1 - 2 of 2 Posts
Are there any variations on the A5 models? For example the early 2007 built cars are slightly different to the 2009 built A5?
Im talking about 1.8/2ltr manual cars.
The variations like slightly different trims on the inside and outside. I know they did this with the A3. (in variations not referring to the s-line)
Just i was looking at a 1.8 sport built in 2007. Then looked at a 58 plate...it just seemed different...
If there is no difference with them on the 2007-2008...is there going to be a slight change with the 2009 built models? If so, what will it be?
I never noticed this, but does the A5 have the same cluster as the A4? When your driving it tells you when to change gear and holding the bottom button gives the digital speed?
The only differences, in the cabin, I can find between my 08 and the Mrs' 09 are:
09 has aux in port under the armrest.
09 has speech bubble on the speech button instead of sound waves.
09's full beam stalk returns to the central position instead of staying forward when full beam in engaged.
Another difference I have noticed is the temperature decimal is separated by a "." in my car eg(23.5) and by a "," in the Mrs' eg(23,5) but I believe this is a difference between MMI & AIS as opposed to 08/09 cars.
I'll get my coat.
1 - 2 of 2 Posts
