gear change farts when on the throttle, yet still quiet enough on a light throttle and cruising.
There is no drone.
It does sound raspy from outside below 3k rpm.
I'll try and sort some sound clips soon.
Best way to get rid of the rasp is to wrap the downpipes. This is best done with the pipes off, but I did mine with them on, just fiddly wrapping the top near the cat flange.
Discussion Starter #8
is this is stuff?
is it easy to do or would you get a company to wrap it?
Yep that's the stuff! Best to get the 1" wide roll so it goes round the bends easier. I got the 2" and it wasn't quite as neat on the bend due to the wrap width.
I used a jubilee clamp at the top as the stainless ties are a bit fiddly and you can't get them tight especially up near the cat flanges.
Jonse, it depends on what sound your looking for. Personally I think yours sounds ok and would opt for the same set up as smokey joe. I was one of the 1st people on here to buy an x pipe 2 weeks after it was released and I think they are great for someone with a std system who wants a bit more noise.
Removing the 2 front resonators in the downpipe is a good option as it will increase the sound without any drone.
1 - 10 of 10 Posts
