1 - 12 of 12 Posts
Hello,
I just bought a vcds cable and I want to activate myself Needle Sweep function but after I follow the tutorial i get this warning:
Mesh Textile Wood Font Wall
This appears to be an uninitialized control module; valid WSC/importer/Equipment data may be required.
Click [Yes] for VCDS to use default values of 12345/123/12345.
Click [No] for VCDS to try the values currently in the module.
Click [Cancel] to go back and manually edit the values.
I want to mention that the cable is bought from Aliexpress. It works very well on scaning the car and reset service but for coding i have this warning and I dont want to mess things up.
Any thoughts on how should I proceed?
Hiya mate sorry no idea. But do you mean that you bought a Chinese VCDS cable so what software can you use??
Buy the VCDS cable and software mate cos IT WORKS!!!!!
When I worked for a medical device manufacturer we supplied a windows based PC software to work with our devices. We offered phone help for any software problems. We were obliged to ban one doctor when we discovered that his Windows operating system was false hahahahha.
Back up the existing coding and go for it. it's pretty hard to mess up when you have a backed-up code. Trust me I have done 100's of VCDS coding and retrofits yet to have any issues.
If you need someone to hold your hand drop me a private message and I will help
1 - 12 of 12 Posts
