1 - 11 of 11 Posts
Hi folks
Installed a new battery into our 2010 A5 2.0TDI Cabriolet, and started up VCDS to update the details of the new battery. However VCDS is reporting "no response from controller". This is the 61 Battery Regulator controller. No error lights on the dash or anything, I would have expected the battery light to be lit if there was a problem with the charging circuit.
There were a lot of historical low-voltage errors which I cleared (due I guess to the old battery which didn't hold a charge well). However controller 61 still not responding.
Any ideas ? VCDS problem or car problem ?
Frank
Administrator
obviously, you don't have module 61.
my A5 does not have one either.
from the Ross-Tech manual: (http://www.ross-tech.com/vcds/tour/main_screen.html)
On some new vehicles like the 8T0 (Audi B8 platform), the Gateway Installation is not accessible via Long Coding. In such cases, use the [Installation List] button in the Open Controller screen for CAN Gateway to access this screen. This function is available in all Gateways that support an Installation list and is explained on the Installation List Page.
Long Coding. This function is needed to Code some control modules in the newest cars which use CAN for diagnostics. Due to the complexity of Long Coding strings (up to 255 bytes of hexadecimal data) we've accommodated (and urge) the use of Copy & Paste in this function and usage of the Long Coding Helper.
Here is the link to the control modules present / available to VCDS in the A5/S5... no #61.
Ross-Tech: VAG-COM: Audi A5/S5 Applications
I'd suspect you are in good shape as-is if everything works, you can do an autoscan and look for any codes if you like. Battery voltage can be checked through several (maybe all) of the controllers. Should be readily available in 01 engine for example. If the car doesn't have a separate battery reg module, there isn't any coding needed as i understand.
Thanks lads. There is a black box on the boot floor just beside the battery, but I haven't had a close look to see what it is yet. I always presumed it was the battery controller.
I cleared some historical low-voltage codes from VCDS (the car had a history of flat battery) and it all seems nice and happy with its new battery.
However there are two codes popping up that refuse to go away, see below. Nothing apparent on the dash, no warning lights or anything. I would at least have expected the red battery light to be glowing, but no.
Here's the report from the CAN gateway - what do you make of this ?
Thursday,16,October,2014,16:06:20:48569
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.3.0 (x64)
Data version: 20140822
VIN: License Plate: 10D
Mileage: Repair Order: 16-oct-2014
Address 19: CAN Gateway Labels: 8T0-907-468.clb
Control Module Part Number: 8T0 907 468 AD HW: 8T0 907 468 K
Component and/or Version: GW-BEM 4CAN-M H09 0117
Software Coding: 00CF07
Work Shop Code: WSC 02391 823 56573
VCID: 83051E7E02A8210606F-80D6
2 Faults Found:
00458 - Control Module for Battery Monitoring (J367)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 176
Mileage: 74290 km
Time Indication: 0
Date: 2014.10.16
Time: 16:04:46
Freeze Frame:
Bin. Bits: 11111
Voltage: 13.60 V
Count: 6
Bin. Bits: 10011
03705 - Voltage Regulator
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 176
Mileage: 74290 km
Time Indication: 0
Date: 2014.10.16
Time: 16:04:46
Freeze Frame:
Bin. Bits: 11111
Voltage: 13.60 V
Count: 6
Bin. Bits: 10011
And then a full report out of VCDS (note the error on the radio, seemingly due to the issue reported by the CAN gateway).
Thursday,16,October,2014,16:01:58:48569
VIN: WAUZZZ8FXAN024334 License Plate: 10D
Mileage: 74290km-46161mi Repair Order:
Chassis Type: 8F (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 26 42 46 47 52 53 55 56 5F 62
72
VIN: WAUZZZ8FXAN024334 Mileage: 74290km/46161miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
26-Auto Roof -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CAHA) Labels: 03L-906-019-CAG.clb
Part No SW: 03L 906 022 NP HW: 03L 906 019 AL
Component: R4 2,0L EDC H25 9098
Revision: 25H25---
Coding: 22194012232503080000
Shop #: WSC 00579 210 88779
ASAM Dataset: EV_ECM20TDI03L906022NP A02009
ROD: EV_ECM20TDI03L906022NP.rod
VCID: 800F11721BBE3A1E1BD-80D5
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 BB HW: 8K0 907 379 BB
Component: ESP8 front H04 0020
Revision: -------- Serial number: --------------
Coding: 160504
Shop #: WSC 02391 823 56573
VCID: 7AFBE39AF562E0CED59-802F
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP
Component: BCM2 1.1 H02 0328
Revision: 00002001
Coding: 033300
Shop #: WSC 02399 823 56573
VCID: 8109147618B43316143-80D4
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H50 0070
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T2 820 043 AF HW: 8T2 820 043 AF
Component: KLIMA 3 ZONEN H08 0171
Revision: D0000000 Serial number: 01130420100039
Coding: 34370000
VCID: 76E3F7AAC17A84AEB11-8023
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 N HW: 8K0 907 063 N
Component: BCM1 1.0 H29 0380
Revision: 09029001 Serial number: 00000000641122
Coding: 2600D0914034AF000009000000005D5D001D038806010141000000
VCID: 3A7B239AB5E220CE959-806F
Subsystem 1 - Part No SW: 8F2 955 119 HW: 8K2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 220310 H05 0021
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 02562A
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 Q HW: 8K0 919 475
Component: PARKHILFE 4K H06 0070
Revision: 11001001 Serial number: 51241010916951
Coding: 000001
VCID: 479D4A6EF6104D261A7-8012
Address 15: Airbags (J234) Labels: 8F0-959-655.clb
Part No SW: 8F0 959 655 HW: 8F0 959 655
Component: AirbagVW-AU10 H10 0430
Serial number: 003A4D0697Y0
Coding: 30363635353130303030554A305238463053
Shop #: WSC 02135 785 00200
ASAM Dataset: EV_AirbaAU10SMEAU485 001004
ROD: EV_AirbaAU10SMEAU485.rod
VCID: F5E170A6547C0FB638B-80A0
Crash sensor for side airbag; driver side:
Serial number: 6334MSME522474489
Crash sensor for side airbag; passenger side:
Serial number: 6344MSME530418410
Crash sensor for side airbag; rear driver side:
Serial number: 6352QSME2D5A3E34V
Crash sensor for side airbag; rear passenger side:
Serial number: 6362QSME325900164
Crash sensor for front airbag; driver side:
Serial number: 63732SME7E565120$
Crash sensor for front airbag; passenger side:
Serial number: 63832SME515B2814.
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90315JDH0000Z
Coding: 000016
VCID: 3D712886A4CC17F6B0B-8068
Component: E221 - MFL H02 0010
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8T0 920 981 K HW: 8T0 920 981 K
Component: KOMBIINSTR. H37 0255
Revision: 00000000 Serial number: CSG50EZ3A
Coding: 2F15180002002600010000
VCID: 44875D62C726663EFF5-8011
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0117
Revision: EC000056 Serial number: 5600E104088211
Coding: 00CF07
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 176
Mileage: 74286 km
Time Indication: 0
Date: 2014.10.14
Time: 21:01:04
Freeze Frame:
Bin. Bits: 11111
Voltage: 13.60 V
Count: 6
Bin. Bits: 10011
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 176
Mileage: 74286 km
Time Indication: 0
Date: 2014.10.14
Time: 21:01:04
Freeze Frame:
Bin. Bits: 11111
Voltage: 13.60 V
Count: 6
Bin. Bits: 10011
Address 26: Auto Roof (J256) Labels: 8F0-959-255.clb
Part No SW: 8F0 959 255 HW: 8F0 959 255
Component: VSG-AUDI-B8 H10 0170
Coding: 010000
ASAM Dataset: EV_ElectRoofContr 001007
ROD: EV_ElectRoofContr.rod
VCID: F1E944B620142396E43-80A4
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0308
Revision: Serial number: 0000010500602
Coding: 011042724009330C03
VCID: 45814066CC1C5F36E8B-8010
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0128837102
Coding: 011F06A2003904600220033680000000
Subsystem 1 - Part No: 8P7 951 177
Component: DWA-Sensor H03 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
Part No SW: 8F0 035 223 D HW: 8F0 035 223 C
Component: DSP Prem H10 0190
Revision: 00010001 Serial number: 34863000536503
VCID: 2149F4F638745316B43-8074
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0308
Revision: Serial number: 0000010503038
Coding: 011042324C09330C03
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000488326
Shop #: WSC 00000 000 00000
VCID: 34670DA29786D6BE4F5-8061
Address 55: Xenon Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357 A
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000001
Shop #: WSC 02145 785 00200
VCID: 387F39924BEE32DE63D-806D
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4F0 035 053 K HW: 4F0 035 053
Component: Radio U Basic H45 0074
Revision: AB001007 Serial number: 341D+0A7728974
Coding: 010003010000000101
VCID: 2541E0E62C5CBF36C8B-8070
1 Fault Found:
03455 - Function Restriction due to Faults in Other Modules
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 176
Mileage: 74286 km
Time Indication: 0
Date: 2014.10.14
Time: 21:00:25
Freeze Frame:
Bin. Bits: 00000000 00000001
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8T2 035 666 L HW: 8T2 035 666 E
Component: H-BN-EU H47 0180
Revision: -------- Serial number: 475DB0A7549996
Coding: 01010103010681ED01000B1E000000010000
Shop #: WSC 10282 123 104857
Subsystem 1 - Part No: 8R0 060 884 AR
Component: ECE 2013 1505
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
Component: E0380 Bedient H08 0100
Subsystem 4 - Part No: 8R0 906 961 A
Component: CD-Database 1293
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 E HW: 4F0 959 795 L
Component: TSG HL H10 0306
Revision: Serial number: 0000103472933
Coding: 010002324009370C03
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000103472942
End ---------------------------------------------------------------------
Seems the CAN gateway isn't hearing from the battery circuit (J367) or the voltage reg. Apparently if the car doesn't have a separate CAN module (#61) then the CAN Gateway itself reads the battery data directly from the J367 box. I suspect this is the box near the battery that you are seeing. You can take a look and see if any of the connections were disturbed or not re-connected in that area when the battery was replaced.
Also, you can check the following: {if they work}
19-CAN gateway > Measuring Blocks > Groups 18,19 and 20
and compare to the battery percentage shown by MMI {if equipped}
and:
19-CAN Gateway _> Long Adaptation -> Channel 4 -> Battery identification
This is where you could re-code for the new battery. Not always required, but it might help to solve this issue.
Hi there,
I had this issue apparently for years without knowing until I did a VCDS report.
Both Battery and Voltage Regulator Modules unreachable.
This must be a flaw in the A5 (or more) and likely a bad join on B698.
I solved it today by placing a correcting wire. See my article and resolution below.
Side effect was that start/stop wasn't working. The car had no idea about the battery load.
Working now perfect again.
Ferry
This is really helpful thank you.
The photos on the link above require a login. Can you post on here please? Or a direct link?
Thanks.
Hi ssmith,
You can sign-up for free and browse through Google translate to the pages.
It contains explenation of the issue, documents and photo's.
I solved it today and all errors are gone.
Now battery on display also indicates the correct value instead of 100%
Regards,
Ferry
Hi.
sorry for my English. It is talked more than once here (about 00458 and 03705). I found where the mistake was! There is a clutch in the wiring harness in the right rear corner of the vehicle where oxidation acts!!!
schema-problem.jpg resized_IMG_20210311_124214.jpg resized_IMG_20210311_124223.jpg resized_IMG_20210311_111007.jpg resized_IMG_20210311_111011.jpg resized_IMG_20210311_132742.jpg resized_IMG_20210311_132922.jpg resized_IMG_20210311_132753.jpg
1 - 11 of 11 Posts
